Question about Printronix Line Matrix P5005B Printer
A have printronix p5005 printer but printout not clear
  • 96 Answers
Remove the black cover over the shuttle and look for a phase number hand written in blue marker on the right side of shuttle. Press the up and down arrows at the same time to unlock the control panel. Press left arrow to go to diagnostics. Down arrow and right arrow until phasing. Set phasing number same as what was written on shuttle assy.If it is making noise then the shuttle is bad.
Posted on Oct 13, 2010
Printronix error b22 decompressed size
flash ic having problem logic crad have to change
Feb 04, 2014 | Printronix P7005/p7010/7205 Ultra Capacity...
The printout is not clear what could be the problem
Hi
It could be that your ribbon has dried out after time or your head gap setting are incorrect.
Please contact your closest service centre to measure the head gap.
Thanks
Jan 23, 2014 | Printronix Office Equipment & Supplies
Printronix p5005 version 4 firmware
go to manufacturer site & download 364221.exe file
Jan 18, 2013 | Printronix Office Equipment & Supplies
Printronix p4280 making noise
Depending on the specific circumstances, of course, the most likely culprit is the shuttle assembly. It could either be the motor in the assembly or the bearings in the shuttle assembly.
Put in hold mode. (Press Enable/Hold button)
Remove the shuttle cover assembly. (leave the screws in the cover itself when you remove it). On the middle-right side you will see a cover sensor -- you will need to fool this with a magnet.
Run a test print (Print Test button). (With the hood up/) Listen for the source of the noise. Is it the motor or the shuttle assembly bearings. (If the noise stops when you turn off test print and the motor is winding down then it is the shuttle assembly bearings.) Or is the noise elsewhere?
If elsewhere move around side to side to differentiate and locate the sound.
Here is a link to the part of the manual that describes replacing the shuttle assembly.
Please note that the motor itself is not really considered a separate field replaceable unit -- it is considered a part of the shuttle assembly. I only mentioned it separately above as part of the troubleshooting to consider the noise source. http://www.theprinterplace.com/printronix/P4280_Shuttle_Replacement.pdf
Jul 21, 2012 | Printronix P4280, P5005, P5008, P5009,...
My Printronix P5005 is having problem in printing setting. it prints out of paper. i want to adjust its printer setting. please guide me how i can change printer setting. thanks Tahir
tell me its graphics printing or plain Text... if plain text then change CPI like 15Cpi / 17.1Cpi / 20Cpi/ and also change Ignore CPI in Hosts menu...for graphics u can;t do anythigns..
Jan 27, 2011 | Printronix Line Matrix P5005B Printer
How do i clean the print head to a good printout
This is a Thermal Printer, which means it uses tiny hot wires to create dots on special paper to form the characters. There may be little to nothing you can do to make output better. You can try unplugging the unit from the power source and using a cotton swab dipped in alcohol to clean any paper fibers or residue from the face of the print head. More likely than not however is the possibility that you will have to have the print head replaced in order to restore crisp printouts. These print heads, much like the older dot-matrix print heads, have a limited lifetime because of the way they function.
Nov 20, 2009 | Printronix T5000 Thermal Printer
My printer not printing a one column of the paper
if your printer is line matrix p5005 model then the problem is only regarding the hammer module so for that open the shattle and the check whether the module is ok if it is then cleaned the surface of module with soft cloth and again place the module properly and tight the screw and then only check. u can do one more thing u can use the all black command also . from pankaj
Aug 28, 2009 | Printronix Line Matrix P5005B Printer
Problem in printing in Windows
tell me which model do u have and which Operating Systems you are using..
Apr 10, 2008 | Printronix Refurbished P5212 DOTMATRIX...
Printout problem
i need driver fover for priner p 500
Mar 06, 2008 | Printronix Line Matrix P5005B Printer
Printronix Line Matrix P5005B Printer Logo
321 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Cliff
Nick
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
