Question about Refrigerators
I own a 1995 GE refrigerator model TFG27PFSM. The ice maker is not making any ice. The water supply seems to work and the tube is not blocked either.
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
mikedurland
  • 481 Answers
SOURCE: ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Posted on Jul 05, 2008
jmgldsmth
  • 2005 Answers
SOURCE: Water Supply Line for Ice maker and Water dispenser is leaking.
Go to the hardware store and get a brass tube sleeve coupling; cut off the old tube end, slide the hex cap thread side out onto the tube, then; slide the tube sleeve onto the tube and, seat the tube into the supply valve then tighten the hex nut.
take the old parts to the hardware store to compare; the size is most likely 1/4" the part can be found in the "evaporative cooler parts" section of the hardware store
Posted on May 28, 2009
arikrom
  • 528 Answers
SOURCE: ge refrigerator water supply line freeze in door
there is a special kit for that to prevent it and your local repair can get you that its like metal foil that keep it from freeze up...
Posted on Jan 01, 2010
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
Posted on Apr 04, 2010
Ice marker stopped making ice
There is a test button underneath of the motor side of the ice maker. Unplug your refrigerator for 5 minutes then push the test button on the ice maker if it doesn't move you need an ice maker if it does move and you still don't get any water the metal tube that supplies the water to the ice maker is frozen up and blocking water from coming into the mold.
Nov 07, 2013 | Samsung Refrigerators
I have a ge side by side both the freezer and fridge will not cool off, we hear the fan but nothing happening
Follow the steps mentioned below to solve the problem:
First remove the ice bin and look inside the mold of the ice maker to see if it is full of ice. If the ice sensing arm is down ( on position) and the ice maker is full of ice, there is a failure inside the ice maker and the ice maker should be replaced.
If there is no ice in the ice maker, look at the fill tube on the rear of the ice maker. If the fill tube is frozen up the ice maker can't fill.
You can defrost the fill tube with a hair dryer.
The water valve on the rear of the refrigerator supplies water to the water dispenser and the ice maker. Since the water dispenser is working, the only line that could be blocked runs up the back of the cabinet and attaches to the fill tube for the ice maker. The water valve could be bad and not sending water to the ice maker.
If the fill tube freezes again you should replace the water valve.
Hope this helps.
Shane
Mar 12, 2011 | GE Refrigerators
Ice maker not working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jul 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrig. Water leaking on floor after ice maker stopped
look at water delivery tube to the ice mker . it has iced over and pluged up causing the water to go out the back and down on floor . . clear the water tube with hot water and problem is over . .. some models cah use a updated water tube. mm
Jul 16, 2010 | GE GSH25JFR Side by Side Refrigerator
My freezer will not make ice after changing the
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Jun 02, 2010 | GE Profile CustomStyle PSC23NGT Side by...
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
GE side by side. When ice maker tries to refill water is going everywhere except in the ice tray. Removed ice maker but saw no problem with it. Any hints of what to look for?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Dec 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a GE Profile refrig, circa 1995. The ice
If you are sure it is caused by the ice maker or if it is not it can be fixed. The only way an ice maker would leak like that is if ice is blocking the inlet tube and when the water comes on the water is spewed in a different direction than the ice maker. Most times this is caused by a slow leak in the water control valve for the ice maker side at the rear of the refrigerator. You can stop the problem by melting the ice in the fill tube with a hair dryer and keeping an eye on it until you see ice beginning to build up there again. That would indicate a slow leak in the water control valve that is not closing all the way when off. The other reason for large pools of ice in the freezer is a frozen over defrost condensate drain behind the cover in the rear of the freezer and would require you to unplug power and remove the rear panel. I will try to get some photos and a link shortly that covers that problem a lot more in just a few minutes. Sea Breeze
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
I have a GE Profile Stainless Steel refrigerator; the Model number is PFS22SISBSS. The ice maker stopped working.
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 01, 2008 | GE Refrigerators
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
