Question about Dell E172FP 17" LCD Flat Panel Monitor
MONITOR WONT DISPLAY
MONITOR TURNS ON (GREEN LIGHT FOR POWER IS ON), SELF TEST FEATURE SHOWS FOR ABOUT 10 SECONDS THEN SCREEN GOES BLACK. ANY SUGGESTIONS?
Dell 171 fpl back light works but can not see words etc just white large lines no display cant see just white vert hoz large blocks
Posted on May 19, 2008
    Guru:
  • 859 Answers
Yes. Disconnect your monitor from the computer and turn it back on. If it self test and then displays a "No Signal Present" message your monitor is probably okay. I underscore 'probably' as it may fail when under a startup load wherein the display adapter is receiving a heavy load from the motherboard as the display is the first device to be loaded by the bios. Still, keep this in mind, the OS will still boot without the monitor attached and there are no error beep codes for monitor failure or unattached.
If you have heard the normal activity from your computer as it boots up while you experienced this situation with your monitor the computer is okay. If you havent' heard the normal activity and have heard some beeps, usually one long four short, your display adapter is loose in its slot or has failed. But, normally you would receive a "No Signal Present" message on screen... but not always. See, there are many variables at work here.
The final word is that your monitor has failed or will completely fail soon. Since it is a Dell and you may still be under warranty persue a replacement (refurbished most likely) from Dell. Be patient as Dell will want to take you through a monotonous troubleshooting routine to assure themselves you aren't mistaken and the problem is real. So, don't sweat it out, just wait them out. Usually with monitor replacements you get a better model than you had.
I'll be glad to assist you further if you want, just click on my user name and click on the Ask Me icon or leave a comment in this thread.
If you find this solution has given you a course to pursue that will result in your satisfaction please rate this response as fixed.
Regards,
Worldvet
Posted on May 15, 2008
Screen won't turn on
You can try to do the monitor self test.
Monitor Self Test:
1. Physically test the monitor autonomously from the computer.2. Switch both the monitor and the computer off, and then disconnect the VGA cable le from the computer.3. Turn the monitor on, pressing the power button for about three seconds. The self-test screen will come up .4. If the image is clear, bright, and shows red, green, and blue, the monitor is working properly. Video issues may be due to the video resolution in the computer, and not the monitor.5. If the image is not apparent and intense or the colors are not accurate, then the trouble is with the monitor or some of the (OSD) settings. In this case, test your particular monitor's information for OSD.
It is always important to check the color of your power light for so you can distinguish if the monitor is defective. Getting red lights on the the power panel states that the power section of the monitor is faulty.
Dec 03, 2011 | Emerson Televison & Video
No display, light goes green but on screen says no connection then goes yellow for standby tried both DVI and VGA so now linked my pc to my tele via DVI to HDMI and works fine anyone know what this could...
here is the simple test to detect hardware malfunction.
on every monitor these days whether its CRT or LCD already programmed inside self test.
detach your cable data to CPU and power on your monitor. if its displayed self test on your screen mean its OK and something wrong with your CPU, could be VGA error.
if its just black display mean some is wrong with your monitor.
if you post more detail maybe we in FIXYA could help.
thanks.
Mar 11, 2011 | Hannspree HW191D LCD Monitor
My dell computer screen goes black after a while after windows xp second up grade went on. what should i do without taking upgradee off or changing screens?
Right click on your desktop go down list to properties and left click under the screensaver tab click the power tab and turn off the power saver in other words change settings to always on and no hibernation
Nov 06, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Westinghouse LCM22W2 shows a display then turns off after half a second
I have the same problem and have traced it down to a potential power supply issue.  I bought mine at Best Buy in '06 and was told today that they will test the power supply for free.  It may range from $50.00 to $100.00 depending on where you can get it.  This does not include labor for those not qualified to work with electronics.  Hope this helps you.
Aug 13, 2008 | Westinghouse LCM-22w2 Television
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Jul 10, 2008 | AOC LM729 17" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
141 people viewed this question
Alun Cox
