Question about Refrigerators
Whirlpool fridge/freezer machine defrosts
  • 828 Answers
Check the condenser behind the toe grill on the bottom front and clean behind it. If dust is built up on these heat transfer areas it will cause the refrigerator freezer to defrost. After cleaning with a vacuum cleaner using the crevasse tool to get into the narrow areas you may want to blow any additional dust out. Also from the back, remove the fiber panel on the lower back of the refrigerator and check to make sure the fan that circulates the air is operational when the compressor is running. Make sure this fiber panel is replaced after you are done as it is critical to normal operation for proper air circulation.
Posted on May 15, 2008
Whirlpool fridge freezer
The fridge side is cooled by the freezer side. Try unplugging power, open freezer door and let thaw out/defrost.
Apr 30, 2014 | Refrigerators
I have a Whirlpool Low Frost Fridge. The fridge part is not colloing however, the freezer is. What can the problem be.
This is a usual indicator that you have a defrost problem or the fan in the freeezer compartment is not running. First thing to do is open the freezer and listen for the fan. If its running look on the bck wall of the freezer to see if there is a build up of ice cover the back wall. If so you have a defrost system failure, and with whirlpool more than likiely it will either be your defrost timer or your bi-metal thermnostat which is located behind the freezer wall. The timer, dependingon your model will be located in the ref. side or in some cases in the back of the machine by the compressor.
Nov 03, 2010 | Refrigerators
How do I defrost my whirlpool ARC 5070 fridge/freezer? (I lost the guide when I moved) Thanks to anyone who can help me
My whirlpool Fridge/freezer powers up but both fridge and freezer notworking,have defrosted the freezer but noluck,have turned on foran hourand then back again,as per user guide still no luck.
Jul 27, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Freezer working fine, but no cold air to fridge
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control unit
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 29, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
I own a three year old Whirlpool side by side fridge freezer with ice maker and water dispenser. Icemaker not now working, and fridge temperature warmer, not cooling food etc sufficiently
ice maker will not work,i push the handle to get ice it makes a noise like the motor is running .the water works just fine .please any ideas
Jun 28, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ARC7470AL FRIDGE FREEZER
you have one of three problems and only one problem
the defrost timer is bad
the defrost heater is bad
the defrost thermastat is bad
only one of the above is the problem but no way to know without checking each part with and ohm meter
May 07, 2008 | Refrigerators
Defrost side by side fridge
no you can not. there are no separate defrost control for freezer and fridge. the evaporator is located in the freezer section and it is supposed to defrost automatically. what is the problem in the first place?
Feb 08, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Fridge Model WRX57H Defrost Timer
if you couldn't find a defrost timer then just unplug it or switch it off until all the frost (ice) melts!
Nov 19, 2007 | Whirlpool 19.6 cu. ft. Upright Freezer...
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
