Question about Pentax *ist DL Digital Camera
Pentax 1st DL shows memory card error no matter whether I replace it with a card that is working in another camera.
  • wright_norma Sep 13, 2010
    Yep, it reinforced what I was thinking
    Genius:
  • 1,040 Answers
This means the your memory card slot (i.e. part in which we put the memory card in cam) has stopped functioning. So get it serviced....
Hope this has helped you... Thanks
Posted on Sep 13, 2010
  • balanbee
    balanbee Dec 25, 2010
    update your firmware from Pentax, go to Pentax web and check it out !
Eclipse avn110m sd card error 013006
This must be very upsetting for you - what make and model of camera has this occurred on ?
Jan 05, 2017 | Cameras
When I insert a memory card into my pentax camera, I am getting a memory card error message. There are pictures on the memory card. The card works when inserted into another digital camera.
Hello
Ok, here is something that just might work.
In your case the problem is not with the card but rather with your camera's card reader. This is a rather hard problem to fix yourself but here is what you can do.
Open the card slot of your camera and peer inside with a sharp light or torch. You should see a little metal tab or switch inside the card slot. This is the write protection switch. Contrary to popular belief , the switch on the card does not impact the operation of the card itself but rather tells the camera that the card should be locked by depressing the little pin inside.
If you put a protected card into a camera with no protection switch , the card would operate normally.
However , with time and repeated use , the switch will start to bend slightly until it will no longer depress when a unlocked card is inserted.
With a toothpick or needle , slightly and very gently push this tab up a little bit. (some camera's will require you to pull the tab down), This will allow the switch to operate once again and should solve your problem.
Kind Regards
Andrea
Aug 13, 2010 | Pentax *ist DL Digital Camera
Memory Card error message
The K100D works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot is is electronically incompatible.
Sep 25, 2009 | Pentax K100D Digital Camera
Memory Card Error on 4 Gb CF cards (80x) for Pentax Optio 430
The maximum supported memory for Pentax Optio 430 is 256mb and for Pentax Optio 430 RS is 512mb.
Check this site for more information.
Optio 430
http://www.upgradecomputermemory.com/ram.cfm//memory/P/Pentax/Pentax-Optio-430/
Optio 430 RS
http://www.upgradecomputermemory.com/ram.cfm/memory/P/Pentax/Pentax-Optio-430RS/
Jun 10, 2009 | Pentax Optio 430RS Digital Camera
Memory card error when I turn on camera
oops.. looks like many card errors, as just now i gave reply to 2
Test the memory cards using external card readers connected to computer/laptop and see if it works.
If it doesn't, then it can be formatted from computer and tested on Pentax again.
If still it doesn't work on Pentax then it can also be a small issue of contacts inside attracted dust. You can try using blower to clean dust if any in the place you insert the memory card and try again.
If it doesn't work then it it needs visit to some experienced person/technician/mechanic.
May 30, 2009 | Aqua Pentax Optio S12 Digital Camera
Camera won't read new SD card
The sd card is to big go for a 2gb ted10
Apr 18, 2009 | Pentax Optio 550 Digital Camera
Pentax K200D Digital SLR - Error Message "f - - "
This can also happen when the lens have an aperture adjustment ring, and it is not set to the "Auto" setting ("A", on my Sigma)/
Dec 25, 2008 | Pentax K200D Digital Camera with 18-55mm...
Memory card size
The S5z is limited to SD cards, 2GB and smaller. The speed doesn't matter, but larger cards will not work in this camera.
Aug 26, 2008 | Pentax Optio S5z Digital Camera
Pentax *ist DL Digital Camera Logo
334 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
