Question about Sony FWD-50PX2 50 in. Plasma Television
My Sony Flat Panel Display FWD-50PX2A : When I plug in my Sony the green light goes on a ticking noise appear and after a couple of seconds the red light goes on - neither the remote or manual buttons turns in back on again. Must confess - I tried to plug in speakers on the unit itself (not switching it off) and this is when it started - kept switching off - was able to switch in on again but eventually nothing. Any ideas? Need to fix it but not sure if Technicians will be honest enough to give you the correct advise and charges? Thanks
  • Sony Master
  • 8,457 Answers
Unplug,replug tv back in an hour later.Tv now reset it self back to factory setting.Now it should work.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Sep 13, 2010
Snx 32gt1 internet tv wont come on
Probably a failing power supply
Jan 14, 2017 | Sony Televison & Video
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
Sony FWD 42PV1 LED shows green light when powered on and switches to red after few seconds without showing anything on the display.
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your Tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care.....
Aug 11, 2010 | Sony Televison & Video
Hi I have a Sony FWD 42PV1 Plasma. It has just stopped working. The LED shows green light when powered on and switches to red after few seconds without showing anything on the display. I have checked the...
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care.....
Aug 11, 2010 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
TV wont turn on
my TV does the same thing except it is a Sony
KDF-50WE655
Jan 16, 2009 | Polaroid FLM-3225 32 in. LCD Television
Sony Plasma TV.
I have the same problem. since I have 3 of these TV's, I switched boards around, and I came to the conclution that is the power board. I will try to repair it, and I'll let you know the component that is bad. Gaston
Dec 28, 2008 | Sony FWD-50PX2 50 in. Plasma Television
Staying on standby
Check P611 in power supply. Its a 1.5a 60v pico fuse (yellowish in color). Also disconnect
plugs when in order not to get false reading when checking other components
Mar 29, 2008 | Sony DVP-CX850D DVD Player
Sony FWD-42PV1 -
I diagnosed the same problem on my FWD-42pv1 as a problem on the Y-SUS board. The fuse on that board was blown, and the board itself was bad (replacing the fuse was not enough to fix it). The symptoms were exactly the same - the LED cycling red/green, and then finally stuck at red.
With a new Y-SUS board, the TV has been working fine for a couple months.
Jan 26, 2008 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Sony Plasma 42 fwd-42pv1 interference / spots
thats a defective light engine..............new tv buddy..............its a known sony problem..........dont listen to thier b.s.
Dec 18, 2007 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Sony FWD-50PX2 50 in. Plasma Television Logo
185 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
