Question about SanDisk Sansa e250 MP3 Player
Computer doesn't recognize unit when connected
I know that it is not the connection on the unit, nor the usb port. USB port works fine, and the connection on the unit also works fine as the charger too. I bought a new data link cable thinking that it was the cable, not the case. Computer doesn't recognize unit anymore when connected. Was doing so for months, then it stopped. Please help! When i plug in the given USB cable it registers then disappears, disabling the mp3 player.
  • 2 more comments
  • Anonymous May 17, 2008
    my sansa e250 keeps shutting down when i plug it in with my usb cable
  • Fade_It May 17, 2008
    This might help! Very simple fix.
    - Turn the player on
    - Spin your dial to unit you get to "Settings" on you Sansa
    - Look for "USB Modes"
    - Should be 2 choices
    - Change it opposite that it set on.
    Done!
    I worked for me. SmoothFade!
  • Anonymous Jun 17, 2008
    i lost the computer software which would help me switch music from the computer to the sansa so it can not be read by the computer since i got a new PC.it also got attacked by a virus known as RAILA ODINGA which made restart by itself and the music stopped playing.so what should i do?
  • rahulvrk04 Aug 11, 2008
    i am unable to connect my player with computer. it is saying that mtp device cant install
    Problem Solver:
  • 10 Answers
Get the recovery tool from Sandisk Support downloads. Put it in a file you can easily find.
plug in the Sansa, once it turns on, hold the power button until it turns off then switch the hold switch at the top edge of the player to hold (showing orange) and then hold the "Record" button on the side until the player turns on with a black screen, saying it is in recovery mode.
Some people have said they had to hold both "Power" and "Record" to make it work.
Run the recovery tool software and you should be running again.
Posted on Jun 18, 2008
I have the same problem and it says that the device cannot start (code 10) when i look at the MTP devices listed.
Posted on Jun 17, 2008
  • 3 Answers
Right Click on "My Computer" (if Windows XP) and click on Properties/Hardware tab/ then click on Device Manager/ Scroll down to see if you see "Windows Portable Device(s)" and expand it to see if you have an MTP device listed you may click on proterties to see if it says"device working properly"; if so, update the Driver by clicking on Driver Tab and the button "update driver' (note: you can always roll back the driver). If no MTP device listed then, right click any of the items listed in the device manager window and click on "scan for hardware changes" to see if it can find it. Let me know if it solved the problem -- as we may just need to do a hard reset.
Posted on May 16, 2008
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Unable to download pictures
I do know that sometimes a usb port will fail, for whatever reason, to recognize a device. It's happened to me before, and you can try a couple things. First, unplug and plug the usb port back in while it's connected to the camera. If the computer fails to recognize it, try you different usb ports, and the computer may respond. Aside from that, if you're running the XP or later versions of windows, you might try restoring your computer to a time before this problem occurred. Also, an update to Windows could have adversely caused this to happen, and restoring to an earlier date would hopefully reset the usb software's ability to recognize the port. Perhaps someone else will have suggestions if none of these things work, but that's the limit of my dealings with this problem. There's always the possibility that a hardware issue is at work here, but I hope not. If you do discover the port is bad, you can always get a hub and deal with it that way, leaving it connected to a known, good usb port. Just make sure you get a hub that is aided by a power source to relieve the computer from the burdon of powering up the hub. Good luck.
Apr 03, 2010 | Canon Cameras
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
My adaptor is not recognized in my USB ports I installed the router and it completes all of its connection checks. I am trying to install the adaptor on a remote computer (in the basement) and that...
Here's what you can do since this is a USB wireless adapter, first connect the USB adapter on a different USB port on the computer better if you connect it on the back USB port of the computer tower and check if the computer will recognize it and if its recognize you can already continue with the software installation , but if not you can restart first the computer and check if the adapter will be recognized if still not the next thing to do here just to know if the adapter is good or bad is to connect it on a different computer and just to check if it will be recognized once its connected to a USB port , because a device should be automatically will be recognized by a computer once you connect it so if its still not recognized by a different computer adapter is bad...
Dec 15, 2009 | Computers & Internet
Canon hv30 is't being recognized on my vista computer
You may have used a different USB port on the computer. Try a different one.
Generally, any USB port would work, except that some devices create a "Virtual USB" connection that is configured with a specific USB port.
Let us know if this helped...
Gort007
Sep 16, 2009 | Canon VIXIA HV30 DV Camcorder
Hi, I have an external disk connected to an usb port. Sometimes my computer stop to recognize the connection and my external disk doesn´t works anymore, until the next reboot. What can I do to resolve...
The only other solution other than rebooting is to remove the cable from the usb port and reinsert it. Sometimes the computer will recognize the drive and it will work properly.
Aug 13, 2009 | Microsoft Windows XP Professional SP3 Full...
USB DEvice not recognized
I had a problem like this -- tried plugging the camera in to the rear USB slots not the front ones and it worked fine.
I think that it doesn't like going via a USB hub, but wants a direct connection. All of the USB ports on my computer are connected direct to the motherboard (i.e. none are on PCI cards or anything), but looking at the hardware info for the computer, it looks like the motherboard has a few "direct" USB connections, and then an on-board hub which the front ports connect to. If your computers are the same, that would explain things. I'd suggest trying each USB port one at a time (turn the camera off before plugging in, and back on when in) and see if one of them works. Wouldn't hurt to power the camera from the mains at the time too.
Jan 01, 2009 | Video Cameras
Computer doesn't recognize scanner
maybe the cabel is broken, what type of cabel do you use for connecting to pc? if usb try to change the usb port, if this doesn"t work change the cabel. btw the scanner has to be started.
Dec 15, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Bad USB conection?
it's not likely the cable went bad.  Do you have more than one USB port you can try? do you have other USB devices to test the port? did you reboot?
Oct 12, 2007 | Pentax *ist DL Digital Camera
Hi All,
I had the same problem and was going crazy trying to figure this out, but I found that I had installed the GPX mw3816 on my bottom USB port and was trying to plug it into the port above it, because I had plugged another unit into the bottom port, but I switched the ports and it immediately installed. This is another reason, I am thinking of dumping windows and moving to a MAC. Peace!
Aug 13, 2007 | Samsung YP-T8 Digital Media Player
SanDisk Sansa e250 MP3 Player Logo
101 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
