Question about Sony RDR-GX300 DVD Recorder
When powering up my Sony RDR HX720 it only shows the word "Welcome" and stays stuck there. Resetting or unplugging for 12 hours or so, have the same result. The word Welcome certainly has outstayed its welcome! Help please! Kind regards Rob
  • 1768 Answers
SOURCE: My sony hd dvd recorder
if it is saying "welcome " it is <on> but maybe the logic needs a reset
It may be a dirty DVD disk >>> clean with soap and warm water and dry with a cotton towel >> then try again.
this also may be a dirty lens
>>> compressed air blown inside the load bay sometimes will remove the dust build up
Hope this helps.
Posted on May 22, 2008
  • 124 Answers
SOURCE: Sony rdr-hxd710 dvd/hdd recorder stuck on welcome.
Set your Television to the corresponding input line. If you have the DVD recorder connected to your television input 1 line. Set your television to input 1 line. The recorder is just waiting for your command to set your time and area ...etc.
Posted on Nov 12, 2008
  • 5 Answers
SOURCE: Sony RDR-GX220 DVD Recorder
This is not a solution but was told by repairers that an ic has gone bad.
I resolved the problem for a while when I removed internal cable and some how got it working.It worked as long as it was powered up. Had a power failure and now battle to resolve the problem. Suspect that it can be a low voltage out of the regulator ic. The mystery was that when I got it working it worked perfectly. The firmware is also doing a power test and I think this is failing and thats why it is display welcome.
Posted on Aug 01, 2009
SOURCE: SONY RDR GX120 stuck on WELCOME message
I have similar problem. I found that if I remove the outer casing (disconnect from mains supply first) and disconnect the DVD cable to the units circuit board then power up again it would clear the problem, but on reconnecting it then trying again the ‘Welcome’ message returned as before. I’m guessing it’s a problem with the DVD drive or its connection. The only other thing I have noticed is, if you do manage to clear the ‘Welcome’ message and leave the unit switched on with the standby button the unit works as normal.
Posted on Oct 12, 2009
SOURCE: my dvd player rdr-hxd860 seems to be frozen on 'welcome'
I've had the same problem. I've actually unplugged the unit and it's been unplugged for probably about two weeks. When I reconnected the power this morning the problem persisted where the DVD Recorder was stuck on the Welcome Screen. As a last ditch effort I pressed and held the power button for 10 to 15 seconds until the word "Welcome" dissapeard of the screen and back on. This seems to have reset the unit. I know I should have tried this a long time ago. So much for reading the instruction manual! I'm just glad it's working again!
Posted on Nov 28, 2009
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
When I power up the unit it only shows Welcome and stuck there, after reset or unplug power it also shows Welcome. It is totally frozen at Welcome.
Hello
Its power board had got damaged. It ony supplies 5VDC to the board, which in turn energises the system control and display. There is 4 more voltages out from it is missing. You have to findi out it, and reason for its failure. Actually the swithcing process in the power supply board is OK. But without the above said missed voltages, there will be no motor voltages and mainboard chroma and decoder voltages. The system is very complicated in circuit nature, so without any previous expeience, never attmpt to reapir it. If you are well aware in digital electronics, you can do this. A high quality digital multimeter and a concept of soldering are also needed. I've given you the fault advice according to your post. Determine what should do. OK.
Mar 23, 2011 | Sony RDR-GX300 DVD Recorder
SONY RDR-HX950 is showing WELCOME in display at startup, nothing else happends
i have a sony HXD-1065 which was doing exactly the same thing.
i searched loads of forums to get some idea of the cause but nothing.
to cut a long story short, i put the recorder away in a cupboard for approx 4 months then just as i was about to list it on ebay as faulty i thought i'd just switch it on and see what happens and it came on and loaded up as it should with no problem so i unplugged it and plugged it back in several times to see if the permanent welcome message came back but it just loaded and has worked perfect for the last 5 or 6 months.
i found out later that the memory capacitor needs to fully discharge before it can reset itself on power-up.
i'm not sure exactly how long this takes but it took me 4 months to find it works again.
Jun 30, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Sony dvd recorder will not open
Well while the unit is on and the Welcome is frozen push and hold in the power on button for about 15 seconds or so until the power goes off. Then release the power button. The unit will go on and the Welcome will eventually blink and the unit will eventually cycle into power off with just the clock showing. Then unplug the power and wait, unplugged for a few days to let the memory capacitor discharge..... If further you have the same problem then you need to repair it....... Please post comments for further help or information...........
Good Luck!!
Mar 27, 2010 | Sony RDR-VX560 DVD Recorder/VCR
My dvd player rdr-hxd860 seems to be frozen on 'welcome'
Nov 17, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Aug 03, 2009 | Sony (RDR-HX710) DVD±RW Dual Layer...
Sony region free hack codes
i have the same problem can't find any codes from those models at all
Aug 24, 2008 | Sharp DV-NC80 DVD Player/VCR
Recording Problems!
You may try a different style DVD disc. Are you using (+), (-), or (RW) the DVD makes a difference. http://pdf.crse.com/manuals/2636511113.pdf Here is the manual for your product. Check pages 9 and 10. These pages tell you the type of DVD disc to use, and what speed they can be used. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Sony (RDR-HX710) DVD±RW Dual Layer...
Sony RDR-GX300 DVD Recorder Logo
221 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
