Question about Hotpoint First Edition WMA22 Front Load Washer
One of the 3 brackets inside the drum of my machine has come loose. How do I resolve this? Any ideas appreciated. Thanks Mrs. Watson
  • Hotpoint Master
  • 3,463 Answers
Pull the lifter towards you to remove it, obtain a new one from Hotpoint, and push and slide the new one forward into place, you should feel it click into place.
Posted on Sep 13, 2010
Testimonial: "thank you this was helpful. What do I call the part when I am ordering it?"
W113 washer drum is loose inside
I had the same problem. I stripped my machine down when they told me it would cost 1200.00 to replace the bearing. I found out after taking it apart it wasn't the bearing. It was the bearing shaft assembly shaft mounting bracket that is made of cast aluminum and the metal was corroded beyond repair. I called Miele and you have to buy the whole inner tub assembly 517.00 plus tax and shipping. I will also replace the bearings as well.
Jan 08, 2012 | Indesit WA 115 Front Load Washer
My washer is making noise on the spin cycle and the drum is loose inside the washer (almost like bad bearings or loose bolts?). I took off the top and the belt and motor are o.k. , but I can't get to the...
The rear drum bearing has failed, you need to remove the door seal, take off the belt, pulley and the drum comes out forwards.
Sometimes the bearings are very difficult to remove.
You will be able to find somewhere to supply the bearing there are lots of Washer spares places.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 28, 2011 | Avanti W1092F Front Load Washer
I have a AEG lavamat 6955 sensorlogic front loader I had the motor changed 5 years ago. The washing machine still works but the drum is tight and does not turn. Even when the machine is off. It is...
Could be that the Inner Drum Spindle is broken, this is a 3 arm spider-ish bracket that holds the inner drum. To test this theory, see if you can lift the inner drum up & down from the door side, you will be able to feel if it is broken.
Hope this helps.
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | AEG L86800 Front Load Washer
Dryer will not start. Power is OK.
Sounds like your problem may be a broken belt.
If you have to replace your drum belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
If the belt is not the problem then you have exposed the motor for further checks. If the motor is ok, then I would look at the start switch or the timer switch.
Good luck,
I hope this helps
Oct 08, 2009 | Kenmore Dryers
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
One of the paddles inside the dryer has come loose, how can I fix this?
remove door screws and screws on opposite side. pull front forward and down. remove two brackets at top corners to raise top (unplug machine of course). screws are on outside of drum.
Jun 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Drum rubbing on inside walls
Go into the back of the dryer. Remove access to back and you will see the drum. Chances are your motor that turns the drum is loose or the shaft or spindle that the dryer spins on is loose from its bracket. Tighten all that up and it should be fine.
Jan 30, 2009 | Dryers
Hotpoint FEW 12
hi there i have had this problem before and found out it was due to to much weight in washing machine? or maybe your drumbelt may be loose which is connected to drum at the back on the inside? hope this helps
Nov 04, 2008 | Hotpoint First Edition FEW12 Front Load...
Sharp AL-1642CS making blank copies
You have a door on the right side of the machine. in that door is a thin piece of wire mounted inside a bracket. The bracket is white and is at an angle in the door. Do you see that now?
Jul 17, 2008 | Sharp AL-1641CS Laser Digital Copier
Trouble with Indesit WI 102 washing machine
I had trhe same problem and was going deaf!!! I know this is probably too late for your machine but it may be usefull to someone else with this model.
Originally thought the bearings had gone but had great trouble trying to source some through UK websites so decided to strip the machine. Did this by touch (no manual!) and eventually found that the bolts holding the bottom weight to the drum had all come loose (all 3!). Trying to access them to tighten was the biggest problem as the front of the machine is welded on.
Managed the above by removing the rubber door seal from the door only and tightening two of the bolts from inside the door. The third I managed to access from beneath the machine. All were tightened using 10mm socket on a bar with extension (curtain pole!) slid over the end.
During this process I had the machine on its side, removed the securing brackets, top weight + springs and wedged the drum from beneath and the side as much towards the rear of the machine as possible to aid access.
Good Luck!
Mar 09, 2008 | Indesit Washing Machines
Hotpoint First Edition WMA22 Front Load Washer Logo
61 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
