Question about Ruud Central System Air Conditioner
I need to replace a wiring piece of my ruud achiever 12, the part has wires going into it and they have actually caught on fire. the part is 43-23204-19 9604 MRP9188920 60 5vF370V 50?60hz 70c AEROMET II M26P3760W05 WHERE Can I get this part... help!!
4 Suggested Answers
pierre1811
  • 144 Answers
SOURCE: Replacement of filter on Ruud Achiever series heat pump/AC
You must first remove the blower compartment panel. The filter should be in there. However, since this unit is in a crawl space you may have a return air filter grill. Look at your return grill. Does it have a filter? If not does it have latches so that you can open it? If so measure the opening and install a new filter there. I hope this helps. Please don't forget to give me a Fixya rating.
Posted on Feb 23, 2009
meBNme
  • 334 Answers
SOURCE: My Ruud Achiever 90 Plus not blowing cooled air
Look on the condensor, (outdoor unit) at the very bottom of the rear panel and you should find a red reset button. push it. If that does not solve the problem, and the outdoor unit is running (make sure both the fan AND the compressor are running) then you are looking at a low refridgerant issue and possibly dirty coils.
In that case, clean the coils and have refridgerant added.
Posted on Sep 24, 2009
  • 40 Answers
SOURCE: How do I know the
I think the #49 in the model # is for 49000BTU's therefore 4ton
Posted on Apr 04, 2011
I have a ruud achiever 80 series had to replace thermostat now my unit will not work no green flashing light now worked great until the new thermostat help
Its possible that you blew the 5 amp fuse inside cabinet. Turn power off at breaker and open cabinet. Typically a small, car like, fuse somewhere along the red wire leading to the tstat wire. Or on a control board.
Jan 15, 2017 | Ruud Heating & Cooling
Ruud furnace wiring diagrams
Generally Ruud uses that for a common
Nov 08, 2013 | Heating & Cooling
Wiring diagram for contacts on the outside unit
I have a wiring diagram I can send you. I took a picture of mine. Mine is a Ruud Achiever PNE 2 ton.
May 23, 2010 | Ruud Matching Split Air Conditioner
Looking to hook up a humidifier. What 12 volt leadsdo I use off the transformer in the ruud 90 achiever so the humidifier lets water run when the ruud unit turns on
usually you would jump it off the white low voltage wire. check t-stat and see what wire is hooked up for heating. also us the blue or common wire.
Please!! rate this it is important to fixya.
Jan 15, 2009 | Heating & Cooling
Ruud achiever heat pump
the reversing valve needs power to switch to heat. more then likly the o wire is connected when it shouldnt be
Jun 15, 2008 | Ruud UBHC Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Ruud air handlers
Check the name plate amperage on the air handler. The air handler only has the blower motor as its main current draw. #12 wire is rated for 20 Amp service. If the amp draw by the unit supplied by the disconnect is under 15 amps it should be fine (but) once again check the name plate for ampacity rating.
May 27, 2008 | Ruud UBHC Air Conditioner
Ruud Achiever 90 Plus wont start
4 blinks is "pressure switch closed" there are 2 in the system according to the wiring diagram one for the vent system  and one for the drain system ... I just wiggled them and heard one "click" the fault light quit blinking and when I pushed the safety switch back in the furnace fired right up.  That being said is there a good website for learning how to maintain your own furnace?  I'll call a pro if I have to, but shoot I can fix a jet engine... this shouldn't be much worse.
Thanks  dan
Jan 19, 2008 | Ruud UBHC Air Conditioner
Wiring schematic - RUUD
Schematic
All Projects with Photo Preview Browse over 10000 circuits. Now! www.ElectronicsInfoline.com
Jan 02, 2008 | Ruud Central System Air Conditioner
FINDING A DIAGRAM FOR A RUUD AIR HANDLER ON LINE
I dont have axcess to a wiring diagram but i am pretty familiar i know the heater wiring is crazy on these what are you having trouble with??
Nov 24, 2007 | Ruud UBHC Air Conditioner
Ruud Central System Air Conditioner Logo
110 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
