Question about Kenwood Car Audio & Video
I just bought a KDC MP-235 to put in a 95 camaro with bose amplified speakers. I ordered a amplifier intergration component to reduce the output of the 50 watt per channel head unit as to have better volume control due to the built in, bose amplified speakers. I just noticed in specs of head unit that it has low pass filter or low pas pre amp crossover. Does that mean that the unit is capable of reducing its amplifier output itself to where I would not need the amplifier intergration which reduces head unit output.
    Brigadier General:
  • 6,966 Answers
Yes, the Kenwood KDC MP-235 has two (2) line level outputs (RCA types red & white). However, these outputs internally passed through an electronic crossover/filter making them appropriate for subwoofer amps only.
If your unit is an MP-235CR, then the same outputs would be for the rear amp (not subs) and are full range (unfiltered).
If indeed your unit is an MP-235 and if I may make a suggestion, still connect the Kenwood to four (4) speakers. It would not be technically correct to leave the internal amps operating with no load (speakers) connected. Additionally, you would be getting 200 watts (4 X 50) more to your system (since it is already there).
If your Bose amp & speaker are subs, then no issue, however if the Bose is for a full range of speakers, then only the woofer part would be working efficiently.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 15, 2008
I need the wire conector for car stereo. Clarion 2261f
You are most likely going to need to retrieve that from the Clarion manufacturer. Cost is usually 35-50 US Dollars.
Mar 16, 2016 | Clarion Car Audio & Video
Using two equalizers on two sets of Bose 901's
As I have figured from your question you are trying to independently control levels for two sets of Bose speakers attached to your NAD amplifier. The problem lies in that the amplifier can only read one signal at a time, so in theory it will only accept a signal from one equalizer and output it to speakers attached to A and/or B terminals. In order to process different eq settings to two seperate pairs of speakers you will need to use two amplifiers, or an amplifier with built in channel controls for speaker set A and speaker set B.
Feb 21, 2008 | Bose 901 VI Main / Stereo Speaker
I have a 95 nissan maxima i am trying to replace stock radio(bose) w/a new cd player but once its hooked up im not hearing any sound? whats wrong with it?
Most Bose car stereos have an external amplifier. You will need to see if that is the case on your factory setup and remove the amplifier. Then hook the new headunit straight to the speakers.
May 30, 2011 | Car Audio & Video
Kenwood kdc-148 is in protect mode why?
A car audio component like an amplifier (or in this case a headunit) is most likely to go into protection mode when there is a short in one of the speaker outputs-- in other words, if the + and - ends of one of the speaker leads are touching, this can cause damage to the internal amplifier of the unit. Some units will respond by putting the amplifier into "protection" mode, so that it does not damage itself. Check connections on the back of your unit, or take it back to the shop that installed it.
Mar 04, 2011 | Kenwood Car Audio & Video
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
My amp has power but then immediately goes red into protect mode.
Ok, being an old-school "back yard" installer when i began, gave me 2 immediate possible diagnosis for your problem. I was running a Kicker zx550.3 amp to 2 Polk DB 12'inch Subs rated 600w max 1500w. I also used a LOC converter (Line Output Converter) in order to use my stock Bose stereo since it did not have RCA outputs. Now shortly after running this setup (approx 2 weeks) I noticed a substantial drop in sound output and also noticed some ground noise/distortion coming thru the subs. After tracing my wires that connected my LOC to the Amp, and Rear Speaker Wires of my Radio to the LOC, I noticed that by jostling the wires there was a connection issue. If you are using your factory radio to power your regular component speakers (tweeters, coax, mids) then chances are your stereo feeds into a FACTORY INSTALLED amplifier. If thats the case, then you need to access a Wiring Diagram for the Harness coming off the Factory Amplifier! Once this is viewable, check the wiring and locate the "Amplifier to Radio Signal Wires" and also the "Amplifier to Speakers Signal Wires" ... Now go back to your LOC and look at the wires you tapped to get the Line Signals to the converter, and make sure that you havent tapped your lines off of the AMPLIFIER TO SPEAKER wires. These wires carry a small electrical current because they are coming powered from the Amplifier, and most Line Output Converters are PASSIVE, which could short the signal the LOC creates thus reducing your signal gain, but does have the capability to surge back to the Factory Amplifier, which could possibly melt the shielding of the factory wiring, and thus allow your signal to cross or ground out! If you can, try running another RCA input to your Sub-Amplifier from another source other than your car, and see if your protection lights go out and the amp returns to normal operation. If so then your LOC or Factory amp is to blame. If not, then the second diagnosis is much simpler, which is your Alternator current has been reduced due to many different possibilities, and you should acquire a .5 or 1 Farad Stiffening Capacitor which will reduce the excess draw from your charging system. But due to the first solution being my problem exactly, im willing to bet your's lies along the same variables... GL to you!
Apr 21, 2010 | Sony Car Audio & Video
Connecting a car stereo to an amplifier
you have to connect your 4 speakers to 4 speakers output direct to your car stereo no need of amplifier to 4 speaker but speakers should be small not like a woofer, and you have to connect your sub woofer by using amplifier don't connect direct. connect the output of your car stereo (using 2 RCA) to the 2 RCA inputs of amplifier. If u connect your 4 speakers to your amplifier then your car stereo does not support Left Right channel.
You can also connect your laptop or iPod direct to your amplifier.
Good Luck
enjoy music
Nov 24, 2009 | Kenwood Car Audio & Video
The right channel on my NAD intergrated amplifier C320Bee no longer works.
if you did test for your cable and speaker and you find it fine-your problem will be in output stage of your amp and needs aid of service center.
Jun 11, 2008 | NAD C320 2-Channel Amplifier
Car Audio & Video Logo
108 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
