Question about Orion STV2763 27" TV
Orion ftdv2004a VHS Tape stuck
How do you get a stuck tape out? when you push eject nothing happens
  • 66 Answers
Orion ftdv2004a is a remote control model number. Please provide the make/model of the VCR itself.
Posted on May 15, 2008
How to remove a cassette stocked in a vhs machine?
If the VHS tape is stuck inside, and when you push the eject button, it wont come out. Then you need to unplug the VHS player, take it apart so that you can access the inside. See how the tape is stuck inside and start to take it out the best you can. Once you get it out you may have to throw away the tape if it is messed up badly, if not wind it back up. Put the VHS player back together once you get the tape out. Then try to play another VHS tape and see if it works again. If not, it may be a bad VHS player or it may be the tapes. Hope this helps. I have had to take mine apart to take a tape out, so that's how I know
Feb 12, 2015 | Televison & Video
Tape an catridge stuck
Unfortunately, the best chance you got of getting the tape out is to open up the video to release the tape.
Feb 08, 2008 | Aiwa HV-MX1 VHS VCR
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VHS tape is stuck in the machine. How do I remove it?
This is often a frustrating problem but if you feel you can handle it go ahead with the following, otherwise get professional electronics help. If you have tried to eject the tape and tried other obvious ways to extract the tape and nothing has worked then you can remove the top cover and manually remove the tape. It is not that hard to do most of the time. First unplug the power cord from the wall outlet. You do not want to get a short or get shocked or zapped. Just unscrew the screws holding the cover in place and set the cover aside. Look at the tape to see where it is hung up. If you need to push the tape around so you get it off the posts or otherwise free up the tape, then gently do so until you free the tape from the tape transport. Sometimes this is all you need to do to extract the tape. You may be able to push out the tape from the VCR at this point. If you can get all the magnetic video tape back into the cassette but the tape simply will not come out then place the cover back onto the VCR, plug the VCR into the wall outlet, power on and try to eject the tape now. Sometimes this works. If all else fails, take the VCR into a electronics repair shop and have them remove the tape for you. They may tell you the VCR needs repairs also so this does not happen again.
Mar 31, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
My Panasonic Omnivision VHS won't eject
take the top off and eject it manualy, there is nothing else u can do with replacing a part, (small white spring loaded, ) probabaly
May 09, 2009 | Zenith ZHX-313 System
Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
SONY VCR: Keeps ejecting video tape
may be machnical stuck in playback mode. remove the cover and see the loading arms are near the video head , if not try to release the arm rotating caption wheel smmothly . don't push more force to rotate the wheel.
Jul 11, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
VCR tape won't eject
you should take the bottom off and you will see a gear with a belt around it try to turn it the same direction as when it is turned off, do not force it but it may need a little force to move the wheel.
Mar 17, 2008 | Sony SLV-998HF VHS VCR
Orion STV2763 27" TV Logo
94 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
