Question about Dishwashers
I have a Philco dishwasher Svelta DWN17 which works well but has lost its spring or counterweight for the door. The door now drops open when not locked for washing. I am having difficulty finding a servicing firm for this machine and would try to fix it myself if I could find a part and get some details on how to go about it. Can you help, please? Alan Wright
  • 3 Answers
SOURCE: Dishwasher soap dispenser sticks
Mine dishwasher (a Maytag) did this also. At first it was becoming stuck because of the soap. My repair guy cleaned it and I switched to liquid soap and it worked great another 2 years then did it again. That time it was just wore out and had to be replaced. I was told it was no longer available but we found it here http://www.repairclinic.com/and our repair guy installed it. He was amazed because he had even called everywhere.
Posted on Jan 02, 2008
SOURCE: Door Drops Open - How to Fix
Actually the solution is quite easy.
First, get the door balance kit from ReparClinic.com mentioned herein. I believe it's Part #1059756.
Second, pull the DW out about halway from its recess (you may have to remove the two "mounting" screws where it is attached to the countertop.
Third, there are two door balance assemblies...one on the lower left side, one on the lower right side...where the door's fulcrum is (where it hinges). Each will consist of 2 pulleys, a string (with a plastic "latch" on one end, a plastic "loop" on the other), and a spring (near the back of the unit). One door balance assembly will likely be "good," one will be "broken," and the likely cause is the string has pulled from its "latch" end. Confused? Use the "good" door balance assembly for reference of how to replace the "broken" assembly. It's pretty straight forward once you compare the two.
Fourth, remove the "bad" assembly as needed. In my case, I only had to remove the string. The pulleys were fine.
Fifth, replace whatever parts you removed. In my case, I replaced only the string, but it required me to press it into the bottom pulley through the open guide at the bottom of it. In any event, replacing the string requires you pull on the string with sufficient force you can "thread" the string around the two pulleys, and hook the latch to the same location you find it latched on the other side of the door (there is a notch in the sheet metal).
Sixth, this is an optional step, but I did it so the string wouldn't pull out of its latch. Take a lighter, and heat the end of the rope in the latch (the part that's sticking out past the end of the latch). Heat it up until it begins to melt slightly, then press or ball it so it will not fray, or unravel enough to pull through the hole in the latch through which it is fitted. I don't know how they got that thing in there (I tried to put my old string back through), but it will likely find it's way out if it's left stock.
That's pretty much it. It's really not hard, and a set of instructions really aren't needed once you compare the left and right assemblies. One is almostly certainly still good, and "a picture is worth a thousand words."
Posted on Jul 01, 2008
SOURCE: KitchenAid Dishwasher KUDSO2FRSS
I recently had the same problem. One of the cords that attaches the door to a spring had snapped. I purchased cord replacments at the following URL and completed the repair myself. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059756&PPStack=1
Good Luck, Tim K.
Posted on Jul 07, 2008
  • 409 Answers
SOURCE: mdb7601aws dishwasher door drops down
hi there,
go to www.whirlpoolparts.ca to get the exploded view for your model #. it will be the located under Repair Parts.
Posted on Sep 23, 2008
  • 258 Answers
SOURCE: neff dishwasher door - think the spring has gone
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
http://www.howtofixanything.co.uk/howto-260.html
Posted on Jan 15, 2009
How do I adjust the door opening on my integrated dishwasher ?
The door springs are too tight. Please provide model number so that I can find the instructions to adjust the door springs.
Jul 30, 2014 | Tecnik Dishwashers
Operating Manual for Philco SVELTA DWN17
Hi Nicki.
I am very sorry but the manuals for Svelta are not available online. The brand Philco is built by the Indesit/Ariston group. You should be able to get a copy of the manual contacting Indesit Service spare parts number.
Here UK number: 08448 225 225
Here the contact page.
Dec 08, 2011 | Dishwashers
My dishwasher door drops down way too easy for my whirlpool partner iii. my wife found a black thin gasket under the dish washer. how can i fix the door?
replace both door balance cord assemblies on both lower sides of the door where they hinge onto the tub assembly as they are counterweights for the door
Apr 16, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Door spring seems to have broken
Yep! What happens is a "T" shaped metal piece that is "screwed" into the spring and serves as an adjustment of tension tears or bends and falls out of the spring(s). Usually one at a time.
If you are clever you can rebend and strengthen this piece and adjust the tension to normal.
Access this by removing the panel below the door where the toe kick is.
The cause of the problem will be obvious and one side will probably still be intact so you can see how they are supposed to be.
May 02, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher door drops hard when opened.
Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
Jan 15, 2010 | GE Dishwashers
I have a KitchenAid dishwasher. The door drops
either the door springs are broke,worn out or possibly the door balancers need replacing
Jan 10, 2010 | Dishwashers
Door drops hard and i have an error code 7 -
The door slamming open is a broken spring/springs. They are very easy to replace - remove the screws holding the dishwasher in... pull out slightly and replace with good ones on the sides.
Can you clear the error code by shutting off power to it?
(Mdl # helps)
Dec 01, 2009 | KitchenAid Dishwashers
Philco delta 4dl user manual
I have just bought a Philco DWN17 diswasher which seems to go quite well. Only thing is I can't work out what the cycle symbols on the front mean.(I have no manual)
Aug 05, 2009 | Dishwashers
Door spring does not work.
bryan,
I do not have a place to order parts for a Neff dishwasher, but I know these dishwashers have springs in each hinge that will wear out/break over the years.
Replacing those springs will stop the door from drooping open.
Good Luck!
Apr 05, 2009 | Neff 24 in. S5409X0 Built-in Dishwasher
Broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs. Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
When replacing the springs or cables, all of them should be replaced at the same time.
To access the door springs and cables remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to get to the screws over the panel, then close the door to remove the panel.
There are two common types of spring assemblies. One type connects the springs from a hook on the dishwasher cabinet of to a tang on the door hinge .
May 07, 2008 | Dishwashers
Dishwashers Logo
221 people viewed this question
Top Dishwashers Experts
