Question about Health & Beauty
Need to know what a E4 reading on the runyes autoclave means
E4 error is a pressure and temperature differential. Check the steam generator solenoid,steam generator water pump and water sensor in clean water reservoir. If any of these components are faulty then replace. If all ok refer to E2 error and check inner temperature sensor or check for steam leaks
Posted on Sep 15, 2010
  • Steam Swami Nov 10, 2010
    What E4 means is that, unfortunately you bought one of the worst autoclaves on the market in the world.. No proper door lock, superheated steam, lousy temp control. Chuck it
Autoclave saying ES what does it mean
There are a variety of brands/models of autoclaves and your model is not adequately identified. There are ES models of an autoclave of a particular brand but I have no knowledge of their designation system. A search of an autoclave manual did not reveal an "es" error code. Why not contact technical support or the sales forces of the manufacturer with the query?
Aug 31, 2017 | Science & Laboratory
What does vacuum failure mean for a siltex autoclav?
It means it was unable to achieve sufficient vacuum to hit whatever set point you have it set for. It also probably means a) you have a leak in the chamber or b) the device creating the vacuum may be clogged or broken.
Jun 17, 2014 | Science & Laboratory
Why is my autoclave not heating its water?
If you are not using purified or distilled water, most likely the heating element or sensor has become encrusted with lime or calcium and gives a false reading which will not allow the heating element to engage. (safety stuff you know) All you could try is a fill with a limeaway solution of 20%, cycle, drain and refill with distilled water, or disassemble and clean the components.
Jun 03, 2014 | VWR As12p Autoclave Accu Steam Sterilizer...
Turned off autoclave in the middle of a cicle
What exactly is wrong that you need help with? More info needed. Why was it turned off? Did it turn off by itself?
Feb 19, 2014 | Science & Laboratory
Err 01 little sister ses
This is a power failure alarm, meaning the prior cycle failed due to a power failure/ outage.
Verify your power supply is correct for this unit's needs.
Check the fuses.
Beyond that, it may be a wiring/power supply issue. Call for service.
Jan 29, 2014 | ESCHMANN Little Sister Autoclave Tabletop
Enigma b autoclave
Oh no, you have bought a "Runyes" Chinese unit. "Run - Yes" is the best option. Sell it & buy something better.
But, E4 is to do with Temp or Pressure not right.
Code E4:constant temperature and constant pressure failed.
(the chamber pressure tolerance is greater than 0.25bar or temperature tolerance greater than 2.5?)
Solution:
A. please check if you can open the solenoid valve which the steam gets into.
B. please refer to E2 process
For E2 try:
Code E2:Chamber overpressure
(The chamber pressure is above 2.4 bar for longer than 2 seconds)
Solution:
A. Please check when the pressure rises, the chamber inner temperature will also rise up. If not or rise up very slowly, then you should check the inner temperature sensor, please refer to E1-C1 process.
B. The chamber keep vacuum pressure, the vacuum pressure will be -0.7 bar within 4 minutes under normally room temperature, and it will above 0.1 bar within 5 minutes if the pressure do not leak out, otherwise, you should check the chamber cover, solenoid valve, safety valve, vacuum pump, connector welded points, till you find the problems where and why the pressure leak out, then solve the problems if you find it.
C. During the machine normally working cycle, please observe if the machine vacuum could be lower than -0.6 bar, even lower than -0.7 bar if the machine is still cold.
D. Adjust the chamber cover and tighten a little if necessary.
E. When you run a cycle for the first time with a packed or non packed instruments and it comes up with E2, please don't worry. It will not come out with the E2 alarm again when you run it the second time.
Sep 12, 2010 | Health & Beauty
E4 trouble condition comes up on screen after power up
Error #4, You probably need to reset the phone by unplugging the main unit from the power source then plugging it back in abd re registering the handsets by setting them in the main cradle for about 10 seconds each. if this doesn't work try the manual if you have it still and see what E4 error means. Good Luck. Sometimes with electronics all you need to do when they wont work is unplug then and plug them back in while holding the power button on. This is amazing trick that no one wants anyone to know about. it works great on VCR's and DVD players.
Feb 11, 2009 | Uniden Cordless Phone
Kenwood dishwasher
E4 means overfilled which in practice means there is water in the tray at the bottom of the machine. Lean the machine forwards and the water will drain out and clear the fault code. chances are it will fill up again so if it repeats the leak will need to be found.
Oct 27, 2008 | Kenmore 46123 Stainless Steel Electric...
Health & Beauty Logo
608 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
