Question about iLO 3200 32 in. LCD Television
How do i get the close caption of my ILO tv if i do not have the remote control?
  • iLO Master
  • 8,457 Answers
Goto to the tv manual control buttons right side of the LCD panel used the Menu button find the functions captioning turn all CC1,2,3 and text 1,2,3 off.Will not getting anymore captioning.
Posted on Sep 13, 2010
Need Closed Captioning
If you have the original remote control, there will be a button marked "CC", and pressing it once, the closed caption funciton will turn OFF, and for an other press, it will re-appear. Now, here you are using a universal remote control. So it will be difficult to make closed caption. Try to enter its function menu by using present remote control, where you can make this funicion OFF, if you could enter into it.
Jun 02, 2013 | Insignia NS-RTV32 32" TV
How to turn off closed caption
Closed captioning is an option usually selected during initial setup of a TV. If you turn off the TV speakers, there is a pause and closed captions begin. To change this, go back to te TV setup procedure and deselect CC
Dec 13, 2012 | Akai New Original KC01A1 Remote Control
My 32 in. ilo sdtv won't stop with the
Download the user manual to your ilo TV. For it with its exact model number. Refer the manual for details.
Jun 07, 2012 | Televison & Video
How do i turn off the closed caption - thanks
Ur tv remote have a button CC on the remote.Push that CC button turn off all CC1,2,3 to off.Ur tv captioning will be off.
May 31, 2010 | iLO 3200 32 in. LCD Television
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
Big black rectangle in the middle of the TV
sounds like an advanced closed caption service is on. go to menu then audio then closed caption and turn off closed caption.
Jun 23, 2009 | iLO 3200 32 in. LCD Television
Closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
Mar 28, 2009 | One For All URC-4330 Remote Control
Black box
Make sure your closed-captioning is turned off. This box appears when you have captioning set for "text" mode and the set is on a channel where captions are being broadcast. The TV blanks the part of the screen where the text would go, but there isn't any to display. Some TV's have a single button on the remote to turn captioning on, and it's easy to set the TV for captioning without knowing it.
Dec 18, 2008 | iLO Televison & Video
Cant get rid of captions
look on top and behind of the monitor you will find buttons for your TV then follow this steps: The Setup menu lets you configure the TV to fit its surroundings and your preferences. To access the Setup menu, press MENU, and then select Setup from the Main Menu.closed caption options are: CC Setting Lets you choose the way closed captioning information appears on the screen. Off No captioning information displayed. On Always Captioning information shown always, when available. On When Muted Displays captioning information, when available, whenever the TV?s sound is muted by pressing the MUTE button. The captioning information is not displayed when the sound is not muted. Make sure all of the options for closed caption are off press exit and you are good to go.
Aug 23, 2007 | iLO 3200 32 in. LCD Television
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
iLO 3200 32 in. LCD Television Logo
119 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
