FixYa.com
Tags:
Danby DDR401 Dehumidifier
Compressor
posted by blue_eyes649 on May 15, 2008
How do I check if compessor is working properly?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 13, 2008
Not Rated (0)
DickyIV1
Rank:Wiz Wiz
Rating: 84%, 89 votes
Hi. If the compressor is working properly you should be able to feel a throbbing from the machine, and if you remove the inlet filter there should be condensation or ice on the cold pipes.
If it is throbbing but not producing cold pipes, then the refrigerant may have been lost through a leak. Not a DIY job I'm afraid.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Dehumidifiers problems?
What is the size of the drain...
What is the size of the drain... Answer This...
Beeping full signal
Is there a way to turn the... Answer This...
danby dehumidifier E3 flashing...
I took it appart and found the... Answer This...
danby dehumidifier
went i turn on the machine it... Answer This...
'E3' is flashing on the display
There is 'E3' flashing on the... Answer This...
Repair Service
Find Dehumidifier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
