When booting up, press the key that allows you to enter the BIOS. The first thing you need to do is verify that you have the most current BIOS driver. After that, make your way through the menu system until you find the memory page. Verify that your system is recognizing the new memory module. If it is, it will show it and what slot it is located in. If not, the memory may not be compatable with your PC. Double check your documentation and the many web sites that tell you what memory your motherboard requires. If that doesn't work, then you may have to replace your motherboard if it wont function with either the new memory or old memory modules. ..Good Luck!
Place the largest RAM closest cpu
hope this helps
etre
Thnx for the Reply......
i Tried as wot u said put the 1gb ram close to the processor and followed by 512mb. But the Single Beep Sound is still there... is dere any problm in using differnt manufacturers memmory.. my 1GB ddr1 ram is Transcend, and 512mb is Kingston.
i hav installed CPU-Z to check the Details of my memory and in the SPD tab under 1GB ddr 1 its showing
Timing Table
JEDEC #1 JEDEC #2
Frequency 166MHz 200Mhz
CAS# Latency 2.5 3.0
RAS# to CAS# 3 3
RAS#Precharge 3 3
tRas 7 8
and under 512 DDR1, its showing.
Timing Table
JEDEC #1 JEDEC #2 JEDEC#3
Frequency 133MHz 166MHz 200Mhz
CAS# Latency 2.0 2.5 3.0
RAS# to CAS# 2 3 3
RAS#Precharge 2 3 3
tRas 6 7 8
some motherboards dont work with two different types/brands of RAM i think this maybe your problem
Timing Table
JEDEC #1 JEDEC #2
RAS# to CAS# 3 3
RAS#Precharge 3 3
tRas 7 8
Timing Table
RAS# to CAS# 2 3 3
RAS#Precharge 2 3 3
tRas 6 7 8
