Question about Dell OptiPlex GX520 PC Desktop
Hi, when i power on it shows in brown color, (blink in brown) nothing dispalys, i changed ps, memory, processor. but didn work out
    Scholar:
  • 181 Answers
The only thing that's left is your motherboard. The usual culprit in a black out mode is the power supply and the motherboard. Try using a certified good motherboard. Try also to check on the display card. Also, check for compatibility of the power supply, the motherboard, the processor, display card and the memory
Posted on Sep 13, 2010
. I WAS LOADING A FRESH LOAD OF WIN-7 AND IT JUST TURNED OFF AND WILL NOT TURN ON AGAIN
I would remove the main battery first and try powering up the computer, next! sub out the ram memory one at a time and test as you go to see if you can restart it, next! disconnect all power including battery, press and hold power for 2 minutes to reset the processor, if none of these work you will need someone to assess the motherboard for repair or possible replacement.
Apr 19, 2012 | Gateway NV59C56u 156Inch Notebook Satin...
P5GD2 one post beep
Check the processor's heat sink fan. Make sure it's spinning. Blow out any dust or vacuum (w/ no power to the tower.) Reseat the memory. Try with one memory stick if you have two, resassuring to put in slot 1. Sometimes two different types of memory act weird together. Make sure memory is compatible. (ex. PC2100...)
Jan 01, 2012 | ASUS P5GD2 Premium (P5GD2PREMIUMWLOM)...
My monitor worked yesterday. I rebooted and the lower right power light started to blink. Looks like it is going to boot up, but the it starts blinking the word "ANALOG" + " DIGITAL",...
First check the processor fan is working if working remove the memory from the slot clean with a clean cloth and rub the conector with a erasor dont use any metel or any other thing insert the memory and see if the lock is locked on to memory properly still not working change the memory sutable for the memory slot still not working removce the processor heatsink and the processor clean the surface and apply athin layer of heat sink compound and fix back the processor if still not working change the processor if still not working use an addon graphics card and check for display
Oct 27, 2011 | Computers & Internet
My hp 7060n won't pwr on. I checked the ps it test
I don't think you know what you are doing. No computer will boot without memory! And no mo bo will work without the 4 pin connector being attached to mo bo along with the 20/24 pin mo bo connector..
Listen, keep it simple and just plug in another known working ps to see if unit works. If it still does not work, then your issue could be corrupt bios, bad hard drive, corrupt OS, bogus peripheral, bad memory.
Sep 16, 2017 | Computers & Internet
I have a foxconn mobo model g31mv and has a problem with the video, well it shows nothing at all. Ive changed the memory, power supply, jumped the bios and check all the wiring and nothing. So.. what...
Try this motherboard troubleshooting beeping code first.
No beeping means short circuit,loose parts.
One beep means everything is working good.
Two beeps means CMOS error.
One long beeps,two short beeps means video problem
Three long beeps means keyboard error.
Continuous long beeps means memory not detected.
Continuous Hi-Lo beeps means processor overheat,loose blower fan heat sink.
If no beeps need to change capacitor parts of motherboard for burn, short and open leakage.
Jul 16, 2011 | Foxconn G31MV-K Motherboard
My aiwa tv-- A219 is showing message AGING 19DCH in red color and nothing else except dispaly button is working.pls help me
my aiwa tv-- A219 is showing message AGING 2F01H in red color and nothing else except dispaly button is working.pls help me
Nov 11, 2010 | Aiwa F2000 20" TV
Foxconn A74MX motherboard will not pick up my PCIe Graphics card
disconnect everything except the power supply, the power on switch, one stick of memory and the graphic card (if you don't have onboard adapter), turn it on and see what happens.
Mar 28, 2009 | Foxconn Computers & Internet
My pc dont start
The problem identified that your system wont start. By solving, let begin from the very the very start. 1. be sure that power supply function well. u can test PS by changing temporary identified functional PS. if u sure that PS is good then, examine processor. remove memory. switch on system w/out memory if hear beeping. u are sure that processor is working.if not then something wrong with your processor. if beefing then insert memory. if not solve, examine memory clean it very well. and insert. if same problem replace memory. notify me if more problem identified. we will continue.....
Dec 14, 2007 | Systemax Venture PC Desktop
Dell dimension 4600C Power up issue
This might be a problem with your motherboard or processor or both of them.
Oct 11, 2007 | Computers & Internet
Dell OptiPlex GX520 PC Desktop Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
