How to open the locked door of IFB washing machine
  • 351 Answers
SOURCE: Washing Machine LG WD-8013F
it may be the lock but this model is known for board faults,take of the top panel and remove the control panel and see if the board is burnt.there was a recall on some of these machines a while ago in australia not sure where you live
Posted on Apr 03, 2008
  • 1462 Answers
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Posted on Jul 10, 2008
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
SOURCE: door will not open on hotpoint wd420 washing
Turn off the power and isolate the water supply, Move the machine in to the middle of a room - you need some space. If you then rock the washing machine backwards, there is a door release. It's extremely hard to reach, about level with the lock, so make sure the machine is both stable and that someone is with you to ensure the machine doesn't fall and crush you to death!
It basically looks like an little electronic panel, in the middle of which you can see a steel knoble. Press with some force, and the catch will release.
This just happened to ours, and the actual lock is broken, so that was why we couldn't open the door. Yours might have a similar fault. The mechanism is partially plastic and it looks like the plastic sheared off and then the electric release no longer pulls the catch in to the position where it will release.
Posted on Dec 08, 2010
Ifb washing machine showing DOOR NOT CLOSED
Visit the sites linked here for more details about the error cddes to many brand washing machine, and dish washers.
http://electrotechnician.blogspot.com/
https://electronicshelponline.blogspot.com/
http://homenol.blogspot.com/
Aug 10, 2016 | IFB Washing Machines
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
What to do when h1 is flashed in ifb automatic front load washing machine
Cannot find anything about H1, but error code E01 is door not closed properly. An instrument at work sometimes reads "h1" and this indicates a "high" reading, but don't know if that is really relevant here. Sorry I can't help any further. Good luck.
May 19, 2015 | IFB Washing Machines
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
How to reset ifb digital washing machine?
I have ifb digital 7kg machine.
When it reaches 0.13 and 0.19 it get pauses.
What to do.
May 13, 2012 | IFB Washing Machines
I have ifb elenaa washing machine. my problem is that water can't enter or drain from machine .help
make sure the water is turned on at the faucet handle behind the washer.
Apr 20, 2012 | IFB ELENA
My washing machine says LO how can i unlock the door is opening but nothing is happening still showing LO
mam there is an error in the lock check the contacts of the lock by inserting a tester or a screw driver into the female lock and see the indication if the lock is good this test will work on that and if its not working so please change the lock(female lock).
Sep 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
3,275 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
