Question about Toshiba Qosmio F55-Q502 Laptop
Buy cable monitor part - Toshiba Qosmio F55-Q502 Laptop
  • 73 Answers
Umm, i dont understand what the ??? is???,,,,
Posted on Sep 13, 2010
What does it mean when it says No VGA Cable
"No VGA Cable" typically means that the monitor does not include a VGA cable, which is the cable you need to connect it to your computer and get it to display properly. You will have to use/buy your own VGA cable to get the monitor to work properly.
Jul 09, 2014 | Dell IN1910N 19" Monitor
Compaq 1825 shows pink/green instead of usual colours wat do
This is probably one of three problems that often screw up the colors on a monitor.
This is most likely a problem of your computer overheating. To fix this:
1. Open your computer and clear out any dust particles with a vacuum. Just make sure not to hit any of the parts of the computer and break it.
2. Get a cooling system. This could be as simple as pointing a fan at your computer and turning it on to buying a water cooling system. Just do something to try to keep your average heat lower.
This is most often the problem and will clear up your problem. If not it may be a problem of a bad cable.
1. To test this you could go out and buy a completely new cable and connect the monitor with that cable. If you don't want to pay for a new cable not knowing if that's the problem, just borrow a cable from a friend, neighbor, or your work and test with that. If it works with the new cable, buy a new one and that fixes the problem.
If neither of those solutions fix the problem it is most likely just a problem with the hardware in the monitor. If the monitor is still under warranty, contact Compaq support and have them replace it. If it is not, you'll need to buy a new monitor.
Thank you for using FixYa!
May 29, 2011 | HP Compaq 1825 18.1" LCD Monitor
My Compaq 1825 monitor is showing pink/green instead of its usual colours. I went for dinner and came back to this.. wat do.
I cant see colors red l
recheck the signal cable,
each pin on the cable carries a differant signal some just a clock some instructions for an entire color. check to ensure a solid connection on both ends of the cable and that the video card is secured in the machine.
if still no red then replace the cable, best buy 5-10 bucks saves you from buying a new monitor in frustration.
still no red replace the monitor.
Jun 11, 2010 | Dell E177FP LCD Monitor
I have an HP Pavilon, Laptop and an Acer Monito
you can buy a lcd cable to connect your laptop and your acer moniter.
if your moniter is a crt then no need to buy you can use the default cable.
if its a lcd the cable is given in that package. you can use it.
you can see a vga port in your laptop with blue colour that is the connector for moniter and your laptop
Jul 14, 2009 | Acer AL1721 17" Flat Panel LCD Monitor
What cable do I buy
If it is a dvi monitor then you would need a dvi cable. VGA monitor would need a VGA cable. HDMI monitor would need a hdmi cable. If it is compatible with both dvi & vga and your video card has a dvi output then dvi is a better quality than vga. You can purchase the cable online at a store like cables2go. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | NEC MultiSync 1525X 15" LCD Monitor
THE MONITOR SONY SDM M81B HAVE HDCP??
A DVI to HDMI cable should work, I have the same monitor, but attached to an Xbox 360, if that doesn't work then buy a HDMI Cable and a HDMI (Female) to a DVI (Male) Adapter
Cheers
Nov 03, 2008 | Sony SDM M81B (Black) 18.1" LCD Monitor
Pink monitor
When you got the new monitor, did you also get a new cable? Most likely the issue is not the monitor but either a bent pin on the cable connector or a bad wire within the cable. Try using a cable from another monitor or borrow a friends to test, before you buy a new one.
Mar 10, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Monitor cable
Aarti Services
Flat No-2, C.J Apartment
Kandivali (w)
Mumbai
9322133048
Dec 27, 2007 | ViewSonic G790 19" CRT Monitor
SYS Technology monitor SYS-152L-C-JT
What kind of cable do you need? Data cable?? you can use from the other old crt monitor.
Power cable?? is the same cable from desktop cpu computer. Are the same type.
Sep 06, 2007 | Sys Technology SYS 152L-C-JT (Chrome) 15...
Toshiba Qosmio F55-Q502 Laptop Logo
22 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
