Question about GE (PSS26MSRSS) Side by Side Refrigerator
Hello there, I have a GE model GSH 25 JF side by side fridge. I believe it's a 2005 model. The Freezer and Fridge are running, but neiher is cool at all. There is a clicking noise happening about every second and when it clicks, the light goes dim. I went to the back of the fridge and it is coming from a (looks like a mother board) behind a metal panel. The fridge has been in the garage and it does get 120 plus degrees in my garage in the summer. Thanks, Gary
  • boerboy Sep 14, 2010
    Thanks for the reply. I will check it out and see if that's what it is.
    Scholar:
  • 142 Answers
There is a box welded to the side of the compressor. If you pry off the cover you will see two parts. The top part is called the overload; this is the one doing the clicking. Underneath the overload is the relay which is the part that temporarily energyzes the "start winding" long enough to get the compressor going. Ovbiously the relay is old and fails to energize the start winding; that in turn causes the "overload" to cut off the power (click) because it got hot. Then when it cools off it sends power back to the relay and tries again (click). What you need is a new relay. It is of course possible that the compressor is "stuck" which would cause the same clicking sound, but I am willing to bet that a new relay will get you going again. By the way, both parts are easily pulled off the compressor; first the relay (you can leave the overload) and then push on the new relay. The replacement relay might have more terminals than the original; be sure you connect the wire(s) at the same LOCATION.
Posted on Oct 21, 2011
    Problem Solver:
  • 9 Answers
Sounds like you have a starter problem. There is a part on the compressor used to start up. It should be if I remember correctly a capacitor near or on the motor. When the light dims it is trying to start up but failing.
Posted on Sep 13, 2010
Hello, the refrigerator side is not cooling, but the freezer is working perfectly. Our fridge is 26 cu instead of 25.6
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
I have an older side by side GE refridgerator model number TFXC222J. The freezer section is working but the fridge side is not cooling. light works.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | GE Refrigerators
Top shelf of freezer and ice maker not cold and top shelf of fridge not cold. everything else on bottom shelves is frozen and cold .GE model GSS22JEMA
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 17, 2010 | GE GSS22JEM Side by Side Refrigerator
Freezer woorking ok fridge not cold model GSS20DBPC WW
heatman101
Aug 23, 2010 | GE GSS20DBPWW / GSS20DBPCC Side by Side...
Frig side does not cool. freezer side cools
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 16, 2010 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
GE fridge and freezer cools when it wants to - freezer on top
hard to say, there is many questions left that need answered...does the compressor run, does the fans run? what more could you tell me.... whirlpoolpartssurplus.com free tech support
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side fridge not cooling enough Freezer side was still
check see if you have frost build up in the freezer back wall you may have defrost problem
Apr 06, 2009 | GE Refrigerators
GE Side By Side top portion of fridge and freezer not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
396 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
