My computer has been locked from the boot menu i put my password in or so i think it is and it will not accept password it tells me to enter password then press (ctrl and enter) to disable system lock not taking password can i reset boot menu password
  • 97 Answers
U can reset boot menu password through removing BIOS battery and than switch on the system it will clear or some boards are with jumpers u can check CMOS clear from 1 to 2 for clear 2 to 3.try it.
Posted on Sep 13, 2010
Hen I put my email and password, it will o will not ta it. If it take the email or password nd when I try the nex't it tell that it is encorrect passwor or email. I cannot use my computer,phone or laptop.
  1. check for caps-lock key see ifs its on
  2. for windows i can fix that for computer i can fix that when you boot your computer there is a boot selection menu look for it press the key and boot in safe mode when pc boots it you will see 2 accounts goto safe mode account and then goto settings and remove the password
  3. for phone i cant tell because you didnt specify your phone and its OS
Apr 05, 2014 | Facebook Apps
I forgot my password
You will need to reinstall windows
Apr 05, 2008 | Dell Latitude D600 Notebook
Tip
How to Boot From A Windows 7 Password Reset Disk?
<span>Forgot Windows 7 password? It seems to be a universal iusse as widespread of Windows 7. To solve this problem, you can either buy a burned Windows password recovery CD on-line or burn such a password recovery disk with<b><a href="http://www.passwordunlocker.com/knowledge/windows-7-password-reset.html">Windows 7 password reset</a></b><span> </span>software. But no matter which method you choose, you have to boot your locked computer from the password recovery disk. However, you will feel frustrated when you have little computer skill. Take these 2 methods as your reference when you encounter the similar problem.<br />Of course, firstly , you need to create a<span> </span><a href="http://www.passwordunlocker.com/knowledge/create-win-7-password-reset-disk.html">Windows 7 password reset disk</a>, and then pay attention on how to boot from the Windows password reset disk .<br /> Method OneInsert a burned Windows 7 password recovery CD in your locked computer boot the locked computer from the CD/DVD as follows:<br /> <ul> <li>1. Turn on or restart the locked computer, watch the screen for a message like "Press to http://www.passwordunlocker.enter SETUP "or something similar. Press this key as soon as you see the message to enter BIOS menu.</li><b>Note</b>: The key pressed to enter BIOS is different based on manufacturers, but F2 or Delete are the most common keys <li>2. Use arrows to choose Boot on the taskbar, select<b><span> </span>Boot Device Priority</b><span> </span>and press Enter.</li> <li>3. Set<span> </span><b>CD ROM</b><span> </span>to the first boot device according to the prompts on the right.</li> <li>4. Press<b><span> </span>F10<span> </span></b>to save and exit BIOS. You computer will restart with the changed BIOS settings</li></ul><br /> Method Two <p>If the method above doesn't work, you can also try to enter Boot Menu to boot the locked computer from the burned CD/DVD as follows:<br /> <ul> <li>1. Insert a Windows 7 password recovery CD in your locked computer.</li> <li>2. Start the locked computer and immediately tap and keep tapping<b><span> </span>F8</b>,<span> </span><b>ESC</b><span> </span>or other keys until the Boot Menu screen appears.</li> <li>3. Select<span> </span><b>CD ROM</b><span> </span>as the first boot device and press Enter. After that, your computer will restart with changed bios settings.</li></ul>PC users can not only set bios password for computer, but also set Windows logon password. If the BIOS is password protected, you need to clear or remove the BIOS password before you can enter BIOS to change boot order.<br />By the way, if you forgot Windows 7 password or Windows 7 password-protected, it is suggested to take Windows password recovery software to create a Windows password reset disk. Take<span> </span><b>Windows Password Unlocker<span> </span></b>for example, it takes you only 4 steps to burn a bootable CD/DVD or USB flash drive for Windows 7 password recovery in 5 minutes.<br /><b>Step 1:</b><span> </span>Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker Professional</a></b><span> </span>in any availble PC<br /><b>Step 2:</b><span> </span>Burn a Windows 7 Password Recovery CD/DVD or USB flash drive.<br /><b>Step 3:</b><span> </span>Boot from the burned the Password Recovery CD/DVD or USB flash drive.<br /><b>Step 4:</b><span> </span>Reset Windows 7 password under Windows PE.<br /></span>
on Mar 23, 2011 | Computers & Internet
Ubuntu adm password reset
Click "Applications" and then click "Accessories" on the top taskbar in the Ubuntu desktop.
Click "Terminal" to open a terminal window.
Type the following command at the Linux prompt and press the "Enter" key:
sudo passwd
To change the Administrator account password, the password of "root" is changed.
The "sudo" command gives the current user temporary Administrator access, in this instance, to change the password of "root."
First, the user will see a Unix prompt asking for the current user's password.
Type the user password for the current user account. Press the "Enter" key. Next, Unix will prompt the user for the new password for "root."
Type the new password for "root." Press "Enter." Finally, a Unix prompt will require a confirmation of the password.
Retype the new password for root, and press "Enter." The Administrator (root) account password for Ubuntu is now reset
or
Boot computer into recovery mode. Reset your computer and as it is booting, hold down the "Shift" key on your keyboard.
You will be presented with the boot menu.
Select "Recovery Mode" from the boot menu.
It is usually the the second boot option.
Wait for computer to boot up.
You will be presented with the Recovery Menu. Select "Drop to Root Shell Prompt."
Type "ls /home" and press "Enter." Note:
The command starts with a lower case L, not a capital i.
You will be presented with a list of usernames of accounts installed on the computer.
Type "passwd username" where username is replaced by the name of the account you want to reset. For example, if the username of your account was "jeff" you would type "passwd jeff" and press "Enter." You will be prompted to create a new password.
Enter a new password of your choosing.
Note: You will see no visual response when you type in your newly selected password; however, the computer still will register the input. Press "Enter."
You will be asked to retype your password.
Re-enter the same password and press "Enter."
Your password is now reset.
Type "Exit" to return to the boot menu and select "Resume Normal Boot" to restart Ubuntu.
hope this helps
Oct 02, 2012 | ValuSoft Ubuntu Linux for PC, Mac, Linux
Lap top locked wont accept usual password
When you boot up to the log in screen type in administrator as the user to log in once you have your computer running again you have to take control (administrator)control panel user accounts on the users tab,click the name of the computer administrator you can change the password there or if your computer has a system restore you can restore it to an earlier date which will have your personal settings or
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
click start control panel user accounts
hope this helps
Jan 13, 2011 | Computers & Internet
My daughter put a password on my computer and now its on a blue page asking for a password how do i rest the computer
Hi Dianegooch20
There are two types of user 1. Administrator 2. User
If you are a user and haven't set the administrator password then you can try to safe boot the steps given below
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Dec 01, 2010 | Computers & Internet
I have intalled my computer with windows xp professional before was xp, I didn't put a password or a username but now my computer is asking me to unter the password before I login!! My computer is Fujitsu...
During the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
hope this helps
Nov 29, 2010 | Fujitsu Mobile MHM2200AT 20 GB Hard Drive
My windows on the my Golf (2001) 4th Generation Gl go down when i unlock the door is this normal. Thanks
put key in door and unlock/hold key over,windows go down.key in door,lock/hold key over,windows go up/sunroof closes(if fitted)
boot lock,turn left,release boot locked.turn right, boot unlocked,locked with central locking..and unlocking/locking the car
with the key as above resets the alarm/immobilser.
BLOODY CLEVER,WHAT.....
last,sat in car with key in ignition,put your hand into open window jam and use the switch to raise window,it will stop when it touches your hand.....and bounce back.
any of your friends got a VW,makes a good party trick.
Sep 09, 2010 | Volkswagen Golf Cars & Trucks
Acer Aspire 7520 Laptop won't accept password
try typing your password in with the caps-lock on. many times this may go unoticed if both password fiels show * instead of the actual password being entered. if that doesnt work for ya go here and chose one of the 5 options to recover or delete the need for a password. you must first download these and creat an .iso disk to be run at startup.
Good Luck and dont forget to rate my post! :D
Mar 13, 2009 | Acer Aspire 7520-5185 Laptop
Troubleshooting Password Problem OS 10.4.11
Follow these steps -
1. Start up from a Mac OS X Installation CD (one with a version that is closest to the version of Mac OS X installed on your Mac).
You should first disable Open Firmware password protection, if it is enabled. Hold the C key as the computer starts.
2. From the Installer menu Choose "Reset Password" (if you have Mac OS X 10.4 Tiger this will be the "Utilities menu").
Tip: If you don't see this menu or menu choice, you're probably not started from the CD yet.
3. Select your Mac OS X hard disk volume.
4. Set the user name of your original administrator account.
Do not select "System Administrator (root)".
5. Enter new password.
6. Save.
7. Follow these instructions to set Keychain Access -
http://support.apple.com/kb/HT1631
Aug 11, 2008 | Apple Mac OS X 10.4
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
