Question about Viper Security and Remote Start System (basic install included)
98 Ford Mustang Viper 5900
My Viper 5900 wont start. I wanted to know if a relay was needed for a 98 ford mustang and if there was one available that did not require a second key?
    Genius:
  • 1,224 Answers
Ok lets check basics first
do you have lights on and power to head lights this is a plus if you do
if you dont its either dead cell in battery or bad alternator that wont charge battery
ok did you try a manuel start tool too starter or old fashion way jack car up and apply long screw driver between power cord and ground on starter this is also a manual start if car turns over its not a relay
look at your key has it been worn down or is it brand new these are indicators of old key cylinder wear
i had to replace my key cylinder the first day when i bought my truck they made me new key but cylinder was wore out i had several problems with other vehicles in this manner
if you made a new key cause old key was bad that doesnt change the fact that key cylinders wear out too
the relay panel is under the hood on fords now heres a suggestion to test them find similar relay in panel box pull out and place in bad relays place
this can tell you if the relay is truley the culprit but remeber when you change it put the other back in the spot you took out
cars come with average of 6 to 8 exact relays for different components of vehicle but they are the same in the panel
did you install a new car sterio system in the vehicle if you did you probably got the wires crossed or not in right place on wireing up radio fords tend to run a couple components threw sterio wires under my profile here i speak of proper wire harness and wire connections this is crucial
this is basics without computer diagnoses its the most info i can give you at this time
Posted on May 15, 2008
Fuel pump relay 1998 mustang
Fuel pump relay reaplacement 98 ford mustang gt: http://youtu.be/mF7oAGRHWEE
Feb 21, 2015 | 1998 Ford Mustang
Ford mustang wont start my 2002 mustang wont start it has a viper alarm system on it.
You need first remove the alarm then check if it start. Or put the ignition on make sure the vehicle is in park if it is a automatic transmission. Or in neutral with emergency brake on hot wire the stater.
Oct 03, 2013 | Viper Vehicle Parts & Accessories
My 98 ford mustang is stuck in park
check fuses for brake shift solenoid. the brake pedal position switch is a fuse under the hood. inside the passenger compartment, check every fuse. that's a start for not having more information.
Dec 08, 2011 | 1998 Ford Mustang
LOOKING FOR FLASHER RELAY LOCATION ON 98 FORD MUSTANG
either under the dash by or in the fuse box or under the hood in the other fuse box
Jan 03, 2011 | 1998 Ford Mustang
98 mustang anti theft
you need to have the key reprogrammed by a locksmith or the dealership. it will only start and stay running with the original or reprogrammed key.
Jul 23, 2010 | 1998 Ford Mustang
Problems removing 98 ford mustang transaxle
If you are talking about the axle hub nuts,then you may have to use an air impact socket driver and impact sockets.These nuts can be torqued to over 140 FT LBS. Let me know if you need more help.MOE
Jun 22, 2010 | 1995 Ford Mustang
98 MUSTANG TAKES TO MANNY TURNS TO START UP V6
fuel pump, regulator and filter need replacement.
Apr 11, 2009 | 1998 Ford Mustang
Where to find fuse diagram for 95 Ford Mustang?
http://www.allfordmustangs.com/forums/attachments/94-95-tech/608d1036338026-need-fuse-box-diagram-95-gt-esb01113.gif
hope that helps.
Mar 26, 2009 | 1995 Ford Mustang
My 98 mustang wants to start hard
what do you mean start hard?
you mean slow cranking or long cranking before start?
Jul 07, 2008 | 1998 Ford Mustang
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
297 people viewed this question
Top Viper Home Security Experts
Will Halftowaite
jason
Kevin Daniels
Are you a Viper Home Security Expert? Answer questions, earn points and help others
