1.
Take the battery out of the laptop & try to turn on the laptop
using power adapter only. If the computer turns on, then the battery is
defective & needs to be replaced.
2. Make sure the power adapter
is not defective. Test the output voltage of the power adapter using a
voltmeter. Compare the voltmeter reading to the nominal value written on
the adapter or the laptop.
3. If you have another processor which is
compatible with your laptop's model, try swapping processors & test
to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
