Question about Sport & Outdoor - Others
Diagram on the timing marks on a 2001 honda trx 250 ex
wayneman01
  • 301 Answers
SOURCE: 2007 honda trx 250 ex needed battery replaced it
Find the main fuse and check it. It's either got a corroded connection or it is 'blown'. If the fuse turns out to be okay - then check for battery voltage at the fuse (between the fuse and the chassis) with the key turned on. No voltage at the fuse means you've got a faulty ignition switch, a bad harness ground connection - or other harness connection(s) that are corroded or unpluged.
Posted on Nov 09, 2009
  • 11 Answers
SOURCE: timing marks for a 1995 honda civic lx
did you try google thy check there images that alwas helps
Posted on Nov 11, 2009
Tnsiouxfalls
  • 617 Answers
SOURCE: need timing diagram for a 1987 honda crx 1.5l sohc
3ec524b.jpghope this helps!
Posted on Dec 08, 2009
  • 819 Answers
SOURCE: need to know how to line the timing marks on the
there is a timing mark on the timing cover that lines up with the mark on the crank pulley (i believe the mark is above the white dot on the crank) then on the 2 gears up top, there are lines that should line up horizontally with the top of the timing cover.
Posted on Mar 20, 2010
jturcotte
  • 8531 Answers
SOURCE: 2001 honda civic ex stereo
Sorry, I don't have the right diagram, but I will walk you thru finding the color code.
Connect a test light or voltmeter to ground and probe each terminal with the key off.
The one that has power is called hot and is used to maintain your station presets.
Turn the key on, and you will find another terminal. That is the accessory wire that powers the radio.
Next, hook the test clip to the hot terminal and probe the terminals again. The wire that yields a voltage will be the ground--It's probably black
Posted on Mar 17, 2011
I need wire schematics for 96 Honda trx 250
Here is a link to the manual for a 97, can't see it being different. There is also a 95 at the same site. It is Australian but that shouldn't make much difference. Give it time to download as it is the whole owners manual including wiring diagram.
http://campaigns.hondampe.com.au/Motorcycles/manuals/atv/own97trx25001.pdf
Oct 09, 2015 | Honda Motorcycles
How do i find the number one wire loctaion on the distributor of a 2001 honda accord ex. 2.3l v-tech
Here is the diagram showing the number one cylinder location.
If you want to know when #1 is ready to fire remove the spark plug and rotate the engine by hand until you fell pressure in the cylinder with your finger over the hole, then look at the timing mark on the front pulley, move the engine until the mark is at "0" TDC, then remove the distributor and set it down so the rotor points towards the location of # 1 in the diagram below.
Oct 13, 2011 | 2001 Honda Accord
Hi, can you help me?? i am looking for the valve clearance gaps for a 2008 honda cbx 250 twister. my current gaps are, ex = 0.10mm and , in = 0.12.... please help, it doesnt sound right
Your valves are adjusted backwards. Most Honda's will use: IN = 0.10 mm ( 0.004 in ) and EX 0.12 mm ( 0.005 in ) A simple adjustment should take care of the problem.
Oct 15, 2010 | 2001 Honda CBX 250 TWister
I need a diagram or instructions on how to set the timing belt on a 96 honda civic ex 1.6L sohc
Click on the following: direct, free Link. It has the Timing Belt + Mark Diagrams for your 1996 Honda Civic 1.6L SOHC. It has several additional diagrams to help you.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1996/make/honda/model/civic/1996_honda_civic_timing_belt_diagram_marks.htm
May 19, 2010 | 1996 Honda Civic
What timing marks do i look for on the camshaft sprockets when timing up the cams, i have the tdc mark on the crank already
Presumably you sorted this?
The answer is as follows:
Looking from the RH side of the bike, the LH (inlet) camshaft sprocket has 2 marks "IN" and "EX" on opposite sides of the sprocket. The "IN" mark needs to be on the LH side i.e. at the rear of the bike. For the RH (exhaust) camshaft sprocket, the "EX" mark needs to be on the RH side i.e. at the front of the bike. Both marks need to be flush with the top of the cylinder casing.
Apr 23, 2010 | 2005 Honda CBF 250
2007 honda trx 250 ex needed battery replaced it with new still wont start...no power ignition switch on? help!
Nov 07, 2009 | 2005 Honda CRF 250 R
Is there a timing diagram? I need to put the timing chain back on.
remove the right hand inspection hole from the engine cover turn the engine over with bolt in the hole and set the mark to no 1 tdc on remove the cam chain tensioner set the inlet cam with the inlet line mark flush to the head were the cam cover would sit then set the ex cam flush with the ex line and check that all three marks line up :inlet flush with the head the same with the ex cam and the crank mark lines up with engine case no 1 mark bolt down the cams in a criss cross pattern and torque to 12nm then back of the tensioner with a small flat head screwdriver you will have to hold it in the bolt it in and pull the driver out and you should hear it snap in place turn the engine over clock wise and recheck your marks to make sure you have it set wright.
hope this helps please leave feed back.
Oct 05, 2009 | 2000 Honda Hornet 250
Sport & Outdoor - Others Logo
127 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
