Question about GE PSS26MGS Side by Side Refrigerator
Icemaker just stopped making ice
My PSS26 is about 2 years old. The icemaker just stopped working when -- when the ice bin emptied its ice, we noticed no more was being made. The power light is solid green. I haven't measured the temperature yet to see if it's below 17F.
It has a horizontal paddle that I presume starts/stops the ice production. It's tucked back near the ice tray. I guess when the augur turns, an abundance of ice would move the paddle toward the front (which would shut off the ice production)? Is that how it works?
Should I try pouring water into the ice tray (from an outside source)?
Other ideas? I'm pretty handy and will report back my results.
The water dispenser on the door works fine (although the water seems warmer than it used to be). The Crushed, Cubes and Quick Ice lights all work.
My model is actually GE Profile Model PSS26MSTE-SS
I couldn't find any Ctrl-Alt-Del buttons.
  • 4 more comments
  • dougkramer May 15, 2008
    I don't see any arm that moves up or down, just a paddle that moves horizontally. Please see this photo:
    http://picasaweb.google.com/douglas.kram...
    The paddle is horizontal, just above center in the photo.
    I've tried pulling it out and pushing it in, with no change.
    Am I overlooking the arm you talk about, or did it break off, perhaps?
    Here's my icemaker:
  • BC58 May 25, 2008
    We are having the exact same problem as he is and I cannot locate the arm that you are talking about. Please help.
  • dougkramer Jun 22, 2008
    The answer from 22yooper is incorrect for this particular model -- there is no arm thatmoves up and down -- rather, it moves horizontally forward and backward.
    This solution worked for me
    Look at the paddle. There is a spring connecting it to the ice maker. The spring is a coil and then a vertical wire. That wire had popped out of the icemaker. I was able to click that spring back into the hole and the ice maker starting working again and you could immediately see that the springy-ness was back in the paddle. Hard to explain. If you want me to take a picture and post it, let me know.
    http://forums.partselect.com/refrigerato...
    The answer above from 22yooper is incorrect for this particular model
    -- the arm (paddle) moves horizontally forward and backward,
    not up and down.
    This answer worked brilliantly for me and another person:
  • Anonymous Mar 24, 2009
    I HAVE THE SAME PROBLEM...BUT THE SPRING LOOKS LIKE ITS IN THE RIGHT SPOT....STILL IT DOES NOT RECOIL PROPERLY
    Problem Solver:
I had a similar problem with ours - everything worked except the ice maker wouldn't drop the cubes. It would drop a few cubes if the paddles was slowly pushed back and forth and that was it.
How I fixed it: Where the paddle connects to the main unit there is a spring. When I looked real close, you could see a straight edge end part on the spring sitting back further. I took the edge of the spring and pulled it forward. It clicked into place and everything works great now! Glad to not have to buy a new one! Turned on the quick ice button and over night the bin bucket filled up.
Posted on May 06, 2010
The only way we fixed ours was to go out and buy a whole new ice maker!!! That meant replacing ours that was only 3.5 yrs old! What a crock and I will NEVER buy another GE refrigerator that makes such an ice maker that only lasts 3 yrs! I even had a customer service rep from GE tell me they are worthless and that they get tons of calls regarding our same problem! Obviously GE does not listen to its customers. I can only hope that they have improved it and this one will last more than 3.5 years!
Posted on Jun 22, 2008
6/21/06 I have same problem with my GE pss26msrc ss . Looks like the same icemaker as in photo. checked the box where the ice forms,there was some ice frozen stuck.Poured water to remove ice.Turned icemaker back on,replaced ice catcher box.Freezer did feed water into icemaker ice mold.Still waiting for results.Water feed does work,but do not know if motor pushes formed ice out so that new ice cubes can be made.
Posted on Jun 21, 2008
  • 828 Answers
As these ice makers cycle there is an arm that moves up while the ice is being freed from the ice maker. After the ice is dumped into the dispenser bin the arm continues a downward motion. If it encounters ice in the downward travel it shuts the ice maker off. If this arm is locked in the full up position the ice maker is manually shut off. Check this arm and make sure it is not locked in the up position.
Posted on May 15, 2008
  • James Helmer
    James Helmer Jun 22, 2008
    Thats the modern engineering technology for you.
How do I get my my GE refrigerator model no. GSS201EPJWW to stop making ice? Bin fills with ice but don't know how to turn off icemaker. Thanks
slide the panel out from in front of the icemaker,there is a slide switch on the icemaker marked on/off
Jan 11, 2013 | Refrigerators
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
Sep 05, 2009 | Whirlpool Refrigerators
Frigidaire ice maker not working
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | Frigidaire FRS6R5EMB Side by Side...
Icemaker is leaking into ice bin.
it sounds like the water valve is leaking
May 07, 2009 | Kenmore Refrigerators
Whirlpool ET1CHMXK09 top freezer with icemaker: Has leaked almost daily. At installation, Lowe's employees had trouble with gasket provided in the icemaker installation kit and had to get something else...
I decided maybe we were fixated on the ice maker because it's the obvious culprit/source of water input. However, thought more broadly and then fixated on the frost-free aspect and the drip pan. In case ice was building up and defrosting within the refrigerator back, even though the pan was bone dry, I removed 1/3 of the freezer contents to another freezer to maximize air circulation in the freezer compartment. At the 24-hr mark, after this change, there was an approximate 2 tablespoon drip downstairs so I don't consider the problem fixed necessarily. The next 24-hour period is late this afternoon. However, I still empty the ice cube bin so it will never stop making ice in case it is the pressure of the water in the line which, when no ice is made because the bin is full, it leaks where the line comes into the back of the fridge, but out of sight, until it pools on the floor enough to run through to the floor below, downstairs.
Thank you for contacting me. I'm telling others about your site.
May 04, 2009 | Refrigerators
Doesn't fill up
sounds like the ice is not releasing from the freeze plate before the waterpump comes back on. you can turn off icemaker - dry the plate with a towel - take fine steelwool and go up and down on the tray until all discoloration is removed and the plate is shiney - empty bin - flush plate and bin - turn back on and see if ice falls onto cutting grid either right before or right after waterpump comes on.
Nov 24, 2008 | U-Line Icemaker
Icemaker will not was dispense ice
My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
Nov 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PSS26MGS Side by Side Refrigerator Logo
754 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
