Question about Crunch PZI250.2 Car Audio Amplifier
I do not have the manual. I need wiring diagram how to connect to the power and speaker.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Crunch Master
  • 2,226 Answers
If you need a manual to hook up an amp, you probably shouldn't be doing it yourself.
Posted on Sep 13, 2010
Need wiring diagram for Kenwood KDC-X679 CD receiver for my 1997 Chevy truck
The manual for the Kenwood Excelon KDC-X679 has the wiring diagram for the connections to the car/truck on page 33. Crutchfield has the manual on the product page: http://www.crutchfield.com/S-FpCU7SY0yQm/p_113KDCX679/Kenwood-Excelon-KDC-X679.html . (Click on the Details tab.) The direct link to the manual is http://pdf.crutchfieldonline.com/ImageBank/v20050828082600/Manuals/113/113KDCX679.PDF .
Kenwood also has the manual on their support page: http://manual.kenwood.com/en_contents/search/ . Just enter the model number. On this site, you can find the manual is several languages. The direct link to the English version of the manual is http://manual.kenwood.com/files/B64-2764-00.pdf .
I hope this helps.
Jan 30, 2016 | Kenwood Car Audio & Video
Model dnx6160 double din. What is the wire color code?
The wiring diagram & color code are in the installation manual which is available from Kenwood on the DNX6160 product site: http://www.kenwoodusa.com/DNX6160 . Click on the Manuals tab. The direct link to the manual is http://manual.kenwood.com/files/52d633463466d.pdf . See pages 4-5. Page 4 has the wiring for power, ground and other connections to the car's wiring/sensors. Page 5 has the speaker wire diagram. Page 6 has the diagram for connecting other devices to the GPS navigation system.
I hope this helps.
Nov 18, 2015 | Kenwood Car Audio & Video
I am changing out a Clarion ARX7570z to NZ500. Have most of the bugs worked out but I need a wiring diagram for the ARX to figure out the which wires are which. HELP!
the wiring diagram is out dated for the cassett player ....
here is what i know
red is ignition swichted
yellow is contstant power
black is ground
blue power antenna
blue with white strip amp turn on
gray + f right speaker
gray/black strip - f right speaker
white is + L front speaker
white with black strip is - L front speaker
green is + L rear speaker
green with black strip - L rear speaker
purple is + r rear speaker
purple with black strip - r rear speaker
your orange with white strip is illumanation not used
100% of all aftermarket radios are color code this way if you have install diagram for new radio it will be the same as old clarion radio ..
but make sure u have a digital volt meter to check power on red and yellow wire and comming from the factory harness be for you connect new radio just to make sure it does have powers and check other wire for power also just so you dont blow up new radio ... you can blow up a radio by connecting a wrong wire faster than you can blink your eyes ..... if you need a wire diagram for you modle car email me with it a http://www.tintingbyfredjohnson.com and go to contact and send email
Dec 28, 2010 | Clarion ARX7570z
Just need a pic to see what color wire goes to each of the 20 pins on the back of the deck
Wiring Diagram / Color Codes
1. Power Antenna (dark blue wire) - Connect to power antenna or amplifier.
2. Ground (black wire) - Connect to ground terminal or clean, unpainted part of chassis.
3. Memory/Battery (yellow wire) - Connect to battery or 12 volt power source that is always on. The radio will not work if this wire is not connected.
4. Accessory/Ignition (red wire) - Connect to existing radio wire or radio fuse.
5. Left front speaker - White/Black is negative, White is positive
6. Right front speaker - Gray/Black is negative, Gray is positive
7. Left rear speaker - Green/Black is negative, Green is positive
8. Right rear speaker - Violet/Black is negative, Violet is positive
9. RCA Outputs to Amplifier - Black is front, Gray is rear
10. Auxiliary Input Cable
11. Subwoofer Output
12. Antenna
13. CD Changer
The manual is available here:
http://diversesolutions.org/files/CD4610.pdf
The wiring diagram is under the section Wiring.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 13, 2010 | Jensen CD4610 CD Player
I have a sony car stereo that was given to and I lost the manual to wire it and don't want to take a chance and blow it
How to set up radio without wiring diagram : First you need to hook up the lead and ground power wire to your radio.(the lead usually has a line all the way down it). Turn power on to the radio and switch to am/fm. Locate any lead speaker wire and connect it to front right -. Then take all ground speaker wires one by one and touch them to front right +. As soon as you hear a sound, find out which speaker it is coming from, as soon as you have identified correct speaker remove wires from right speaker and mark them carefully. Do this with the rest of speaker lead wires an speaker ground wires and you will be able to connect your stereo.
Jun 18, 2009 | 2005 Chevrolet Silverado 1500HD
Wiring Olson S550 Speakers
I assume these are not powered speakers -- is this correct? I.E., there is no volume control on the speakers -- just tone control.
The + / - are for connecting the speaker leads from the back of the amp.
Not much of a diagram needed. There are left and right + / - speaker terminals on the back of the amp. Run wires from there to the + / - connections on the speakers.
Apr 29, 2009 | Audio Players & Recorders
Need a wiring diagram because the harness i boughtfor my cd player is wired slightly wrong
yellow wire - continous power
red wire - power ( when switch is on)
black wire - ground
blue wire - remote ( has power when switch is on) ( must be connected)
blue/light blue - rear right speakers
yellow/brown - rear left speakers
white/white striped - front left speakers
grey/pink - front right speakers
orange wire- dimmer lights ( not important)
these are the wires coming from car follow this diagram and you should be fine
Jul 22, 2008 | 2000 Oldsmobile Alero
Wiring diagram and manual needed for wd810
The manual can be found here: http://www.rmeco.net/images/IB/durabrand/WD810.pdf Also, here are some standard wire colors: Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Sep 02, 2007 | Durabrand WD810
Crunch PZI250.2 Car Audio Amplifier Logo
69 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Walter Dominguez
Level 1 Expert
Vernon Taylor
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
