Question about HP Photosmart D7360 All-In-One InkJet Printer
Carriage jam how do i fix carriage jam? thanks
  • miwn Mar 18, 2009
    That didn't work, taking out the ink cartriges.
  • Anonymous May 18, 2009
    LCD says Fix Carriage Jam then press OK. nothing seems to fix this problem and i can't bypass and force print anything. anyone with a solution? pulling cartridges did not work, installing new cartridges did not work, willing to look at other possibilities.
    President:
  • 4,402 Answers
Ouch! take the ink cartrige out and put it back in.
Posted on Sep 03, 2008
My hp printer 5525 shows carriage jam how can i fix this?
If you lift the lid to get access to the cartridges, there should be a diagram showing you how to unjam the carriage. I have a 564, & it has that feature.
Aug 05, 2016 | HP Photosmart 5520 Multifunction Inkjet...
I'm getting an error msg and can't print. It says please fix cartridge jam and hit enter. I can't find any jam. What do I do?
If there isn't a cartridge jam then it's probably a carriage jam:
However, I'm not too familiar with clearing a carriage jam. I just know that if your cartridges are not blocked then the carriage is likely at fault. You will need to Google this on how to fix a carriage jam.
Jan 24, 2011 | HP OfficeJet 6110 All-In-One InkJet...
How do you fix carriage jam?
1. unplug the unit
2. open the lid
3,. Grab the carriage and move it to the far left.
4. power the unit
This should clear the jammed carriage if it does not give or does not move and its hard to move STOP its useless the whole carriage will need to be replaced or repaired witch by all means is not a easy task.
Only move the carriage if it gives movement.
Thanks I do hope this helps, do not shoot the messenger I am not there, please do leave you rantign before you go, thanks
Aug 17, 2010 | HP Officejet J5780 All-In-One InkJet...
HP 6110 Printer jams after 1 sheet
Thanks for contacting Fixya.com
Please try the bellow mentioned troubleshooting steps to help elliminate the paper jam and noise issue for your printer:
Things that cause a carriage jam error:
Dirty encoder strip.
Damaged encoder strip.
Encoder strip spring mount out of position so strip is slack.
Encoder strip not threaded through the emitter/detector that reads the lines on the strip. (just fixed a 5550 with this problem)
Emitter/detector that reads the lines on the strip is bad, this is part of the carriage PCA, (board).
Carriage stuck on side because service station is not releasing it.
Carriage stuck due to being tilted at wrong angle, if it's stuck a few inches from the right it needs to move farther to the right to be released, stuck a few inches from the left end move it farther to the left. (instructions probably on HP web site, they are there for the DeskJet 5550)
Carriage binding on rail due to ink build-up or lack of lubrication, (be careful what you use to lube).
Bad carriage motor.
Bad carriage drive belt.
Some machines have a timing disc on the service station motor and may indicate a carriage jam if the service station motor does not turn.
The cause could also be a loose cable connection on a small circuitboard inside the printer (The one that controlled the paper jam sensors) I fixed it by saudering the leads to the board until I had a good connection again.
Thank You and best of luck,.
Jul 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My printer have carriage jam
try to move the carriage manually left and right...will fix the issue.
Nov 24, 2008 | HP Office Equipment & Supplies
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Photosmart D7360 All-In-One InkJet Printer Logo
260 people viewed this question
Ben Johnson
