Question about Acoustic Research 208 HO Speaker
WHERE CAN I GET MORE INFORMATION ABOUT AR 208 HO SPEAKERS IE, POWER ETC
My boston hps12 ho subwoofer blows fuse. what could be wrong
Fuses blow when there is an overload. The most likely cause is a short-circuited semi-conductor IE: a transistor or IC etc. If you find one of these devices inside it with a heat sink on it, that will be the most likely cause. Transistors can be tested with an Ohm Meter and in a short circuit fault such as this, it will be like you have put the two test probes together!
Dec 06, 2015 | Boston Acoustics Audio Players & Recorders
I cannot connect the usb to my lap top it does not recognize it
u menia Sony DCR-DVD101E DVD-?²?¸?´?µ?¾???°?¼?µ???° ho moi kompiuter\toshiba satellite a200 windnows vista/ne chitaet disk etogo camcodera.i ne mogu instalirovat driver sony usb CD-R/RW diskoveda please help me
Feb 14, 2011 | Sony DCR-DVD101E DVD Camcorder
Just got two AR 312 HO speakers from my brother. I have a Yamaha HTR 6250. The speakers have (2) sets of cable hook up. One I assume is for built in sub woofers? Do I hook one normal and one to the sub...
do not use those speakers with that amp, those are 4 ohm speakers, which could damage your 8 ohm yamaha amp. you will have to get a 4 ohm capable amp to run the highs, and another 4 ohm amp to run the subs.
car amplifiers are currently 4 ohm, or even 2/1 ohm stable, but few, if any modern receivers can run at anything lower than 8 ohms without a danger of overheating. you may have to get a vintage amp(s), like a 1970's marantz receiver, or a 1980's to early 1990's kenwood power amp, because 4 ohm home amps are pretty scarce nowadays.
whatever amp(s)( you get, verify that they are DEFINITELY 4 ohm stable.
Nov 06, 2010 | Acoustic Research 312 HO Speaker
Ð?еб камеÑ?а Microsoft VX-7000...
Copy the Microsoft Web site and paste it in your web browser address bar and hit ENTER.
http://www.microsoft.com/hardware/download/download.aspx?category=ICEbd
then select the necessary items as listed below, such as
1. Select type of product. (Web cam)
2. Select your product (camera model).
3. Select your operating system. (XP, Vista etc.)
4. Select your operating system langusge. (United States English)
Then to use it on the Web, do this.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
Oct 05, 2010 | Microsoft LIFECAM VX-7000 Webcam
мой дÑ?Ñ?г дал мне свой Nokia 5200,...
Can you please give information of the question posted in English? Doing this will make me have good understanding of the problem and i will be able to proffer solution to the problem.
Thank you.
Aug 24, 2010 | Nokia 5200 Cellular Phone
How do I get our sharp AR-M208N to work with windows 7?
go to www.sharp.ca
Select Service Support > Downloads and slect Photocopiers. This machine is listed as an AR 208. Click on DONE and the drivers will be presented. Scroll to the PCL English version and download from there.
Jul 13, 2010 | Sharp AR-M208N Copier
AR -208 N Needs starter and drum replaced. Need
For given repair will take:
Fotobaraban AR-202DM.
Pliers
The Vacuum cleaner for peelings of the node removable unit containing and corona.
To take the block of the drum out of copier it is necessary,disconnect feeding,open shift to the right lid,on she is found corona carrying,open the front lid,take out the toner-cartrige,take out the block with developer and finally take out block itself with drum.
The Bonanza block before itself.With pliers we roll the dowel,which keeps the drum and take out him(it).
We Remove drum.
The Vacuum cleaner net corona and removable unit containing .
We Put new фотобарабан,insert and twist the dowel.
We Insert the block of the drum on place,then block with developer and toner-cartrige.We Close shift to the right door,include the device.
May 09, 2009 | Sharp Office Equipment & Supplies
231 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
