Question about Euro-Pro PT205 Leaf Blower Powerful 12 AMP Leaf Blower, provides 205MPH air speed, Detachable Vaccum... Vacuum
Pull Cord I was trying to pull the cord to start the leaf blower and it got stuck all the way out and won't go back in. Now I can't start it.
  • Anonymous Jun 28, 2008
    METAL SPRING CAME OUT?
CHORD STUCK , NOW FIXXED BUT METAL SPRING CAME OUT, WHEN WOUND BACK, HOOW DOES IT ATTATCH TO PLATIC COWL AGAIN?
Posted on Jun 28, 2008
How do I get the cord out a Hoover Wind Tunnel?
Hi there! If the cord is stuck and won't pull out, try gently pulling the cord while pressing the cord rewind button. Hope that helps! If you still need assistance feel free to reach us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Oct 01, 2014 | Hoover Vacuums
My cord wont rewind
The rewind tension spring may be broken or fully extended. Try to yank hard on the cord and pull toward you with some force. Pull until the line will no longer come out and if it won\'t recoil then it needs to be repaired.
Apr 01, 2014 | Electrolux Vacuums
Repair retractable cord
Depending on which model of Electrolux you have and how far out you have pulled out the cord (most of the Electrolux canisters have a yellow tape around the machine end of the cord to alert you not to pull it out any further), you might have to take it apart to fix it. However, the first thing that I would try would be to stand it on the end (the hose end at the top), and pull short jerks on the cord to see if it will correct itself and retract. If that does not fix it, I would stick a screwdriver in the hole where the cord comes out of the machine and attempt to wind the cord reel back up which will slowly wind the cord back up on the cordwinder. This usually cause the cord to wind back up. If that does not work, then the only option is to take the machine apart to fix it.
Dec 11, 2013 | Electrolux Vacuums
Retractable cord stuck
I wonder if there is a tangle in the cord. It could have also come off the wheel inside. Open the vacuum to see if you can untangle the wire and put it back on the wheel.
Nov 29, 2013 | Hoover Vacuums
Cord won't stay out, it keeps going back in
when pulling the cord out, it should 'keep' it that spot if you pull a certain direction, cant recall if it is up, or down, left or right, and pulling it opposite direction releases the cord again
Mar 10, 2013 | Electrolux EL6984A UltraSilencer Green...
Just trying to find out how to open the Panasonic V9635C vacuum cleaner. Cord is stuck inside. Thanks
Good day!!!!
before you decided to open the cover of your vacuum please try this first...Use long nose pliers or any tools that reach the cord then try to pull it out while pressing the cord lock button..
If there is no other way than open the cover of your vacuum..just remove the screw on the bottom of the vacuum after that you can freely remove it..
after that try to look the possible cause of that problem to prevent it for coming back..and apply some remedy on it..
I hope this information will be helpful..
Thanks for using fixya...
Aug 27, 2011 | Vacuums
The cord will not rewind
These get stuck all the time...I own 2 of these , and I have done this many times...Get a can of WD40 or some type of spray lubricant with the little straw in the nozzle. Try pulling and pushing the cord back inside(don't pull it too hard) while you are spraying the lubricant directly inside where the cord comes out. push the cord back in as if you were going to force all of it back inside the cord winder. You may even have to bump the back of the machine where the cord winder is located. But it will wind back up.If you are worried about getting the lubricant on something that it doesn't need to be on , then take the Vac apart and spray it directly on the the coils of the cord winder..A lot of times, that's all they do in the repair shop when they tell you they replaced the cord winder....
Jun 15, 2011 | Electrolux Epic 6500 Vacuum
Kirby won't start. cord got stuck and it stopped, but after I wiggled it, it worked again. Then the next time I couldn't get it to start. took cover off of cord, it looks fine, no fraying. Its an older...
The problem is most likely a bad cord. Take off the cord cover on the side of the motor unit, and pull the cord straight out to remove it. The cord can then be tested with a voltage meter, and replaced if necessary.
Jan 24, 2011 | Vacuums
Cord getting stuck, won't come fully out.
Hi Karen. Chances are your cord has a kink in it which is preventing it from coming all the way out. Pull the cord out almost as far as it will come and then twist the cord one way or the other and pull to get the kink out of it. Once you have it all the way out you can start closest to the machine and smooth out the entire cord to be sure that the kinks are more or less permanently gone.
Apr 30, 2009 | Dyson DC08 Hepa Allergy Bagless Canister...
Bosch cannister vac: Cord is stuck--won't rewind
It probably is, these cords are usually 15-25' long ;-)
What you can asssume is that the cord is simply twisted upon itself and doubled up so cannot easily come out, and will not go in... therefore.
Pull gently on the cord and twist in a clockwise direction. Does the cord seem to get a bit longer? If not, or if it gets tighter, try counterclockwise. If you keep trying eventually it will loosen and you can fully extend the cord. Compare this to holding a piece of string between your hands by the thumb and index fingers. Hold one end still and twist the other 20 times (twisting the string). then relax the string between your hands. See how it immediately forms a loop? That is the problem with your cordreel too. There is a loop in there that we need to undo. Now pull a bit so you can still see the loop, and then start untwisting to see what happens. You can also do this with a YoYo ;-)
Be patient, observe, sensitize your tactile senses and see if you can figure out which direction loosens your cord - and get it out ;-)
Good Luck
Hopefully you wont have to take it all apart. that cordreel spring is very strong. Be careful if you do go in there.
Mar 26, 2009 | Bosch BSG71360UC Bagged Canister Vacuum
Euro-Pro PT205 Leaf Blower Powerful 12 AMP Leaf Blower, provides 205MPH air speed, Detachable Vaccum... Vacuum Logo
215 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
