Question about Dynex 60" Universal Tripod
The head of my dynex tripod is loose how can this be repaired?
  • 685 Answers
There are some brands of tripods that are made for the retailer and the name is licensed, so the name brand does not support or stock repair parts. Especially if the tripod is an inexpensive one. Because of the model and make of you tripod, I would recommend you throw it out and buy another one. In my opinion Slik and Manfrotto are two very good ones. Slik for the lesser expensive and Manfrotto for the more durable, expensive, parts are almost always available unless is it really old tripod. Find some Manfrotto tripods at: www.BogenTripodParts.com
Posted on Sep 24, 2010
Whilst trying toromove the 168 ball head from my manfrotto art055 tripod the head became loose on the central column. How can I fix it back
There is a video at: http://bogentripodparts.com/repairs.htm
the one on the right shows you. It is usually remove the 3 screws and a little force to unscrew the head.
Apr 02, 2014 | Manfrotto Photography
- I need a quick release plate for this tripod DYNEX DX-MW010.
Try http://www.tripodquickrelease.com/Dynex_Quick_Releases.htm Check the dimensions of what you have against this one listed see if it will work for you.
Apr 02, 2013 | Photography
Screw at top too large for digital camera. How do I modify to work with nikon 300?
The mounting scre is probably a 3/8" and your camera takes a 1/4x20. 2 solutions::a ball head to mount between tr4ipod and camera, or search eBay for a 3/8" to 1/4" reducer.
Oct 24, 2010 | Dynex Premium 65 inch Tripod for Digital...
Looking for a dynex trp-60 plate (to replace lost one).
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I’ve seen.
Jun 03, 2010 | Dynex 60" Universal Tripod
Tripod head
If the head is loose on the tripod follow these instructions:
There are three small set screw (grub screws) that are under the head, net to the center column. You will have to raise the center column and look under the head. These are slotted screw heads and a small to medium screwdriver should work. You don ot have to remove the grub screws completely, but you should back them out at least half way. The head will unscrew off the center column. The gray part below the head is half the head attachment and half the center column end plate so it should separate in the middle line between the two.
If screws came out elsewhere, we will need to know the model number of the head that came apart.
Jun 01, 2010 | Manfrotto (Distributed by Bogen) 055XDB...
Head will not tighten on AF2100 Pistol grip
one of the treads in the tripodas head is broken try unscrewing the grip the other way to remove it, then examine the grip, if one of the threads on the part of the grip that screws in to the head, is broken then you might be able to get a new grip, and that might work, but there might also be damaged threads inside the tripod head, in which case you neet to replace the head if you can, but if you cant, then I do not think that you can repair that tripod
Aug 01, 2009 | Slik PRO 700 DX Tripod
Lost mount for tripod can I get a new one?
Velbon QB-4W Quick-Release Platform is a nearly identical replacement for the plates that come with the Dynex tripod. You buy it from:
http://www.amazon.com/s/?ie=UTF8&keywords=velbon+quick+release&tag=googhydr-20&index=electronics&hvadid=3155273537&ref=pd_sl_6aoq8ub9ut_b
Apr 28, 2009 | Cameras
How to fit camera on dynex tripod
http://www.youtube.com/results?search_query=how+to+use+a+tripod&search_type=&aq=f
http://www.youtube.com/watch?v=oTDCVSW07o8
Mar 22, 2009 | Dynex 60" Universal Tripod
Problem removing head from tripod
Look on the underside of the platform where you screwed on the head. It should have 3 small screws in it. These are tighened and loosened with a jeweler's screwdriver. You may have one screw that is just *barely* tight, so you were able to hand tighten the head until it "locked" into place with the screw. When you loosen each of these screws a few turns the head should come off.
If you can't locate these screws, or you can't remove the head, you will need to take the tripod to a large camera store for assistance. Their rental or repair department can help you remove the head. If you need help locating a large camera store with a rental or repair department in your area, I may be able to help - I would need your location (e.g. city/state/country/zip or postal code).
Dec 31, 2008 | Bogen Communication Bogen Manfrotto Tripod...
Need a quick release plate for Dynex tripod 60
Quick release plates can be purchased on amazon, here: Amazon com Dynex tripod quick release plate. Take a look. Wish you ebst of luck.
Thomas
Nov 03, 2008 | Dynex 60" Universal Tripod
Dynex 60" Universal Tripod Logo
510 people viewed this question
Top Dynex Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Dynex Photography Expert? Answer questions, earn points and help others
