Question about Canon PIXMA iP3000 InkJet Photo Printer
My printer was printing fine all day and all of a sudden it stopped. I cleaned it many times and did several deep cleanings. It faintly printed but that's all.
    Genius:
  • 1,044 Answers
Quite possible that with all day use the ink in the cartridge is finished. Check that aspect.
Posted on Sep 13, 2010
Printer not printing very faint
Clean or deep clean the black printhead. Go to 'printer properties' then 'maintenance' and click the appropriate button.
Feb 22, 2015 | Canon Pixma MP450 All-In-One InkJet...
Pro901 stopped printing in color
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Nov 16, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
My Lexmark prevail pro 705 has stopped printing anything colour even after i have replaced all the cartridges??
This article on How to Troubleshoot the Vizix Ink Technology will help fix print quality problems on your printer. To run the Deep Clean Printhead function on your printer -> on the printer operator panel, press Setup -> Maintenance -> select Deep Clean Printhead. Your printer will then print the test page. Hope this helps. Thanks.
Jan 11, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
Changed the print head in my Canon MP760 but now printing is blurred and very faint
Try cleaning the felt pads where the print head would rest when not printing. They get full of ink and cause more printing problems. I use water to clean them.Don't loose them, they are needed to keep the print head from drying out.
May 31, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
Very Faint Printouts
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
Rgs
The StickMan
Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
HP 7110 still won't print in color
Your post "...it prints very faint horizontal lines in color..." is indicative that indeed your color printheads are clogged and would need repetitive deep head cleaning. This is of course would require that you keep on cleaning until such time as the faint color lines have turned to legible print.
Apr 08, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Canon PIXMA iP3000 InkJet Photo Printer Logo
29 people viewed this question
old marine
old marine
