Question about HP Officejet Pro L7580 All-In-One InkJet Printer
How 2 solve the problem of out of paper? - HP Officejet Pro L7580 All-In-One InkJet Printer
    Sergeant:
    Champion:
  • 251 Answers
Put some paper in.
Posted on Sep 13, 2010
Paperstuckup
Turn the printer off and on.This automatically pushes out the stuck paper.Solved?
Open cover to gain access to the paper path and pull it out firmly but with care.
Check through the paper paths for any other obstructions.
Avoid filling the paper feed tray to capacity.Solved?
Disconnect from power and connect again.Turn it on.
Hope it helps.Thanks!
Jan 01, 2012 | Samsung Office Equipment & Supplies
My printer is not taking the paper correct
  1. first, look in the paper feed section, where you load the paper , is there any foreing body that stop or balance the paper, if yes remove it carefully.
  2. the paper pickup roller must be cleaned, to work properly.
  3. if your problem still not solved you must replace the paper pickup roller and the separation pad.
i hope that help you to solve the problem, if you need more help, you can live a comment now.
Dec 06, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Paper feeds fine from the manual tray but the main tray (the bottom) I continuously get a paper jam. It begins to feed then jams. Anything I can do to fix this?
Dear,
No problem.I can solve your problem.There are printer has two paper feed system 1) manual feed2) on cassate.When you get a paper jam in cassate you clean paper clauth or cassate feed roller clean.Some times is missfed because it can not creat frashor in correct.Clean it then solve you problem.Or some of paper bit here.
Dec 09, 2009 | HP LaserJet 1320n Printer
Have a BROTHER HL2140. Paper jam: Can't remove drum unit & toner cartridge: Help
Solved by opening the front and removed paper: not required to remove cartridge. Info on Problems with Printers. Thank You
Nov 08, 2009 | Brother HL 2140 Laser Printer
C0920
c0920 is the 1st paper drawer motor.
since the paper jammed the motor path, so the paper deck cannot come up, just pick up the paper n re insert the paper deck..problem solved..
Jan 19, 2009 | Konica Minolta DiALTA Di200 Copier
Error Message Out of paper
Contact hp. They have a small item (roller clelaner) that you insert it into the printer as if it were paper and it seems to clean up your rollers. It takes about 15 minutes and it works. I also had the same problem and this solved the issue.
Apr 16, 2008 | HP Photosmart 3210 All-In-One InkJet...
Paper loading
Make sure that there is no pieces of paper jambed around the wheels that pull the paper into the printer. Also that the back panel is fully locked into place.
Dec 20, 2007 | HP PSC 1610 All-In-One InkJet Printer
Fax does not know paper is loaded. says load paper
When you load your paper, you must press the Stop/Reset button for it to reconize you have loaded paper.
Nov 17, 2007 | Canon FAXPHONE L80 Laser
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
