I burned a dvd in Pinnacle Studio Plus 11. I know stuff burned to the DVD, but it won't play on the computer or in the DVD player. Does Pinnacle not finalize the DVD, could that be why it's not playing? Or is there another potential problem? It was a DVD -R. I know that the DVD player plays those types of DVDs.
Be sure to check if there is a file written on the DVD disk. Try to install a player like VLC and see if the .VOB file is playing.If not the DVD is not burned properly then try to recheck your settings on the Studio 11 Make Movie
Posted on Sep 13, 2010
I can not play my dvd on sony dvd player i get message canot play.i have a sony dvd recorder in which my laproscopic surgeries are recorded.if i play my unedited dvd on player it runs or plays very well...
My guess is the Pinnacle software isn't writing correctly. Read this from the Pinnacle support site.
Use this FAQ to troubleshoot any problems where Studio is failing during the process of burning the DVD.
  1. INSTALL THE LASTEST PATCH:
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
Note: Studio 11 patches will only patch a previous install of Studio 11.
If you have an older version of Studio (Studio 9, 10, or 11 etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
  1. MAKE DISC SETTING, SAFE MODE BURN OPTION: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Safe Mode: create disc content and then burn" by clicking on the radio button in front of the setting and then click OK. While troubleshooting this problem, always use this setting.
  1. RESTART STUDIO: Shut down Studio, then relaunch it. Try to create the DVD again using the safe mode setting above.
  1. RESTART THE COMPUTER: Try opening the door of the DVD burner. If it won't open, then shut down Studio, then restart the computer. Launch Studio and try to create the DVD again using the safe mode setting.
  1. MEDIA:
BLANK MEDIA IN THE DRIVE: Make sure that there is a blank, write-once media or rewriteable media in the DVD burner.
TYPE OF DVD: Make sure that your DVD burner supports the media you use. As for any problem with burning a DVD, we recommend customer use rewriteable media to reduce the number of wasted DVDs when they have to troubleshoot a failure while burning DVDs. In this case, if you have only used rewriteable media, (RW) we would also recommend trying to use a write once (-/+ R) DVD and erasing the RW media.
BRAND OF DVD: Pinnacle recommends using a name brand of DVD, i.e. Sony, Apple, Memorex, etc. Also we recommend trying a DVD from a different manufacturer to see if the problem is related to the brand of DVD that is being used.
NOTE: Check with the following site to find information on the media being used.
http://www.videohelp.com/dvdmedia
  1. LOWER THE WRITE SPEED: In the Make Disc settings try lowering the Write Speed to the lowest possible setting.
  1. GET THE LATEST FIRMWARE: Ensure that the DVD burner being used has the latest firmware update from the burner manufacturer.
  1. CHECK DISC SPEED: Make sure that the disc media speed (printed on the media or on the media box) is compatible with the DVD burner. Some burners may not work with media that has a higher maximum supported burn speed. For example, if the burner being used supports 4x disc media, do not use 16x disc media.
  1. DELETE AUXILIARY FILES: Try deleting the Auxiliary Files for the current project. To do this, go to File -> Delete Auxiliary Files and select "Delete auxiliary files for current project." Press OK and try to re-render and burn the project.
  1. ALWAYS RE-ENCODE: Go to the Make Disc settings and check the box called "Always re-encode entire movie".
  1. SAFE MODE: Try burning with the safe mode option selected. To do this, go to the Make Disc settings. In the Burn options are select the option called: "Safe mode: create disc content and then burn.". This step does not apply if you are using Studio 12 since this is the default burn method.
  1. CREATE A DISC IMAGE: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Create disc content but don't burn" by clicking on the radio button in front of the setting and then click OK. Then click the Create disc button in the Make Movie section to begin the image creation process.
    If the image is not created, it is likely that the problem is a Render problem rather than a burn problem. Click Here to see the FAQ on Render problems.
    If the disc image file is created successfully, burn the disc from the new disc image by selecting "Burn from previously created disc content" in Burn Options.
    NOTE: When troubleshooting all burn or playback issues, it is recommended to use rewritable media to avoid wasting discs.
Nov 04, 2010 | Sony DVP-NS530 DVD Player
Pinnacle S 10.7 DVD plays for for 15 min plus and then image free
Unfortunately I do not know what a prosumer is (do you mean producer?) but what I would do is produce an image file rather than write direct to disc and then use nero or imgburn to burn the disc.(I prefer Imgburn and not just because it is a free open source prog).
Give it a go and get back if the problem remains.
Jul 08, 2010 | Pinnacle Dazzle DVD Recorder
Dirty disc message
You might miss match the file associations while burning them as movie dvd (ie if you have the extension like making a movies cd of the file extension like .fly,.mp4,.3gp,etc...) makes a dirty dvd disc in dvd player it can only be readable under the computer in some cases. Try to read it in a system and convert it into .mpeg extension by total video converter available at http://dw.com.com/redir?edId=3&siteId=4&oId=3001-2194_4-10429299&ontId=2194_4&spi=54bb6302e3f8eb192d7c4d5e103edc96&lop=txt&tag=idl2&pid=11366878&mfgId=105109&merId=105109&pguid=Q7DsewoPjGEAAHsRE5EAAAEz&destUrl=http%3A%2F%2Fsoftware-files-l.cnet.com%2Fs%2Fsoftware%2F11%2F36%2F68%2F78%2Ftvc.exe%3Fe%3D1274206388%26h%3D61a08d8270b9777c717edcb3bb514fd4%26lop%3Dlink%26ptype%3D1901%26ontid%3D2194%26siteId%3D4%26edId%3D3%26spi%3D54bb6302e3f8eb192d7c4d5e103edc96%26pid%3D11366878%26psid%3D10429299%26fileName%3Dtvc.exe & burn it again as dvd format. It will now played in most of player.
May 18, 2010 | Pinnacle Studio Plus Version 11
Pinnacle studio 12 .stx fil
Hi and welcome to Fix yah,
I would suggest to you to finished edit your project and after that click on make movie tab or the number 3 tab of your Studio then do this procedure.
Disc Type : DVD
Audio Compression : PCM
Video Quality : Automatic
Use Progressive Encoding : NOT checked
Always Re-encode Entire Movie: Checked
Burn Options: Create Disc Content and then burn.
Current Media : Should show what DVD Disc should be used.
Target Media: DVD 4.7 GB
Copies : 1
Write Speed: lowest possible
Let me know what happen.
Feb 14, 2010 | Pinnacle Studio Plus Version 11
Pinnacle 11.1 user dvd drive went bad /replaced dvd drive . since
Hi and Welcome to Fixyah,
What do you mean by this? what is the error message when trying to burn your project using Studio 11? Please reply back here.
Jan 04, 2010 | Pinnacle Studio Plus Version 11
After burning the DVD once,
Several possible solutions.
1. If you are using DVD-R discs, your player probably does not support them. There are known compatibility issues with DVD-R discs. If your burner supports it, use DVD+R discs.
2. Try burning at the slowest possible speed. That can help your player pick up the disc better.
3. Did you remember to put a menu in the beginning of your movie? Even if you have the disc set to skip the menu when inserted, it still must exist for some DVD players to recognize it as a disc and play it.
May 31, 2009 | Pinnacle Systems Studio AV/DV Version 9...
Studio 11 want allow me to burn my project to dvd
I suggest to render the project to a video file first avi conversion to isolate the case. Once you have finish import the AVI file in the pinnacle did try to create now the dvd disc so that the rendering process will be fast since that you already have the file not the project.
Jan 05, 2009 | Pinnacle Studio Plus Version 11
The durabrand 1700
It could be the codec u use to encode the movie,
secondly could be a firm ware problem of your dvd player.
Other than this I can't think of any other reason. or just may be the type of recoreder u use or the recoding programe. If u had check these, then get another player
Sorry, this is all I can think of.
PS. the player firmware is the main reason to me.
Cheers
Rifaa
Nov 18, 2008 | Durabrand PDV-705 Portable DVD Player
A DVD burned with Studio 10.8 plays on our stand alone DVD player, but it won't play on our computer.
check what mode the cd video is you may have to burn another one with the correct mode for pc
Right click program on cd go to properties check video name plus what is after the . ie home.wmv as you need to burn cds with a general code
Try VLC Media Player on computer this plays all my video media
Jul 22, 2008 | Pinnacle Systems Studio AV/DV Version 9...
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
