My hard drive recognize only a 9.96 mb where i think the capacity of hard drive is 200 + gb. how should i fix this problem
  • 11,800 Answers
Boot from a Linux Live-CD, recover all your files and launch the install program. In it when presented, select to use the entire hard disk - the Linux OS will be installed on it. Later if you want to you can reinstall Windows also on the whole disk.
Posted on Sep 13, 2010
My HDD Dell 300GB 15K 3.5" SAS, i used with Windows Server 2008 Enterprise. The problem after installing the hdd total capacity its 279 How can manage this? Thank you
Hard drive manufacturers market drives in terms of decimal (base 10) capacity. In decimal notation, one megabyte (MB) is equal to 1,000,000 bytes, one gigabyte (GB) is equal to 1,000,000,000 bytes, and one terabyte (TB) is equal to 1,000,000,000,000 bytes.
Programs such as FDISK, system BIOS, Windows, and MacOS use the binary (base 2) numbering system. In the binary numbering system, one megabyte is equal to 1,048,576 bytes, one gigabyte is equal to 1,073,741,824 bytes, and one terabyte is equal to 1,099,511,627,776 bytes.
Simply put, decimal and binary translates to the same amount of storage capacity. Let's say you wanted to measure the distance from point A to point B. The distance from A to B is 1 kilometer or .621 miles. It is the same distance, but it is reported differently due to the measurement.
Capacity Calculation Formula
Decimal capacity / 1,048,576 = Binary MB capacity
Decimal capacity / 1,073,741,824 = Binary GB capacity
Decimal capacity / 1,099,511,627,776 = Decimal TB capacity
Example:
A 500 GB hard drive is approximately 500,000,000,000 bytes (500 x 1,000,000,000).
500,000,000,000 / 1,048,576 = 476,837 megabytes (MB) = 465 gigabytes (GB)
Mar 07, 2011 | Dell 300GB 15K RPM SAS 3.5-HPLUG HD R710...
I have a compaq witha samsung hd M/NSP2504C, S/N S09QJ1ULB30333. What are the speed and buffer specifications and which hard drive would you recommend for a compatable replacement or slave.
Hello
Samsung SP2504C is a 250 GB hard disk drive using the new SATA-300 interface, which allows a maximum theoretical transfer rate of 300 MB/s. Its main specs also include an 8 MB buffer, 7,200 rpm rotation speed and support to NCQ (Native Command Queuing). In this review we checked the performance of Samsung SP2504C installed on a motherboard using a regular SATA-150 port and also on a motherboard using the new SATA-300 port.
This very same hard disk drive is also available with a 200 GB capacity, being called SP2004C. Both belong to SpinPoint P120 series from Samsung.
Good LUCK AND DO RATE THE SOLUTION IF HELPS
Dec 20, 2010 | Compaq Computers & Internet
If I try and format my LaCie drive through my computer its capacity shows as 9.99 MB why is that if I do format it (NTFS) will it have the correct capacity of 250G
You may have two or more partitions on this hard drive. If you delete all the partitions and then format the hard drive then you will have the full unformatted 250 Gb capacity.
Sep 24, 2010 | LaCie (300770) 250 GB Hard Drive
Maxtor Personal Storage 3200 500 GB Hard Drive suddenly not recognized. Light on, tried alternate similar power supply, tried different computer along with different operating system. Please help.
May be your Personal Storage 3200 500 GB Hard Drive power socket pins are not seated well when you connect so make sure the pins are in good condition.
Think this is helpful !
Aug 11, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I need to know what kind of hard drives and other hardware i can use with a HP Compaq D530 Socket 478
HERE shows an overview of the specs for the HP d530 series. Shows IDE type HD's.
Technical Specifications - Hard Drives
7200 rpm SMART III Ultra ATA/100 Hard Drives 40-GB Capacity 40,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 78,165,360 Operating Temperature 41° to 131° F (5° to 55° C) 80-GB Capacity 80,000 MB Rotational Speed 7200 rpm Interface Ultra ATA/100 Height
1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including settling) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 156,301,488 Operating Temperature 41° to 131° F (5° to 55° C) 160-GB Capacity 160,000 MB Rotational Speed 7200 RPM Interface Ultra ATA/100 Height 1 in (25.4 mm) Width 3.5 in (88.9 mm) Transfer Rate Synchronous (Maximum) 100 MB/s Seek Time (typical reads, including setting) Single Track 0.8 ms Average 9 ms Full-Stroke 17 ms Physical Configuration Logical Blocks 320,173,056 Operating Temperature 41° to 131° F (5° to 55°C)
Feb 21, 2010 | Computers & Internet
IS IT POSSIBLE TO INCREASE MEMEORY? BOTH RAM AND
Yes, it's possible to increase both RAM & HARD DRIVE Capacity.Your Pc comes with RAM: 512 MB in size and Storage (hard drive)Capacity: 80 GB.
You can put One more 512 MB of RAM or you can replacethe ealier RAm with 1GB RAM or Put two 1 GB RAM Instead.
For Hard Drive,use your 80 GB Hard drive as external storage device, and Put a 320 Gb new Hard drive.
Dec 26, 2009 | HP Pavilion dv1000 Notebook
During installation, windows XP only recognizes 131062 mb of my 320 gb hard drive
This is because "the original ATA specification used a 28-bit addressing mode, allowing for the addressing of 228 (268,435,456) sectors (blocks) of 512 bytes each, resulting in a maximum capacity of about 137 gigabytes" (wikipedia). To fix this try upgrading your computer's bios and enabling any bios entries for larger disks. Also make sure that you are running your operating system with all of the current updates.
Nov 21, 2008 | Computers & Internet
NexStar hard drive doesn't recognize its size
It may be crashed....use [Nucleus Kernel for FAT and NTFS ] software...
Oct 11, 2008 | Vantec NexStar-3 External 3.5inch...
Copy heavy files fail from iRiver to Hard-Drive
That is too many songs to transfer at once - transfer less at a time
Oct 10, 2007 | iRiver H10 MP3 Player
Computers & Internet Logo
David Payne
David Payne
