Question about Canon ImageRUNNER 3570 Copier/Printer
My canon ir 3530 give light print at the top and bottom part of the page. Drum with 4000 copy, charging roller cleaned with dry cloth,drum also cleaned, dp box cleaned thoroughly and installed with new ink but the problem is same. pl help
  • 461 Answers
SOURCE: Buying and replacing just the transfer roller on a Dell 5110cn
Maybe if you call you can order just the transfer roller. You could try removing it and cleaning the ends (to provide better electrical contact). You could also try wiping the roller itself with a lint free dry cloth - but do so at you own risk and never touch the roller with your fingers!
Posted on Dec 09, 2008
SOURCE: canon IR C3220 cannot print multiple pages..ONLY able to print one page
I had same problem with my Canon pixma ip4600 and 4300, it works fine on one of my laptop that has XP but will only print one copy at a time on my laptop with Vista. After a long time playing around with it I found if i set the printer setting range to print pages 1 to 1 ( or 1 to "number of pages in doc"), then put in how many copys you want and click collate.
It worked for me so hope this helps :)
Posted on Oct 11, 2009
canontech
  • 1219 Answers
SOURCE: CAN I RESET A DRUM LIGHT ON FOR A CANON IR 1600?
Take out the drum.
Open the "cork" on his top side an vacume the waste toner.
If you have E100 error you must replace it, if not, must work
Posted on Jan 14, 2010
shawn38
  • 200 Answers
SOURCE: Kyocera fs 4000
(1) Detaching and refitting the drum unit
Procedure
1. Remove the developer unit (See page P.1-5-
9).
2. Open the left side cover and then remove
the waste toner box.
3. Unlock the drum unit lock and then remove
the drum unit.
4. Check or replace the drum unit and refit all
the removed parts
(1) Detaching and refitting the transfer roller and separation charger brush unit
Procedure
9).
2. Remove the drum unit (See page P.1-5-10).
3. Slide the paper chute guide and unhook the
hooks.
4. Remove the paper chute guide.
5. Remove the shaft (transfer roller) from the
both bushes.
6. Release the four latches and then remove
the separation charger brush unit.
7. Check or replace the transfer roller and separation
charger brush unit and refit all the
removed parts.
CAUTION: Note the following, when refitting
A. The separation charger brush unit is
inserted into the two projections of the frame
and does not run on to the projections.
B. The separation charger brush unit is
firmly in contact with the separation charger
plate of the frame.
(1) Detaching and refitting the paper feed assembly (paper feed roller and pickup roller)
Procedure
1. Remove the paper cassette.
2. While pushing the lock and then slide the
paper feed roller pin.
3. While pressing the lever and then remove
the paper feed roller assembly.
4. Check or replace the paper feed assembly
and refit all the removed parts.
(2) Detaching and refitting the ****** roller
Procedure
2. Push the bottom plate down until it locks
(30/31 ppm printer [EUR/USA model] only).
3. Unlatch the two latches and then remove
the ****** guide.
4. Remove the ****** holder (roller) from the
****** guide.
5. Check or replace the ****** roller and refit all
the removed parts.
Posted on Feb 19, 2010
canontech
  • 1219 Answers
SOURCE: canon ir 3530
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Posted on May 04, 2010
Canon ir3300 printing black dots on bottom of paper
Dear
A scan copy of the printing and information on paper setting would bet better to understand. however the dots appeared at bottom may cause due to the drum unit corrosion or spots on its surface. Try to clean drum and PCR roller with cotton cloth dampen with isopropyle alcohol. and warm up with rubbing dry cotton on the surface of PCR and drum. Note don't work with direct light or sun light.
Try to clean the transfer roller with soft brush.
Thanks.
Feb 07, 2015 | Canon IR 3300 Digital Copier
What are the steps to solve light copies with canon ir 1024 copier
Did you clean the optik lens,mirrors...?It may also be a transfer roller,try to clean or replace it.
Sep 03, 2014 | Canon IR-1022 Copier
When i print more than one pages. the 2nd page and later will always have shadow from previous page printout.
Drum Unit is not cleaning.
Either is not producing the right charge in the corona wires
your wiper blade is not functioning or the roller speed/ fuser speed is not correct
easiest solution clean drum with dry cloth
order maintence kit and replace rollers
next order new drum unit
order new fuser
Oct 28, 2013 | Samsung CLP 315 Laser Printer
Sharp 1641cs - Dark/black page after replacing drum & toner
Hi you have not said the toner type you replaced with though that will give not completely black copy. The problem may have been the drum unit installation. Make sure the charge unit over the drum service is present ie the one with a mesh wire like grid. If present, clean it or wipe with a soft clean and dry cloth. Clean the saw-tooth like metal plate inside that unit by slow blowing and make sure no toner particles are there. Finally screw the unit properly on the drum unit and your problem is solved.
Jan 11, 2013 | Sharp AL-1641CS All-In-One Laser Printer
Ir 6570 copy light
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder
May 07, 2012 | Canon Office Equipment & Supplies
Dell 1815dn - when faxing, the fax goes through but all pages are black. when attempting to scan, pages are black. when trying to scan to a PDF file, the file is blank or black.
Welcome to Fixya
Try to print a document and see if you will be getting same issue. Try to copy a document and see if same thing will happen also. Check if the cartridges are not running out of ink.
Thank you for using Fixya!
Aug 02, 2011 | Dell 1815dn All-In-One Laser Printer
I have a 2590MF, when i print colour pics there are streaks on the printed area - running from top to bottom. This does not occur when printing B&W. Does the drum need to be replaced?
Dirty print out is basically due to cartridge related issues. Take out the cartridge and clean its drum/ (green roller) with a dry, soft, lint-free cloth. The drum is usually located under a cover. Checkout for any spilled toner inside the printer and clean it also. Print a few pages so that the parts get further cleaned. I think, this would solve the issue. (This may help temporarily)
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge.
So, it is recommended that you replace the cartridge with a genuine one (not any replacement or refill).
Let me know if any further clarification is required.
Hope it helps! Good Luck!
CreativeTECH
Apr 08, 2011 | Konica Minolta magicolor 2490MF Laser...
I have an IR2200. At the top of the page, there are black dots. There are 3 lof them and they are about 1 in apart. Could someone please tell me how to fix this myself with out calling for service?...
try to print something out.If the dots arent on the printed page, that means that you need to clean the optics ( beneath copy glass ).
If you are not able to print, open front cover, realese the blue handle for duplex, release the handle for toner station, unscrew one screw on front of drum unit, remove drum unit and check for dots on drum surface, or for damadges on charge roller ( the black/grey roller on top of drum ).
Its probably drum unit fault, but it also can be fixing film in steak.
hope that helped
Aug 02, 2010 | Canon imageRUNNER 2200
Copy light
hi,
did you try to print something from pc? Are the print is ok? If the print is ok and copy is not ok, clean the copy glass.
If your copy and print are not ok, clean the laser unit, check the transfer roller and contacts, check the developing cylinder and contacts,... and try with new drum UNIT!
Nov 26, 2009 | Canon iR 2020i Laser Printer
Black lines on copies
Have you cleaned the optical path and the laser cover glass? Remove the glass and clean all the mirrors with a soft lint free cloth. Do not use and sprays or cleaners, just a dry cloth. Clean the scanner bed and the glass for the ADF if it has one.
Sep 14, 2008 | Ricoh Aficio 2018D All-In-One Laser...
151 people viewed this question
old marine
old marine
