Question about Car Audio & Video
Hello, My cdx gt250s is showing reset when i select to play from cd. Other things are working absolutely fine. I tried resetting that din work. When i insert the disc, its not taking in. instead it pushes it out. Please kindly guide me at the earliest. Prem
  • 13 Answers
SOURCE: SAMSUNG SV-DVD440 Combo
how old is the player, it sounds like the lazer has gone down if it reads cds and not dvds
Posted on Feb 10, 2008
hogan doan
  • 227 Answers
SOURCE: My AVIC 9 sat nav
Assuming you have the original navi disc, then your laser eye is either dirty or tired(out of alightment) from playing mp3 or copied disc. Buy a cd lens cleaner kit if that doesn't help then have someone who know how and have it re-align. Goodluck.
Posted on Apr 24, 2008
jerree_carde
  • 3 Answers
SOURCE: I am using sony cdx-r6550
try reseting your radio. Disconnect it completely (power)
Posted on Jul 25, 2008
SOURCE: i have a sony cdx-gt22w
iit the cir
Posted on Aug 12, 2008
thefazool
  • 3 Answers
SOURCE: No sound from cd or aux on CDX-GT32W
Just connect together the solid blue wire on the main harness to the radio with the blue/striped wire. The blue wire is for the power antenna and the blue striped is for the remote amp. but if not connected together only the fm/am has outputs to the line output RCA jacks. I learned this through Sony's tech line and it works perfectly now.
Posted on Dec 15, 2008
Sony CDX-GT210 Can't find the reset button. Radio plays fine, but No sound comes out when I use CD player. Panel displays that it is able to read disk (numbers for time played goes up and displays...
Usually Reset button located underneath front panel, remove front panel and look at unit, hopefully you will see reset button, press it with some pointed thing like paper clip etc to reset the unit.
Thanks.
Aug 11, 2011 | Sony CDX-GT210 CD Player
Hi I have an older disc changer it is a cdx-64rf i turned it on and it said reset so i did so, then it was working, it was showing that the songs were playing but only the radio was coming through the...
when you reset it, it reset to the factory default tuning frequency, find it by pressing seek several times while a cd is playing until you hear your disc. save that station.
May 18, 2010 | Sony CDX-656 10-Disc CD Changer
CD RESET
to fix this problem you have to take the face plate off. There should be a small button on the middle-left side that sais "reset" on it. Get a ballpoint pen and press this button. Pop the face plate back on and play your CD and it should work no problem.
Jan 16, 2009 | Sony XPLOD CDX-GT200 CD Player
Xplode cdx-gt460u CD Reset Error
REMOVE THE FACE PLATE THERE SHOULD BE A RESET BUTTON ON THE FRONT OF THE RADIO PUSH THAT AND TRY AGAIN IF THAT DOESNT WORK THEN PULL THE RADIO AND DISCONNECT FROM POWER 4 A LIL BIT AND THAT MAY WORK
Dec 29, 2008 | Sony XPLOD CDX-GT200 CD Player
Sony cdx-t69 CD Changer Unit
hi there that is sorta the problem i had and if you press eject nothing happens its still in there what i done was disconnect the battery for at least one minute and the cd changer lost its memory and was fine so i ejected the cd magazine and cleaned all the cds and blew out inside the machine has worked everytime its woth a try
Jul 01, 2008 | Sony CDX-T69 6-Disc CD Changer
Numark CDX CD Turntable
HERE YA GO!! GOOD OLD FASHIONED BEATING FIXED MINE... I PROMISE THIS. When you turn on your CDX... HIT THE SQUARE AREA where the play button and the cue buttons are located. It will jump to CDX on the screen and work fine. Mine did this and i messed around with bumping it and stuff and figured this out
Apr 25, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Sony CDX-L480X
I had the same problem, CD not accepted by unit and pressing source button to select CD player causes unit to display reset.
Using reset button just causes unit to 'whir' for a while, problem is not solved. Firstly with unit switched off, and the ignition off I inserted a CD using some gentle force, I then inserted a second CD, forcing it in over the top of the first. Next I pressed and held the reset button for a short time before releasing it. Both CDs were ejected, when the unit had stopped I took the CDs out, replaced the front panel and turned on the ignition, The unit will now accept CDs and eject them O.K.
(This did take two attempts to get right). Seems to reset the eject status of the CD player.
Avulon
Feb 17, 2008 | Sony CDX-L480X CD Player
CD won't work
Have you tried using the reset button on the front of the unit (under the face panel)
Jan 13, 2008 | Sony CDX-L400X CD Player
Cd Player Lights Up No Music Coming Out Of Speakers
try resetting it, open faceplate, with pen tip ,press reset button
Sep 08, 2007 | Sony CDX-C5000X
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
