Question about Home
My whirlpool Bath Pump TDA150 has stopped working. is there a way to restart or is there anything I can do to fix it. Thanks Kathy
  • Kathy Burns Aug 02, 2012
    Its an outside spa that's Hard wired
  • 707 Answers
It should be ran through a GFI plug like your bathroom plugs with a built in reset button...Hope this helps.
Posted on Sep 14, 2010
    Its an outdoor spa that's hardwired
I have a HydroAir Magna Series Whirlpool pump model #LD7AC that will not shut off with the airswitch. The airswitch does not appear to be disconnected nor does the tubing appear to be clogged. Any...
If your bath pump LD7A-C will not shut off when you push the air button then the AIR SWITCH in the motor needs to be replaced.
This is a pretty common problem with Bath Pumps and easily fixed.
Rod
US Parts Center
888-521-6183
Mar 18, 2013 | Home
Hydroair magna series whirlpool pump model #LD7AC airswitch does not work. It appears to be connected properly and not blocked. Any suggestions?
If your Bath Pump will not shut off when you push the Air Button, it sounds as if the Air Switch is not working in your Bath Pump.
Click on the Air Switch name and it will show you the replacement part you need to fix the Bath Pump.
Rod
US Parts Center
888-521-6183
Mar 18, 2013 | Balboa HydroAir Magna Series Spa Eyeball...
How to start the jets on an MTI FURO MTDS 59
Checking the circuit breaker for power to the pump is obvious however the control that turns the bath pump on/off may be the real problem.
MTI has what control box to operate the pump?
Check there first because that may be the problem before the bath pump is a problem.
We would need to know the model number of the bath pump and the control box if there is one that the bath pump plugs into.
Rod
US Parts Center
888-521-6183
Mar 11, 2013 | MTI Furo MTDS-59 AST59
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
The air switch on my whirlpool tub will not toggle, i must hold the button in to keep motor running.
What you are experiencing when you push the Air Button down and it engages the BATH PUMP but when you release the the Air Button is a bad Air Switch in the BATH PUMP.
When you push the air button down it sends a column of air to move a small switch in the BATH PUMP. When the switch in the BATH PUMP is bad it will not engage.
What you need is a new Air Switch model TBS-339.
Rod
US Parts Center
888-521-6183
Feb 28, 2013 | Home
Have bought hudson reed topaz wall mounted bath taps, where do I get the t piece manifold that attaches to the bath support. Have rang help line and they do not hold the part, have been to a local plumb...
Hi Paul
You would be able to buy the part from screw fix please follow link below:
http://www.screwfix.com/p/conex-female-branch-reduced-tee-617-22-x-22-x/47241
Thanks
Sanctuary Bathrooms
Aug 25, 2011 | Home
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after...
Anyone got an answer to this, as I have exactly the same fault.
Dishwasher appears to switch on OK, then after a short time (20 secs?) the pump noise stops and the green light flashes - it seems to e a sequence of 7 flashes, then stop... 7 flashed then stop.
The sequence could indicate a fault detected?
Anyone know anything about these units from IKEA, made by Whirlpool?
Thanks!
S
Feb 12, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
2748.328 Town Square 5' x 42" Air Bath Tub Won't Work
Air bath tubs have a preset time limit. it could be that it reached that limit. Especially if the lights are still lit up on the control.
Dec 29, 2008 | American Standard 2748.328 Town Square 5'...
Home Logo
93 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
