Question about Mattel Barbie Collector's Request Vintage Reproductions All That Jazz Barbie
How do I remove the arms and legs from a contemporary barbie so that I can replace them?
How do I use a staedtler arco compass set
http://www.staedtler.us/en/products/technical-drawing-instruments/compasses/mars-comfort-551-precision-compass/
There are basically two arms to a compass. One arm usually has a point, which you can remove and reverse and or replace with different points for different paper. The other arm has a leg which can be disconnected and replaced with other legs. This arm usually holds the lead or a ruling pen. To remove the leg simply turn the thumb wheel counter clockwise ( lefty loosy, righty tighty) untl you can pulll it out. The other legs have the same fitting you slide in and then tighten the thumb wheel. You may have a very long leg you can add to make a very large circle. Hope this helps.
Nov 18, 2014 | Staedtler Arco Compass Set
Recumbant bike makes aclunking sound whe pedaled
follow this steps and fix it. God bless you
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess grease
Loose Pedals
Kneel next to the left side of the elliptical's base. Use the Phillips screwdriver to tighten the two screws located in the center of the left pedal.
Use the Allen wrench to remove the bolt securing the left pedal arm to the pedal leg and body arm. Use the Phillips screwdriver to remove the screw securing the rear end of the pedal leg to the crank arm.
Pull the end of the pedal leg free of the crank arm. Wipe the crank arm clean, then apply a fresh coating of machine grease or silicone lubricant. Replace the end of the pedal leg back onto the crank arm and use the previously removed screw to secure it back into place.
Join the front end of the left pedal arm to the ends of the pedal leg and body arm. Use the previously removed bolt to connect the pieces together.
5
Move to the right side of the elliptical and repeat the above steps on the right pedal arm
Dec 09, 2013 | Exercise & Fitness
Www.mattel.com/transition.@matte laspx can I purchse just the legs of a ken or Barbie doll?
You could buy a replacement doll on eBay and remove the legs. Some dolls are as cheap as 2 pound
Jun 01, 2013 | Toys
How to oil my size barbie joints and limbs?
spray a little cooking spray onto the joints and move them back and forth.
Nov 15, 2012 | Creative Design 38" My Size Barbie Doll w/...
I have a NordicTrack SL710 recumbant bike that the pedals slip and make a clicking noise?
Prepareto oil by filling a grease gun with lithium grease. Check your owner's manualfor the exact type of grease for your unit.
Oct 31, 2011 | Nordic Track NordicTrack Treadmill, A2550
NordicTrack SL710 pedals slip and make a clicking noise?
Kneelnext to the left side of the elliptical's base. Use the Phillips screwdriver totighten the two screws located in the center of the left pedal.2
Use theAllen wrench to remove the bolt securing the left pedal arm to the pedal legand body arm. Use the Phillips screwdriver to remove the screw securing therear end of the pedal leg to the crank arm.3
Pull theend of the pedal leg free of the crank arm. Wipe the crank arm clean, thenapply a fresh coating of machine grease or silicone lubricant. Replace the endof the pedal leg back onto the crank arm and use the previously removed screwto secure it back into place.4
Join thefront end of the left pedal arm to the ends of the pedal leg and body arm. Usethe previously removed bolt to connect the pieces together.5
Move to the right side of the elliptical and repeatthe above steps on the right pedal arm
Recumbant bike slips while peddling
http://www.youtube.com/watch?v=mVJxs7ALxDM&feature=related
Loose Pedals 1
5
Move to the right side of the elliptical and repeat the above steps on the right pedal arm.
Oct 30, 2011 | Nordic Track NordicTrack Treadmill, A2550
My proform 2605 elliptical the right foot pedal is making a loud noise like it's slipping.
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 01, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
Left pedal arm for a barbie bmx bike broken. Where can I find a replacement?
You should talk to your bike shop because they can find the correct one and also install it because you need expencive bike spicific tools to remove them and replace.
Jul 22, 2011 | Dynacraft Girls 16" Barbie Bike
Mattel Barbie Collector's Request Vintage Reproductions All That Jazz Barbie Logo
1,019 people viewed this question
Top Mattel Toys Experts
thegtw
Nikki  Mclean
Nikki Mclean
ray gallant
Are you a Mattel Toy Expert? Answer questions, earn points and help others
