Question about Toshiba Satellite A135-S4527 Notebook
First..cannot connect to internet, IP address is blank..wen ipconfig is type in command prompt..so what i did is uninstall/ install LAN driver (realtek) then after that..laptop always restarting..
    President:
  • 2,291 Answers
Click Start and Open the Control Panel 2. Go to System and Maintenance, Click on System. 3. Select Advanced System Settings and choose Advance tab. 4. Under Startup and Recovery, click on Settings. 5. Under System failure uncheck Automatically restart. Another cause for random reboots is that the computers processor is getting too hot. To check this, enter the computers bios during boot (usually by pressing Delete, F1 or F10 when the computer just starts) and there will be an option about the computers temperature (often under "PC Health"). U can have registry error.Run a registry cleaner reg in out
Posted on Sep 16, 2010
Hi there, Mine is a wifi problem.. at home or at a couple of other places I've tried, my Aspire One connects no probs. At work, it constantly tries 'Acquiring Network Address', and on going...
Plug LAN cables or turn ON Wifi.
Enter Run command or type cmd.
on the command prompt screen ( black it is ) type:
ipconfig /release
enter
next type:
ipconfig /renew
enter
type exit
NOTE: if the problems still remains,which means the router use a STATIC ip eg.192.168.1.5
( CONFIG INTERNET PROTOCOL TCP/IP = ip address : 192.168.1.5 subnet mask :255.255.255.0 default gateway : 192.168.0.8 )
akee_akee@live.com
Aug 16, 2011 | Acer Aspire One Netbook 8.9" Notebook
Tip
Internet is too slow how to make it fast
Please reconnect your ethernet cable . Right click on the LAN connection icon and click on repair.. It will get clear otherwise,go to windows. then to Run . in run window type "cmd" you will get a window named command prompt. In command prompt , type ipconfig. Now you will get ip address of your system. Then type ipconfig/release to release your ip and after some time type ipconfig/renew .in command prompt...So you will be getting new ip and it will be faster.
on Dec 03, 2009 | Computers & Internet
My wireless internet stopped working. i have model #wrt54g v8. i have cable internet also. when the wireless stopped working cable company checked said everything on there part is fine. its pluged in. the...
When you plug in the ethernet cable the corresponding numbered indicator on the router should flash to indicate a LAN connection and some data flow from the router to the computer. This does not necessarily mean that there is data flow from the internet to your computer via the router. Simple check would be to use a smartphone and try and connect to WiFi on the router but restart the router first. If the smartphone is also having problems then the problem may be with your internet provider or the router. If the smartphone connects then restart the computer. If the computer still does not connect then try the following steps to refresh the computers IP address:
For Windows XP
Step 1
Click Start->Run, type cmd and press Enter.
Step 2
Type ipconfig /release at the prompt window, press Enter, it will release the current IP configuration.
Step 3
Type ipconfig /renew at the prompt window, press Enter, wait for a while, the DHCP server will assign a new IP address for your computer.
For Windows Vista& Windows 7
Step 1
Click Start on the task bar, type cmd into the search box and press Enter.
Step 2
Step 3
Type ipconfig /renew at the prompt window, wait for a while, the DHCP server will assign a new IP address for your computer.
For Windows 8 & Windows 8.1&10
Step 1
Press windows key and X key at the same time. Then click at Command Prompt.
Step 2
Type ipconfig /release at the Command Prompt window, press Enter, it will release the current IP configuration.
Step 3
Type ipconfig /renew at the Command Prompt window, wait for a while, the DHCP server will assign a new IP address for your computer.
Hope that helps.
https://fastproactiveit.com/
Proactive IT Support PC Repairs Laptop Repairs Custom Built PC Leading IT...
Sep 22, 2017 | Linksys WRT54G Wireless Router
Cannot connect to the internet wirelessly. says i
If you are getting invalid ip try the following:
  1. Click Start and type "cmd" in search press enter
  2. In the command prompt window type ipconfig /all
  3. Check the ipv4 ip address
  4. If you are getting an ip address as 169.254.xxx.xxx
  5. Go to device manager
  6. Uninstall the Network Adapter
  7. Reboot the computer
  8. Re install the driver for you network adapter if prompted
  9. You should be able to get a Valid ip address and get connected
If you have a pci network card installed
Try to remove the card and install it in another slot.
Hope you find this solution helpful.
Thank you for choosing Fixya.
Jan 22, 2010 | Acer 91.AB370.001 Network Adapter
I have a new reformat pc from hp compaq d530. We I can't connect to the internet may be because there is no local area connection. What should I do?
first make sure that you have installed your lan driver and ethernet cable is connected from both end and there is power in your router. Now at command prompt type ipconfig and look for your ip address assinged manually or automatic.....
If you see any ip address try to ping the ip itself and then try to ping gateway..
ping xxx.xxx.xxx.xxx -t (your ip add)
similarly ping the gateway
if you get reply from ip and gateway then it should work.......do reply
Nov 12, 2009 | HP Compaq d530 PC Desktop
Internet connectivity
Reconnect your ethernet cable . Right click on the LAN connection icon and click on repair.. It will get clear otherwise,go to command prompt, type ipconfig. Now you will get ip address of your system. Thentype ipconfig/release to release your ip and after some time type ipconfig/renew .in command prompt...So you will be getting new ip and it will be faster. Hope this will helps you...Thank you...
Oct 13, 2009 | Compaq Presario Notebook
IP Address
Your ADSL port IP address will be set by your ISP and will be displayed on router status page. Your LAN port IP address is likely to be http://192.168.1.254
Oct 09, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Can't find ip address
whos IP address ?
if it's your own external WAN IP address click this.
www.whatismyip.com
Your internal address LAN IP address
it could be 192.168.1.xxx
Az.
Sep 16, 2008 | Computers & Internet
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
Manually assigned IP setting lost
see there are two types of connection in your laptop pls see u define on which network choose local lan and assign ip adress and save .
Dec 17, 2007 | Computers & Internet
Toshiba Satellite A135-S4527 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
