I was built before cell phones or desktop computers! Older sewing machines are more reliable that the new fancy electronic ones.
Broken thread is usually caused by old rotten thread, cotton breaks down, or you may have a bad batch. Or it is caused by incorrect threading, or incorrect tension (upper or even bobbin tension). Or the machine needs cleaning, servicing and timing.
First turn off the XL-1000 and remove the auxilliary bed. Attach the embroidery bed and push the lever on the front of the bed to the right. Switch to the embroidery presser foot. Thread the machine with the appropriate embroidery thread and bobbin thread. Set up the embroidery hoop. Turn on the machine. Lift the presser foot to the highest position. Slide the embroidery hoop under the presser foot such that the key on the hoop goes into the slot on the embroidery bed.
There are tons of diagrams, web sites and videos about older Singer sewing machines. A lot of them are very similar, so finding information for one will most likely be beneficial.
All Singer models would have arrows/numbers to guide your top threading from the spool pin to top thread guide, for most machine start from your thread spool pin, to a thread guide follow arrow down then up into the take up lever and down to the needle thread guide then into the needle hole. Assuming you have wind and install the bobbin thread into the bobbin case, turn your hand wheel towards you makes the needle bar goes down,keep on turning till the needle bar is fully up again, pull the end of the top thread to pick out the bobbin/bottom thread. With your material/fabric under the presser feet, apply the presser feet lever down, you are ready to sew.
try changing the needle check to make sure the top thread has not come off the thread take up lever it could also be a problem with the timing and the machine would have to be checked by a technican
Try to turn the hand wheel (on the right side of the machine) backwards ( if you are facing the right side of your machine, turn it clockwise) and try to remove the thread. Once its freed up, change the needle.
