Question about Fisher and Paykel 24 in. DS-603 Built-in Dishwasher
My fisher and pykel DS603 single drawer dishwasher keeps pausing itself every few mins on any cycle no error codes are shown it simply stops as if you had pressed the pause button and restarts for another few mins when i press the pause button. It will eventually compleate the cycle if you press the pause button enough times but its very frustrating.Any clues for a fix appreciated. Mal
    Problem Solver:
  • 3 Answers
Same issue here. If you found the solution since the original post, please share it. Like you're saying, it's a very frustrating problem.
Thanks!
Posted on Jan 31, 2011
  • martin7788 Jun 21, 2011
    I have the same issue.
    Has either of you guys figured it out?
    Please let me know
    Thank you
  • zorro42 Jun 22, 2011
    Well, I bought a new Bosh dishwasher and am a happy customer.
I have a fisher pakel double drawer dishwasher and it keeps pausing a couple of times through the cycle how do I stop this
Pausing - how long? The pause means the wash motor keeps halting as it is waiting for the water temperature to increase to the right wash selection. If the heater is sluggish then it will take longer to heat. Try a simple rinse cycle and see if there is any difference. (Rinse cycle will use cold water to complete)
Dec 04, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
Fisher paykel dishdrawer
The controller is detecting some abnormal condition. Clean the interior of the dishwasher with warm water and clean cloth. Remove the base drain plate etc., before cleaning and clean the plate separately. Put back and try again. If no difference, then buy Finish dishwasher cleaning kit and run the dishwasher on one of the hot cycles. (You will have to keep pushing the pause button ). See if it clears everything. If not then call the technician as the controller may need replacement.
Nov 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
Machine Running noisy during cycle
lift off spray arm and remove motor rotor and remove any debri this can cause a noisey motor.
Sep 04, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
DS603 Fisher & Paykel U1 error code ..(see our previous errors we've listed) we have now pulled out the yellow water valve that goes up behind the front panel and at the other end by removing the...
This product is total ****. Pull it out, call whoever sold the **** to you and tell the to come get it and shove it up their ***. Then buy a Bosch and live a happy life. The design is moronic. The machine is like the old jaguar. It looks good but you need two. One for the repairman to fix and one to use. These **** things should be put in a landfill. If I ever find Mr. Fisher and Mr. Paykel I will kick their *****.
Apr 10, 2010 | Fisher and Paykel 23 in. DS603H W Built-in...
Hi, I have missed place my manuel for my dishwasher. It is a single-draw stainless steel, model DS603. The problem I have is F1 is showing on the control panel and it has a beeping sound. How do I rectify...
The manual for your unit is available on
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
However, this will give you only the reason for the F1 fault code but not the causes for it.
This occurs when the flood switch at the base of the dishwasher (under the drawer) is activated. This is because there is some water gone into the base of the unit.
Causes can be - leak in the drain hose (that is at the back of the drawer) or too much foam in detergent or simply water spilling from over the drawer.
If there is a leak in drain hose then this needs to be replaced.
Parts manual is available for your unit at
http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/DISHWASHERS/599084%20Dishdrawer-Version%203%20%20eg%20%20DD603%20etc.pdf
You might be able to source it locally.
To get rid of the F1 - switch off the dishwasher power.
Extend the drawer out as much as possible and dry out the base with towels and hair dryer. The location of the flood switch is shown in the parts manual in case you are interested. Turn the power on and hopefully it was a once of problem.
Good luck
Jan 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dd603 stops while in cycle and beeps but no error codes show
Does it open the lid?... and does the display flash, as if paused?... if so, just clean the closed sensor lenses, top right hand corner of the drawer, and the little piece of plastic they shine into on the housing.
Nov 29, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Sep 08, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher & Paykel Dishwasher
f2 refers to a motor error, you have the manual??? if not hereit is, try taking apart( its mean t for you to be able to service your self, its explained in the manual as to hoe to gfe down ther, the motor/ also called rotor is located within the drawer itself and under the silver screen every compponent twist out to reveal the next look for something under there somewhere preventin the rotor from spinning freely
http://www.fp.co.nz/admin/pdfs/pdf_usecares/527972D_DD_UserGuide_NZw.pdf
Apr 08, 2008 | Dishwashers
Fisher and Paykel 24 in. DS-603 Built-in Dishwasher Logo
368 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
