Question about HP Pavilion dv2109nr Notebook
Media reader 5-1 rich Help
My memory card reader is not working and in the property list it shows a code ten HELP!!
  • 74 Answers
Hi
Install driver for card reader then u can able to read
Harry
Posted on Aug 08, 2009
SD memory card reader
Many HP and Compaq computers come with memory card readers preinstalled.Figure 1: Memory card reader (yours might be different)
12_26_2011_1_43_52_am.jpgMemory cards are used primarily for importing pictures from digital cameras, but they can also be useful for sharing pictures and files. The following list shows some common types of memory cards:
  • CompactFlash I
  • CompactFlash II
  • IBM Microdrive
  • Secure Digital (SD)
  • mini-SD
  • MultiMediaCard (MMC)
  • Reduced size MultiMediaCard (RS-MMC)
  • MultiMediaCard Plus (MMC plus)
  • MultiMediaCard Mobile (MMC mobile)
  • Memory Stick
  • Memory Stick Pro
  • Memory Stick Duo
  • Memory Stick Pro Duo
  • SmartMedia
  • xD Picture Card (xD = extreme digital)
NOTE: If your computer came with a 6-in-1 card reader by KYE and was purchased before summer of 2003, update its card reading firmware by using the HP Download Web Page (in English) for your computer model name. Updating the KYE firmware allows bad blocks messages to be displayed.
A high capacity SDHC card locks up or the SDHC card cannot be readMany models of PC card readers do not work with "high capacity" formats. For example, a memory card reader capable of reading a 1 GB Secure Digital (SD) card might not read from a 16 GB SDHC card.The computer might lock up when an SDHC card is inserted into a card reader that does not support SDHC. To immediately fix the lock-up, double-click the Safely Remove Hardware icon, (in the notification area in the lower right corner of the screen), select the USB card reader, and then click Stop . The card reader will not work until the computer is restarted. You can now safely remove the memory card and use the computer for other activities.To use your higher capacity memory card without locking up the computer, do one of the following:
  • If you are using the card in a camera or other device, you can attach the device to the computer using a USB or FireWire cable. When connected, most devices appear in Windows as a Removable Disk and can be used in the same way as the card reader.
  • Use a USB memory card reading device that plugs into any open USB port. Make sure the USB device can read SDHC. These devices are inexpensive and can be used in any computer that has a USB port.Figure 2: SDCH to USB card reader adapter
An SDXC card cannot be readMake sure the card reader specifically supports the SDXC format. You can access the SDXC card by using an SDXC compatible USB reader or adapter. Look for an SDXC logo on the device or check with the device manufacturer for information.
CAUTION: Never format an SDXC memory card in a non-compatible device. Doing so will make the memory card incompatible with SDXC devices because it will erase the data on the SDXC memory card and format the card for a different file system.
Card reader stops working after using Safely Remove Hardware
CAUTION: Do not insert or remove memory cards while the light on the reader is flashing. Doing so might cause loss of data on the card or might permanently damage the card reader.
The following steps explain how to use memory cards in a card reader:
  1. Insert a memory card when the light on the reader is not flashing . You can have a memory card inserted in each slot in the card reader, at the same time.An autoplay window displays. If it does not, access the card through Windows Explorer.
  2. The memory card has a drive letter, like a DVD drive or hard drive. Use the memory card as you would use any other drive on the computer. For example, double-click the memory card icon to open a new window showing the files on the card.
  3. When you have finished working with the files on a memory card, right-click the memory card icon and select Eject . Make sure the light on the memory card reader is not on or flashing when removing the card from its slot.Figure 3: Eject feature in Windows Vista
Memory card readers are devices that use the Safely Remove Hardware icon in the notification area on the taskbar). Do not click Stop in the Safely Remove Hardware window. Doing so can disconnect the memory card reader from Windows. If this happens, restart the computer to reinitialize the memory card reader.
An alternative to restarting the computer is to use the Optimize for Quick Removal feature in Windows as follows:
  1. Open Device Manager:
    • In Windows Vista, click Start c01041253.gif , and type Device Manager into the Start Search field. Click Continueif a UAC message opens.
    • In Windows XP, right-click the My Computer , select Properties from the drop-down menu, select the Hardware tab in the System Properties window, and then select the Device Manager button.
  2. In Device Manager, click the + sign next to Disk drives to display a list of the drive devices on your computer. Memory card readers are seen as drive devices in Windows.
  3. In the list of drive devices, right-click the device that has stopped functioning to display a drop-down menu (for example, Generic USB CF Reader for CompactFlash media).Click Properties in this menu.
  4. Click the Policies tab in the Device Properties window.
  5. Select Optimize for quick removal , and then click the OK button.This setting disables write caching on the device and in Windows, so the media can be removed without using the Safely Remove Hardware feature in the taskbar. The card reader might experience a minor drop in device performance.Figure 6: Optimize for quick removal setting
Memory card icons are missing in WindowsIf you cannot access the memory card, or the drive is not listed in My Computer, use the following steps until the drive displays:
NOTE: If you are using a card reader that did not come with the computer, contact the manufacturer of the adapter for help.
  1. Remove and reinsert the memory card.If the AutoPlay window opens or if the memory card is now listed in the Computer window, you are done. Otherwise, continue with the next step.
  2. Restart the computer.If the AutoPlay window opens or if the memory card is now listed in the Computer window, you are done. Otherwise, continue with the next step.
  3. Reinstall each memory card device using Device Manager:
    a. Remove all memory cards, and unplug all USB storage devices from the USB ports.
    NOTE: Make sure you remove all USB devices.
    1. In Windows Vista, click Start , type Device Manager into the Start Search field, and press Enter .In Windows XP, click Start , right-click My Computer , select Properties , click the Hardware tab, and then click the Device Manager button.
    2. Click the plus sign next to Disk Drives to open the category.
    3. Right-click a "Generic" card reader device name and select Uninstall .Figure 7: Device Manager in Windows XP (Windows Vista is similar)
    1. Wait until Device Manager updates the list, removing the name of the Generic device.
    2. Continue uninstalling Generic card reader device names until they are all removed from the list.
    3. Restart the computer and use the card reader. If problems persist, continue to the next step.
  1. Try another memory card of the same type in the same slot. If this memory card works, the card reader is working correctly. Replace the original memory card. If the second memory card does not work, continue using these steps.
  2. If you are using Media Center, remove the memory card, maximize the Media Center window, and reinsert the memory card.
  3. Turn off the computer, disconnect the power cord, and press the power button on the front of the computer for five seconds. Reconnect the power cord and turn on the computer to test the card reader.If the AutoPlay window opens or if the memory card is now listed in the Computer window, you are done. Otherwise, continue with the next step.
  4. Some memory card readers use support USB devices. Insert a USB device into an open USB port to test whether the card reader can read from the USB device. If the device works correctly, continue to the next step. If the USB device also fails, there is a problem with USB.
    1. Turn off the computer and disconnect the power cord. Then shine a flashlight into the empty card slots in the card reader to see if any pins inside are bent. Straighten any bent pins with the end of a mechanical pencil. Replace the memory card reader or have the computer serviced if a pin is bent and is touching another pin.If the AutoPlay window opens or if the memory card is now listed in the Computer window, you are done. If there were no bent pins, continue to the next step.
    2. The memory card reader software is usually set up through a plug and play process in Windows. Some computers that came with Windows XP and built before 2003 might come with separate software for the memory card reader. If so, reinstalling the memory card reader software and then restarting the computer can fix problems with the memory card driver. To reinstall the card reader driver on HP and Compaq desktop computers, see the HP support document, Using Recovery
      10 Reset the cable connections and memory card firmware:
      1. Remove the side of the computer case by unscrewing the two retaining screws on the back of the computer and sliding the side panel towards the rear of the computer. Set the panel aside.b.Find and disconnect the cable from the back of the card reader and leave it disconnected.Figure 8: One type of connection on the reader (your computer might be different
12_26_2011_1_55_53_am.jpgMake sure that the other end of the cable is correctly connected to the motherboard or an electronic card connected to the motherboard. Make sure that the unconnected end of the cable is not touching any electronics or components inside the computer, particularly the fans.Figure 9: Connector on the motherboard (your computer might be different)
  1. Replace the computer side panel and turn on the computer.
  2. After Windows starts and the desktop displays, wait about five minutes for Windows to make the necessary hardware changes.
  3. Turn off the computer and remove the computer side panel.
  4. Reconnect the cable into the back of the card reader, replace the side panel, and turn on the computer.
  5. Check to see if the drives appear in My Computer or Windows Explorer:
    • If the memory card drives appear in Windows and work correctly you are done.
    • If the memory card drives do not appear in Windows, the drive might need to be serviced or replaced.Memory cards appear in Windows but errors occur when writing or readingIf you are having problems reading and writing data to memory cards, use the following troubleshooting tips:
      • Try a different memory card of the same type in the same slot. If this memory card works, the card reader is working correctly. Replace the original memory card.
      • Some cards have a read/write security switch on the card. Make sure the switch is set to Write Enabledbefore trying to write data to it.
      • Make sure that the amount of data you tried to store has not exceeded the capacity of the card.
      • Inspect the ends of the memory cards for dirt or material closing a hole or spoiling a metal contact. Clean the contacts with a lint-free cloth and small amounts of isopropyl alcohol. Replace the memory card if necessary.
      • Make sure the memory card is supported by the card reader.
      • Make sure the memory card is fully inserted into the slot.
      • Remove the memory card when the light is not flashing and shine a light into the empty slot to see if any small pins inside are bent. If the pins a slightly bent, turn off the computer and straighten them with the tip of a mechanical pencil. If two of the pins are touching, replace the memory card reader or have the computer serviced.
      • If errors continue, replace the memory card.
Dec 25, 2011 | Computers & Internet
Blackberry Bold 9700: "Media card
You need to get a reader/writer like this one;
http://www.newegg.com/Product/Product.as...
I use this one because it support all the latest formats. Older readers might not read the SDHC (High Capacity) format and you don't nead that. Pop the reader into a USB port and the card will show in File Explorer just like a hard drive. Right click it and select Format. Go with FAT32 format for most storage cards.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 13, 2011 | SanDisk 8GB microSDHC Memory Card with...
My phone memory suddenly showing 3.3GB and all themes,games,wallpapers were deleted and ono folder with noname is showing 3.3GB in gallery.When i try to open music player it is not working and showing not...
Hi, I would like to help you out. I believe you are talking about memory card not the phone memory (which is 30mb)
The symptoms you said shows that your memory is infected by virus. You can recover your memory card but there will be data loss. Put your memory card in a media card reader and insert it in laptop then format it completely.
This will definitely resolve the issue:)
Please let me know if you need more help. Good luck
And also vote if you think this solution will help others.Thank you:)
Oct 30, 2010 | Nokia 5130 Cellular Phone
Ive put a card in my viewty to boost memory but when i tried to format it asked for a code so a put 0000 in and it started to format then stopped and now the external memory isnt showing .... HELP!!!!
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jan 20, 2010 | LG KU990 Viewty
    Music Player
    Connect the phone to a PC using Nokia PC Suite software or the memory card to a memory card reader.Browse to the location where the  media files are stored. Select all the songs by pressing "ctrl+A" and right click and take "Properties"In the Genetral tab, untick all the attrib value.then press " Apply " then "OK".
    That's it.
    and rename the folder which contain your media files to "My Music".Ignore this if it has been already done.
    Your phone only support  polyphonic, MP3, AAC files.Make sure they are MP3 or ACC media files.
    Start your phone with the memory card inside and update your music library list.
    You will find your favorite music there.
    Note :  Some mobile doesn't support very long media files name.
    Dec 16, 2009 | Nokia 3110 Cellular Phone
    Can't find hidden media folders
    Follow these steps to hide or show pictures on the BlackBerry smartphone:
    1. On the Home screen of the BlackBerry smartphone, click Media.
    2. Go to Pictures.
    3. Open the picture that you want to hide.
    4. Press the Menu key and click Properties.
    5. Select the Hidden check box and click Close.
    Follow these steps to show a picture on the BlackBerry smartphone:
    1. Click Media.
    2. Press the Menu key and click Explore.
    If the picture is in Device Memory,
    1. Click Device Memory.
    2. Press the Menu key and click Show Hidden.
    If the picture is in Media Card,
    1. Click Media Card.
    2. Click BlackBerry.
    3. Press the Menu key and click Show hidden.
    Additional Information If the computer is set to Show all hidden files and folders, the BlackBerry smartphone user should be able to view all hidden pictures by using Roxio® Media Manager. However, pictures cannot be hidden or shown using Roxio Media Manager. If a picture is on a media card and the computer is set to Show all files and folders, pictures can be viewed, hidden and shown by using the removable disk drive.
    Sep 12, 2009 | RIM BlackBerry Pearl 8100
    My n 73 phone keeps showin memory full message,even though my inbox is empty and i have free space in my memory card.help.is it a virus
    make sure your message memory is memory card. messga-option-setting-other-memory in use-memory card.
    and try to free phone memory or better restore to factory setting. *#7370#
    Aug 04, 2009 | Nokia N73 Cellular Phone
    Formattin sandisk
    hi
    1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
    2. 2 Open up 'My Computer'. You should see it under the list of available drives.
    3. 3 Check its contents first to make sure that you have the right drive.
    4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
    5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
    6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
    Jul 16, 2008 | SanDisk Memory Media
    MMC card support in compaq
    Well basically what you do is
    1.) connect your memory card reader
    2.) install the necessary drivers
    3.) insert the memory card and it should show up as a removable disk in my computer similar to that of a pen)flash) drive
    If the card reader is built into the computer then simply ensure the necessary drivers are installed (right click computer and select properties, then click device manager , it will show up in the list, if it has a yellow maker then it has a problem if its a question mark then it aint installed) if you dont have the drivers get them from the manufactures web page. IF everything checks out ok then put in the memory card and it will show up as a removable disk in my computer..
    If you dont have a memory card reader or dont have the card reader built in then you will need to purchase one.
    Jun 29, 2008 | HP Compaq Presario V6000T Notebook
    Acer aspire 5610z card reader
    goto to start menu
    click on my computer--this will show all drives and devices
    find your media reader drive
    right click on that--goto properties
    click and you'll see different tabs, so go thru each of them
    and try to restore all defaults--
    not sure what os you are running on so let me know if i was of any help to you.. thanks, d
    Feb 27, 2008 | Acer Aspire 5100 Notebook
    HP Pavilion dv2109nr Notebook Logo
    73 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
