Question about Home
Long beep problem when I turned on my computer
    Scholar:
  • 76 Answers
Not the right category for computer but a beeping computer on switch on usually means the memory module is not present or not working.
A continuing beep beep beep memory missing.
One long continues beep that stops and the computer then works could be anything normally the PC is looking for something can’t fined it and moves on.
If you are concerned restore the system to a previous time i.e., prior to the beep starting to happen.
Posted on Sep 13, 2010
Computer won't come on
All computers have beep error codes, if you provide the following details I may be able to help.
1 Make and model of PC
2 error code ( you can count the code for example: 123 could correspond to
Beep - pause- beep beep - pause - beep beep beep
3 does the fan turn
4 does the monitor turn on ok
5 can you hear the hard drive an DVD rom spin a little then go quiet or do they spin and then chuntle on for a little while
Nov 25, 2016 | Computers & Internet
When rebooted computer beeps 3 times and will not turn on
Is it a long beep or a short beep? Beep codes are used by the BIOS during the POST to report certain initial system errors.
If you're hearing beep codes after you turn your computer on, it typically means that the system has encountered some kind of problem before it was able to display any kind of error information on the monitor.
Follow the steps below to determine what system problem the beep code is representing.
Difficulty: AverageTime Required: Anywhere from 10 minutes to a few hours depending on the cause of the beep code
Here's How:
  1. Power on the computer or restart it if it's already on.
  2. Listen very carefully to the beep codes that sound when the computer begins to boot.
    Restart your computer if you need to hear the beeping again. You're not likely to make whatever problem you have worse by restarting a few times.
  3. Write down, in whatever way makes sense to you, how the beeps sound.
    Important: Pay close attention to the number of beeps, if the beeps are long or short and if the beeping repeats or not. There is a big difference between a "beep-beep-beep" beep code and a "beep-beep" beep code.
    This is all important information that will help determine what issue the beep codes are representing.
  4. What steps you take to solve a particular beep code will differ depending on the BIOS manufacturer.
    Choose the correct beep code troubleshooting guide below based on your motherboard'sBIOS manufacturer:
    Tip: Not sure what brand of BIOS is on your motherboard? See this How To Determine Your Motherboard BIOS Manufacturer guide for some helpful advice.
Tips:
  1. Still can't figure out what the beep codes mean? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum.
Jan 03, 2013 | Dell Precision T5500 Computer Workstation ...
HP desktop computer makes many long beeps i a row and won't turn on
Those beeps are warning beeps look up what the beeps mean for your machine.
Jan 02, 2013 | HP Computers & Internet
Computer will turn on but will not boot up
Dear,
Did this situation come with any beep sound. Because, most of the time, in this situation; the computer beeps. Here are some codes. Check if any of these condition apply to your system.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Gateway 510XL (2800446) PC Desktop
I have a ASUS P8P67 LE motherboard, intel i5 - 2310 processor, kingston DDR3 RAM and ASUS ENGTX560 DC/2DI/1GD5 graphic card. When I turn on the PC i get one long and then three short beeps, and the...
> one long and three short BEEP
Something is wrong with some of your hardware.
Turn the computer off.
Disconnect the AC power.
Remove the graphic card.
Connect the AC power.
Turn the computer on, to see if the pattern of BEEP has changed.
Remove the RAM -- all of it.
Reinsert one stick of RAM.
Reinsert the graphic card.
Jul 16, 2011 | ASUS P8P67 LE LGA 1155 P67 SATA 6 Gbps and...
Ive got a long continual beep and it emits orange light from the front and back of the computer how am i to fix it?
Unplug the power cable.
Remove the video card.
Remove the RAM.
Re-insert the video-card, ensuring that it is "seated" properly.
Do NOT re-install the RAM, just yet.
Connect the power cable.
Turn the computer on.
If you get a different "beep", the lack of RAM is the problem.
If you get the same "beep", the video-card is the problem.
Disconnect the power-cable.
Re-install one stick of RAM (two if it is RAMBUS/RDRAM).
Reconnect the power-cable.
If it beeps "normally", then the not-yet-installed RAM is the problem.
If it still "long-beeps", turn the computer off, disconnect the power-cable, and remove the RAM, and insert the "other" stick/pair of RAM.
Reconnect and start it up.
If still a problem, change the video-card.
Dec 02, 2009 | Dell PowerEdge 1800 Server
Hardlocked;beeping and red light on motherboard;will not restart
Something on the motherboard has failed, and the RED light confirms it.
Turn your computer off.
Remove ALL of the RAM. Turn your computer on.
Do all the fan(s) start to spin?
Do you get the _same_ "beeps" as before, or some different pattern of beeps?
If it has more than one stick of RAM (and the RAM is _NOT_ labelled 'DDR2'),
then remove all but one stick of RAM, turn your computer on, and try to reboot.
Same beeps?
Turn your computer off, try a different single (or pair of) sticks of RAM.
Caution: before doing any of the above, your computer could be within the "WARRANTY" period,
i.e., it could be fixed/replaced for free!
May 26, 2009 | Abit GD8 Motherboard
Black screen when i turn on the computer
post comment in my yahoomail so thAT i can kep in touch with you!!sergio_bonjovi@yahoo.com
when you turn on the computer does the computer beeps?how many times does it beeps? when your computer beeps 3 times faster..try to check you video card!!!! but when the computer continues to beep and beep try to check the modules or the memory try to replace it with a new memory!!! but when you turn on your pc and no beep at all your motherboard will be the problem?so did i answer your questions?
Apr 25, 2009 | Compaq Presario 5000 PC Desktop
Motherboard message LED message is --
Your motherboard has died .
No beep code explains it all .
LED lights and even fans spins only tells me that your getting power to the motherboard , but No beep code is crucial .
Every motherboard will beep once when your first turn on and beep once again before the Opertional System boots up .
Sorry again for your loss ...
Aug 07, 2008 | Evga nForce 680i SLI (122CKNF68)...
Home Logo
74 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
