Question about GPS
I have a Magellan 4040. I tried to update the software to 2.62 or 3.61 Rel1. I lost my map files because I didn't back up first. Now the unit starts and hangs on the blue screen with the Magellan logo with the black bar. I have another 4040 that I have tried to copy files from. When I do this, the unit seems to function except the map will not initialize.The error: insert SD card with map appears. The unit is not in warranty and Magellan is no help. Is this problem repairable or is the unit useless now?
  • 2 more comments
  • ltsmash Sep 13, 2010
    I am able to get the maps on the SD card from the working unit. I just cannot get the other on to read the map from the SD card. I have tried several times with the same result.
    I have the map files on SD card from the working 4040. I cannot get the unit to read those maps.
    I know there is something I can do to get the unit to read the map from the SD card.
    I have tried this with no luck.
  • 10,515 Answers
This is a common problem with Magellan. There are few tricks that you could try and see, if that helps unless you need to send the unit to Magellan for repair.
1. Remove the SD card from unit.
a) Press and hold the power button for up to 10 seconds
b) Turn the unit back on (the unit should go back to normal operation
2. You could go to Magellan website and try to upgrade your unit's software from there.
If that does not work, you need to send the unit to Magellan and they would flash the firmware for you.
In rare cases, even a bad memory card gives this problem. But as this is their own SD card only they can replace it as it contains maps.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 14, 2010
  • 17,970 Answers
Its posssible that you need format the SD card again, try it accessing from pc/usb port connection.
Then, updated the firmware from support/notes.asp?supportID=754
Tell us news.
Posted on Sep 13, 2010
    President:
  • 2,777 Answers
It is not completely useless, that's for sure, you may need to get the map update from Magellan which can be found here:
http://www.magellangps.com/products/map.asp?tab=0&PRODID=2156
But before I'd do that, if I were you, I'd call Magellan again, at this number (maybe the same one you used?) and attempt to set up an RMA. Tell them you know it is no longer under warranty but you need it repaired. They can definitely fix the issue, the unit is not junk by any means. Make sure you tell them that it was THEIR 3.61 Rel 1 update that wiped out your unit, and you didn't see anything reminding you to back up the maps. They may charge you a small service charge for the repair, but it should be less than the $79.99 they are asking for the map update. Again, if it were me, I'd call back 2, 3, even 4 times to get different support people and eventually someone invariably will help you.
Then you can box it up, and send it back to them at:
Mitac - Magellan Returns Center
C/O ModusLink
Attention: RA #
2000 Midway Lane
Dock 3
Smyrna, TN 37167
And put the RMA # after the RA # portion above.
Thanks
Tim
  • 3,083 Answers
From the blogs I read concerning this problem, the crux of the biscuit is having the backup, as you know. I would think it should be possible to transfer the files from the good 4040. I guess you backed up the good 4040 on the computer, and tried to reload the SD card, then transfer it to the bad one. Don't know what the answer is, but I think the basic software has to be installed before the updates will be valid.
Don't know or think the following link will help you, but here it is:
http://autonavdirect.com/request-14-427.html
It might be irreversible, with the lesson taken and learned, but I would still try to pursue it, just for the challenge. There may be some tecchie that's got a fix. If you can get the system maps on the SD from the old unit, you have a shot.
Good luck, if I can think of anything else, I'll get back.
I attempted an update to the map software version 2.62 or 3.61 Rel1. Something went wrong and the unit will now power on but only to the blue screen with Magellan logo and the black bar on the bottom. I...
run the update again..if it wont take it or wont see the 4040, it gets a little hairy to get them running again, but it can be done.
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
bill
Standing Member of G.O.T.
Sep 13, 2010 | Magellan Maestro 4040 GPS Receiver
I have a Magellan Maestro 4040 that I tried to do a map update. It wouldn't do it and now all that happens when I turn on the unit is that the black progress bar goes across the bottom of the screen and...
i did post a clarification request to you, but i dont think they are working...do you still need help...i can help you..please see my feedback if you have any doubts!
bill
Jun 09, 2010 | Magellan Maestro 4040 GPS Receiver
Are there any free updates for a magellan gps 4040
  • The only free update for your 4040 is the latest firmware or you can call the tech support of Magellan and ask if you can still avail the latest maps for your 4040 don't forget the recepit when you call them, they may ask you to send it to them for verification.
Feb 10, 2010 | Magellan Maestro 4040 GPS Receiver
Map update error problem with Magellan 4250
I had the same problem until I plugged the usb cable into the back port of my computer. Then it worked. Something about using a higher speed usb port.
Oct 23, 2008 | Magellan Maestro 4040 GPS Receiver
Magellen Maestro 4040 code
it is not a scam .then why did you bought it ,i did on my magellan maestro 4000 the firmware update and map but this unit does not come with turn by turn like the old roadmate700 which gave the option to turn on or off turn by turn voice.but what can you do that is life. regardless you must go to magellan website and do all the Upgrades and Maps Updates
  • Magellan 2008/2009 Map Update - NA
  • Magellan Maestro 4040 Voice Upgrade Magellan Maestro 4040 Voice Upgrade Welcome. You are about to retrieve an Authorization Code for an unlock code so that you can upgrade your Magellan Maestro 4040.
    To purchase an Authorization Code you will need to:
    • Login to your existing user account, or create a new Magellan user account.
    • Register your product if you have not already done so.
    • Have a valid credit card with a billing address in North America or Europe. (Visa, Mastercard, American Express, or Discover in North America, Visa or Mastercard in Europe).
    NOTE: This upgrade includes a new sound engine with a text-to-speech feature and an expanded vocabulary. This upgrade is non-refundable and non-reversible.
Sep 27, 2008 | Magellan Maestro 4040 GPS Receiver
Unit will not power up after map update.........
I installed today too. Totally dead, nothing but a backlight blue screen. This is their first update in 2.5 years and it bricked my GPS. You'd think they did it on purpose.
Dec 08, 2007 | Magellan Roadmate 760 GPS Receiver
GPS Logo
63 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
