Sounds like your fuel pump is going out cuase not getting fuel and dies if filter was replaced how long ago fuel filter replaced becuase if you have got bad gas could have clogged fuel filter again with debris try this turn the key to start position but dont start it and see if you can hear the fuel pump and if it is weak hope this helps turn key off then on wait till fuel pump kicks off then do it again then try start it if starts right away is a weak fuel pump cuase manually priming it
why does it only do it when it is luke warm? between 1/8 and 1/4 of the way up on the temp gage. Would it be a censor?
ok i have some things i want you to try it sounds to me like you have a clogged fuel injector try this get a good can of fuel injector cleaner and put that in the gas and or try taking the fuel injectors themselves and cleaning them taking them off the using soaking them in gasoline and clean the sprayer in them any debris out heres why i say this because when car is cold starting it the debri has settle to bottom of injecter but then you start car and it sprays warms up little and from movement the debri moves and settles blocking the injecter one bad injector will shut down the car and see if this fixes the probelm but there sounds like sounds stopping fuel flow this sounds like the problem
SOURCE: After 150-200 miles, spits and sputters on
Clean throttle body, change fuel filter, plugs, and definately plug wires.
Egr seems to be common problem with these.
