Question about Lexmark X1195 All-In-One Printer
Lexmark X1100 all in one printer problem
Hi Guys,
Really would appreciate a little help. I opened the printer to change cartridge then I pushed it back down to close it a little too hard and a small white piece has fell off inside. I now cant use the printer because it says the printer is not closed although it does close. I have opened the printer up and found the piece which is about 3 cm long and half a cm wide. Obviously it is a clip that connects somewhere. Do you have any ideas for me. Seems simple but can't figure it out. darrrrrrrrr
  • 71 Answers
SOURCE: lexmark x3470 printer
Either the cartridge didn't get seated properly or a tab on the door that pushes a hidden micro-switch is broken off, not aligned correctly or obstructed from going in to the slot. The tab is a non-assuming plastic tab that lines up with a hole in the housing. "If" it is broken, bend down the center of a paper clip to form a "T" and insert it into the hole. The "T" shape will keep it form falling through. You may have to tape it into place. This is a safety feature to keep you from reaching in while it is printing or about to start. So remove it before doing any maintanence.
Posted on Jul 01, 2007
SOURCE: Lexmark X3470 Printer Plastic clip (white)fell off
i pushed the little black trigger in and at the same time put a couple drops of crazy glue on it. works like new!!!!!
Posted on Mar 27, 2008
SOURCE: cannot connect with my lexmark printer X1100. UBS connection
as stated i have a mac apple laptop. I have safari as my program so I do not have start or control panel. I do have a system preference icon which gets me to printers and faxes. when in printer and faxes it states that my lexmark already is my default printer. CONFUSED
Posted on Apr 01, 2008
wayneard
  • 1901 Answers
SOURCE: I cant figure out how to change the ink cartridges on my lexmark
On an X4850 the whole top of the printer opens up to reveal the cartridge carriers. Press down on the latch of each side to reveal the cartridges.
Here is a link to the User guide: X4850 User Guide It is described on page 94.
Posted on Nov 20, 2008
  • 185 Answers
SOURCE: I replaced my ink cartridge closed the lid.
Try and replicate the shape of the piece that is broken off,
If it is a straight edge a piece of wide transparent tape could do.
Other shapes can be made with the use of epoxy type putty.
this material is available at you plumbers store.it is sold as 2 separate products thatis sift and malleable when separate.
but by combining the pieces, they will gradually get as hard as metal. it is quite inexpensive.
If you use a piece after you have molded then together. Shape the part that is missing on the printer case.
then firmly put it in place after 24 hours. if it hold. it should be as good as teh original piece, for a long time.
You can also use automobile radiator putty. it si made of the same materiels too and work as well.
How did you break that piece anyway??
Posted on Jan 25, 2010
Lexmark Series X1150 My printer does not recognize the color print cartridge and only prints in Black even though the color cartridge is new. First time this has ever happened. I've had the printer...
Make sure you are inserting the correct color cartridge versions for the Lexmark X1150 (either #26 or #27).
Try to clean the cartridge nozzles. On your computer, open the Lexmark Solution Center, click Start > Programs > Lexmark X1100 Series > Lexmark X1100 Series Solution Center. From the Maintenance tab, click Clean to fix horizontal streaks. Your printer will then print a page that will help clean the nozzles from possible dirt and clogs.
If that doesn't help, try to insert a different known working cartridge (e.g. your old cartridge or another new cartridge). It could be a faulty cartridge issue.
Sep 01, 2011 | Lexmark X1150 All-In-One InkJet Printer
MY LEXMARK X1100 CENTER DOES NOT OPEN.
Hi. The software may not be installed properly. Try running the software again using the installation cd that came with your printer. If you have tried it already. uninstall and reinstall the software to give your computer a fresh start. Also, check your firewall and allow all Lexmark communications to go through. Hope this helps.
Mar 14, 2010 | Lexmark X1270 All-In-One InkJet Printer
Hi need to know how to open my printer and get to where i need to put the new cartridges in it i have a lexmark x1185 please help me
The entire top of your printer lifts up. (Scanner unit.)
Refer to this setup guide:
Lexmark X1100 Series Setup Guide
See steps 6 through 9.
Once the lid is lifted, there are locking tabs on each cartridge. Squeeze and lift up. You can then lift up and out on the cartridges. Reverse the procedure to install the new cartridges.
NOTE: Make sure the printer is ON during cartridge removal and replacement.
Thanks for using Fixya.
Nov 05, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
My x1180, how do i change the ink cartridge
Here is a copy of the setup guide that should give you some good help:
X1100 Setup Guide
The cartridges are in cartridge carriers under the scanner unit cover.
Jan 12, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x1100 series all in one printer
Get on the internet, go to Lemark site they have a area for support, and download drivers place on a cd or down load to your desktop. When finished run the drivers and your printer should work. If you can find on lexmark site there are many other sites that have them. Just type Lexmark x1100 drivers and pick a site in your search engine. You should not have to buy them.. Good luck.
Jul 09, 2008 | Office Equipment & Supplies
FAX with my Lexmark X1150
you can find a complete .pdf guide thats easy to understand by clicking the link below !
Lexmark X1100 series User Guide.pdf
Worry not , the X1100 series should match your x1150 model installation procedure!
Whatever O/S you use , you can get the Lexmark drivers to match from the Lexmark downloads section for X1100 series below ( also links to other models as well !)
Lexmark X1150 drivers & downloads / Choose your O/S
Jun 02, 2008 | Lexmark X1150 All-In-One InkJet Printer
Printer installation
Hi Roger22
May 22, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark All in one printer
looks like you may need to replace the black cartridge.
usually when you open the cover of your printer, cartridge carrier will move to the center. that's where the cartridges are, you can open it buy pushing it down and release it.
you can also checked lexmark site for this
check out this link too.
x1185 and x1100 are most likely the same.
http://www.lexmark.com/publications/pdfs/x1100/eng/ug.pdf
Mar 26, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
96 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
