Question about Dishwashers
The top and bottom spray arms were not rotating. We assumed there was a fault with the pump. We replaced the pump. The bottom arm now spins and sprays water but the top arm will spray water but does not spin.
  • 4,323 Answers
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are oopen. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and youl'll need a Torx driver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... If it does please do not forget to accept the solution or post back with the make and model number of your dishwasher for assistance. Daniel
Posted on Sep 13, 2010
Bottom arm will not spin
Possible that the water pressure is low as there is dirt accumulation within the unit and so the pump filters are clogged
click this link : filters
Spraying arm
Jan 24, 2013 | Dishwashers
I have a Bosch dishwasher SGV43A03 and the bottom spray arm doesnt spin. It is free to move by hand, is clean inside and has clean nozzles. The water pump is operating the top jet and top spray arm...
Hello this means the circulation pump would need to be replaced. You can purchase the part from the link below. Also there are several articles that explain how to work on Bosch dishwashers.
Appliance & Refrigerator Repair
Mar 23, 2011 | Dishwashers
Water pumps into the bottom of the dw but the spray arm doesn't rotate and spray. It also empties, so the problem seems to be with the spray arm. Any solutions?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 04, 2010 | Asko 1385 Dishwasher
Spray Arm Doesn't Move on my GSD5630d01ww!
When you say the dishwasher is running do you mean that the pump is operating?  If the pump is not pumping water the arm will not spin.  Is there a bottom arm and is it spinning?  If it spins then the pump is working. The upper arm will not spin if it is blocked by hitting a large dish or utensil.  There should be some sort of tube or tower (some are collapsible) in the center of the lower rack that shoots water into the bottom of the spin arm above.   Is it missing, blocked or clogged?
May 30, 2009 | Dishwashers
Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Jan 17, 2009 | Dishwashers
I have an equator PLS600 and I can't seem to get it to work. I have tried the WikiFix to help a stalled dishwasher, by adding water and vinegar. When I put on the wash cycle it does not run. Even with the...
Give the spray arm a spin to make sure it rotates. It should spin freely. If not, remove plastic spray arm clip, flip it over, replace it, and try again. Make sure holes in the spray arm are clear of debris. Spray arm must be clean for it to spin. If spray arm does spin freely, remove spray arm clip, spray arm and the post assy (the thing the spray arm attaches to). Try your WikiFix again. This time add baking soda to the hole the post assy came from. Top it off with white vinegar. Leave it overnight. In the morning, stick your finger down the hole where the spray arm assy sat. You should feel a plastic thing. This is a propeller attached to the recirculation pump. You need to free it up. Get that thing moving with your pinky or a chopstick or whatever. Try the machine without the spray arm. You should get water blasting up from the hole. Reassemble the spray arm.
Nov 26, 2008 | Equator 20 in. PLS600 Free-Standing...
Bottom rotating arm doesnt spray water but top arm does
i have a similar problem. water is not reaching the bottom spray arm. there. i have an underwater case for my digital camera, so i'm going to put a torch or 2 in some waterproof bags and remove the bottom spray arm and run the dishwasher to see if there's water coming out of the bottom pipe, if not, i need to try and see if there's a blockage in the system, or a dodgy valve, could be that the soldering's or the control panel's buggered.
Nov 24, 2008 | Siemens 24 in. SE25T250 Free-Standing...
Small plastic top and mid spray arm do not turn, bottom does
decrete, you want to get down to the chopper and screen. If the screen is plugged up with gunk there won't be enough pressure to reach the top spray arms. Check out the posted pics. Remove the lower spray arm. Rotate the rear feed arm to the right until it unsnaps from the tube going up the back. See the 4 torq screws holding the filter on. Remove them. Lift the filter up. Now you will see the chopper inlet cover. 1 torq screw holding it in. Lift it up and there's the chopper and screen. Catriver..post back
Apr 09, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
I replaced the spray arm seal, but the arm still wont spin. I get water but not enough pressure to turn the top arm. The bottom arm works fine. Should the top arm turn easily when pushed by hand. It...
arms should turn freely. spray arms are only rotated by water spraying out from angled jets at end. check for blockage in spray arms - sweet corn and rice are the worst offenders. take spray arms off and run water in centre hole and see it runs out of all the jets freely
Apr 08, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Dishwashers Logo
161 people viewed this question
Top Dishwashers Experts
