Question about Canon PIXMA MX310 All-In-One Printer
Where is the plug in on the printer that connects to the computer. I have the white cord and cannot find the receptacle that fits We moved and the printer was taken apart It is one great machine!!!!!!
    Sergeant:
    Champion:
  • 251 Answers
Looking at the back of the printer, the receptacle is on the left side wall of the indentation below where you put the paper in. It's kind of around the corner.
Posted on Sep 13, 2010
I have thre prong dryer and four prong outlet
remove the old 3 wire cord from the dryer,purchase a 4 wire plug and cord that will fit the receptacle then put the RED and BLACK wires on the cord on the 2 outer terminals on the dryer or L1 & L2 terminals,then the white wire on the cord to the center terminal between the L1 & L2 which may be marked "N" or NEUTRAL,then finally the GREEN wire on the cord is thje safety GROUND and this connects to any metallic portion on the dryer case
Sep 12, 2012 | Admiral Dryers
Tip
Rewiring 4 to 3 wire plugs Information.
So you have an, ahem... problem....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
At this point - you have two choices....replace the wiring from the dryer's breaker to the receptacle with all new 8/3 with ground romex (it more then likely only has 8/2 with ground now)....and replace the receptacle with a 4 prong grounding receptacle to match your dryer's cord....OR - as an alternative - you can replace the cord on your dryer with a 3 prong cord to match the existing dryer receptacle outlet.
Out of the 2 choices....the first one will bring the old wiring in the home up to current Codes (all NEW homes must have this 4 wire/4 prong set-up per Code...but older homes are grand-fathered)...but it is clearly the most involved, time consuming and most costly approach...and it is recommended only an electrician do this work. If this approach is taken....your dryer cord can stay as is...it will now fit the new receptacle outlet with no modifications.
The second approach - is to pick up a 3 wire 3 prong cord at your local hardware store to match the existing 3 prong receptacle.....and replace the 4 wire cord on your dryer with it. Although this is the least desireable - it is an allowed approach because this is an older home with existing wiring. This is a much less involved approach...all you need to buy is the 3 wire dryer cord (they come all ready to go) remove the 4 wire cord and install the 3 wire cord to your electrical connections at the back of the dryer. Hopefully...when the 4 wire cord was installed on your dryer, the ground strap wasn't removed completely (this is a metal strap that will connect the white wire to the metal frame of the dryer)...because now you will need to re-use the ground strap. For more on this....see the images of the differences of the 3 wire and 4 wire dryer hook-up at:
http://www.applianceaid.com/general.html#3to4
NOTE: the only real difference between the 3 wire cord and the 4 wire cord is now the white neutral and the ground are kept seperate in a 4 wire..the green ground will connect directly to the dryer frame....where in a 3 wire there is no seperate ground wire - ground and neutral are one and the same...the ground strap connects the frame to the white neutral. The 4 wire permits a better safety measure...in the event of an electrical problem (ground fault) in the dryer...the fault now has a seperate path to your panel's ground...and less chance of a shock from touching the metal frame of the dryer.
The choice of how to proceed is up to you....if you go with completely updating the dryer wiring from the breaker outward...I recommend an electrician do this work for you (it's about an hour's work...plus materials). Then your exisiting dryer's 4 wire 4 prong cord can stay as is....the electrician will install a 4 prong receptacle made to fit your cord.
If you go with simply replacing the dryer's cord....changing it to a 3 wire so it will fit the receptacle...make sure the ground strap is re-utilized as seen in the images at the site above.(also make sure all work is done with the dryer breaker (or fuse if a really old home) off before starting any work. If you change the cord yourself...make sure to reconnect in exactly the same manner as the previous cord was connected...(make a note on paper or take pictures so that there are no mistakes)..and that you tighten the nuts securely to the posts once the wire lugs are on them. Where you state you do not have a background in electrical work...you can have an electrician change this cord for you...(typically in under a half-hour)....or you can do it yourself - by carefully following the pictures.
The choice is yours...if it was me - I'd change the wiring from the breaker outward...making the older home meet today's current Codes and be complaint for this dryer..and then you wouldn't need to change a thing on the dryer....but you can go either way....Codes allow this grandfathering in older homes with existing wiring.
on Feb 09, 2010 | Washing Machines
I am having trouble connecting a replacement for power cord. It should fit but it doesn't.
Hi, This may be remedied believe it or not by a little whittleing. Be very careful as you are dealing with a 110 volt a.c. line cord, any signs of silver or copper color may mean the cord has been damaged! It sounds like the end of the cord might be a bit misshapen. if the receptacle on the back of the bose ( where the cord plugs in ) is for example squared off on the one side while the other is rounded off (or vice versa-the receptacle is rounded while cord is flat along one side ) then you may whittle the flat side to match the plug in. also sometimes the plug end that goes into the Bose may need to be notched ( this can bee seen on any number of cords that you may even already have-a little groove on one or both sides right in between the holes at the end ).
Thanks for asking FixYa, I hope i was of some assistance, let us know if so or even if not, thanks again and good luck, Prodzilla.
Apr 13, 2011 | Bose SoundDock Digital Music System for...
I am changing the 4 wire on my 2 yr old maytag dryer to a 3 wire to fit the recptical in my new house. Other then the 2 hots and 1 neutral connection, my dryer also has a white ground wire off to the side,...
Feb 19, 2010 | Dryers
3 wire to 4 wir
Feb 11, 2010 | Kenmore 94802 Front Load Stacked Washer /...
How to hook up a 4 wire plug to a Maytag clothes dryer model LDE8824ACM with 3 wire connecters.
Feb 09, 2010 | Dryers
Need to replace existing three wire plug with new four wire plug. there are only three terminals to connect to. what do i do?
Based on your description....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
Feb 08, 2010 | Dryers
Just moved and now my HP 812c won't turn on- is there a on/off or reset switch I am unaware of?
There is no reset
Possibke causes other than failure of equipment:
Power cord(s) not seated properly.
Power convertor plugged into a SWITCHED receptacle intended to plug in a floor lamp and switch is off.
ALWAYS run all your computer stuff from a single receptacle to avoid ground loops and possiblle damage.
Oct 11, 2009 | HP DeskJet 812c InkJet Printer
Wont start till I pull on the cord to make connection.checked cord with volt meter,its o.k.help. stampvs@yahoo.com
If you have unplugged the unit and performed a continuity (resistance) check from the end of the power cord to where it connects to the terminal block at the back of the appliance, then the next logical step is to perform a voltage check of the wall receptacle itself. If the voltage at the receptacle is good, but you are having connectivity issues with the appliance plugged in, the receptacle terminals may have become loose, or you may have a power cord that has a loose or broken wire. This intermittent connectivity can cause the receptacle and/or power cord to heat up and cause a fire. With the appliance unplugged, connect an ohmmeter to either end of the power cord and perform a continuity check. Move the power cord to see if the readings are constant. If you have intermittent resistance readings, you have a bad power cord. If the power cord still checks good, then I would recommend having an electrician check your wall receptacle before using the appliance again. If you still have questions, let me know. I hope this helps you.
Jun 19, 2009 | Frigidaire Electric Dryer
Electric cord
What you should get is a new 4 wire cord. It is way less complicated than trying to change out the wall receptacle.
On a 4 wire dryer cord you have White(common) in the middle. Red and Black are hot and go on either side of white. If you really want to make it look good you can put red to red on the terminal and black to black but you don't have to. Some dryers may not have those color hot wires. Green hooks to the chassis with a green screw or any screw connected directly to the frame.
Jul 21, 2008 | Kenmore 62802 Electric Dryer
Canon PIXMA MX310 All-In-One Printer Logo
19 people viewed this question
old marine
old marine
