Question about Toshiba 1370 Black and White Copier
THE COPIES COME OUT ALL SMUDGED WITH INK WHAT'S WRONG.
OK WHEN I MAKE COPIES THEY COME OUT ALL SMUDGED WITH INK. I HAVE TRIED CLEANING EVERYTHING PER MANUAL. BUT NOTHING WORKS WHAT DO I DO...
  • buckmanjohn May 15, 2008
    where is and what is "the fuser"...my copier has one inch wide bands across the copy, where it is smudged and nearly blank, these are about 5 inches apart? any ideas? i hate to toss the copier, because it has always worked well in the past. thanks in advance..
  • Anonymous Dec 29, 2008
    our copier has like a wavy shadow, one person told me we may need a new roller... any ideas on that?
  • 34 Answers
Hello
in your printer fuser has went bad, just replace toner if its almost empy and fuser and that will take care of it.
Thankyou
Posted on May 15, 2008
Hello! Copies are very poor. New ink. Copies
Try to align the cartridges again...
Steps to align : press the setup button.. > go to tools > align cart and clean cart
Oct 19, 2009 | HP Officejet J5780 All-In-One InkJet...
Smudges on copies
You may want to try the series of steps required for "cleaning" the inside of the printer. Usually there are a combination of reset buttons that are used to clean a printer and it could take about 10 minutes. The Canon website usually has which combination of buttons will do that.
Sep 15, 2009 | Canon imageCLASS D320 Digital Copier
My printer wont print even after changing ink and cleaning
When cleaning doesn't help, you need a new printhead. Around $89.00 now and then you add labor. They sell a new MFC 490 for around $120.00 with a year warranty.
Jul 01, 2009 | Brother MFC-3240C All-In-One InkJet...
Canonimageclass D320 makes smudged copies. What do I do?
This model is noted for a jam in the fuser area around the roller, Not easy to get to but sounds a like that may be proble, Can you hear a sound like paper wrinking as it runs. Also is the drum in the cartridge clean or has tone on it. Have you changed the cartridge. I do get a kick out of Staples Experts.. They did sell you some cleaning sheets... Hey Good Luck....
Apr 23, 2009 | Canon imageCLASS D320 Digital Copier
New ink cartrage
Print Nozzle Check Pattern
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Note:
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Note:
    Do not do any other operations until print head deep cleaning is completed.
    Note:
    Ifthe printed result does not improve even after doing print head deepcleaning, turn off the printer. Then, after 24 hours or later, do printhead deep cleaning again. (After a given time interval, ink coulddissolve itself, resulting in ink unclogging.
Jan 08, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Epson Stylus CX5000 blurry or smudged printing
epson uses pigmented ink and compatibles use dyes and thus if the paper is not of good quality then you can have this problem.
do the following
change the paper and try.
As there will be ink in the head and the ink feed tubes , print some 10 -15 copies of all color prints so that the original ink starts to get into the head and then the paper.
this should solve your problem
Also use your printer every 2 -3 days if you dont have any prints then give a noozle check and then switch off the printer. This will avoid the printer from doing a head clean very time you switch on the printer and also the ink will give you more output as there is less amount of head cleaning
bye
Aug 09, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Blurry Scanning/Copying
Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
Jul 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Toshiba 1370 Black and White Copier Logo
286 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
CheckitRight
CheckitRight
pkwc
Electro Med Services...
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
